Question about Frigidaire FFU14F5HW 14 Cu. Ft. Upright Freezer With 3 Wire Shelves, Basket,Interior Light, Door
Freezer sshuts off..a " J " appears on the door control panel
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
How do I fix a Freezer door alarm went off How do I reset the freezer?
Hello Friend, this is Z. I am happy to assist you!
From what you have described it sounds like your freezer may possibly be in the OFF position or lock which may occur after a power outage or alarm. In the meantime, let's attempt resetting your freezer by pressing and releasing the "UP" arrow three times within three seconds or the "DOWN" arrow three times within three seconds. If an LC appears, then your control is locked. Then repress and hold the control lock key and try the procedure above. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully.
Jul 29, 2014 | Frigidaire Freezers
Freezer lffu14f54hwc try to cutoff by holding down till 0 appears get e7 appearing
Hello Oran - Typically error code F7 on Frigidaire freezer indicates that the unit has detected a stuck key or fail safe mode initiated. Check if it has a thermistor failure and may possibly need to replace the main control board. Contact a professional to move forward accurately.
Oct 12, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer keeps beepimg
if the temp. in the refrigerator side is 20f, its to low, set the ref. to 40f and freezer to 0f.
Sep 23, 2012 | Liebherr CI1651 30" Built-in...
I have a 2007 model 253.264 upright Kenmore self-defrosting freezer. The control panel on the front door stopped working. No temperature reading and no way to adjust controls. The freezer is still
I have one out in the yard that is doing the very same thing. Works good but the door display is out. I looked underneath and all of the wires seem to be connected. The main control board is on the bottom as well. The battery is also new. You must have a broken wire between that control and the main board below. I imagine it has something to do the the connector that goes through the door.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 21, 2012 | Kenmore 13.7 cu. ft. / 388 liter Upright...
I don't have the model number. Fridge/freezer five years old with an electronic control panel on the freezer door. Freezer temp not showing, nor can it be adjusted. Freezer temp lowering, but appears to be...
Well, its good that it is still cooling, however since you cannot adjust the temps, you do still have a problem, and one that may include the unit fails to cool properly.
Oct 04, 2010 | Whirlpool Freezers
My frost free freezer is building frost on the top part of the freezer between the door and the small divider, the seals appears ok with no gaps and it never shuts off 2006 model
there are two vent holes in the bottom of the door that need to be seal closed there has been air leaking in from these holes also the rear air diffuser should be solid and the vent holes in it coverd as well.then you nee to take one or two small washers and remove the front panel inside the freezer and put the washer between the panel so there is a small gap between the top of the freezer and the divider
Sep 26, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
My GE freezer stopped cooling. I turned it off,
Hi
I think the problem you are experiencing might be due to the temperature control.
1. Check if the temperature control is off if you dont hear the freezer operating.
2.If you do not see an interior light,when you open the door,then make sure the freezer is properly plugged into an electrical outlet.
3.Move the temperature level to a colder level if the freezer is not cold enough.Warm weather can also be a factor.
4.Find the condenser and check to see if it needs to be cleaned. The condenser is located behind the decorative paneling at the bottom of the freezer.
5.If it doesnt work still then contact a technician.
GOODLUCK
Jul 28, 2010 | GE 16.7 cu. ft. Upright Freezer FUF17DTR
Frigidaire FFU14F5HW 14 Cu. Ft. Upright Freezer With 3 Wire Shelves, Basket,Interior Light, Door Logo
15 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
