Question about Hunter CareFree Plus 33222 Humidifier
I am not getting any moisture. The fan just runs but no water is being evaporated?
When I first started running it 2 days ago it evaporated half the tank of water. Since than nothing has evaporated
  • 2,113 Answers
How old is it? it may be time for a descale. Do you have any CLR or a janitorial or restaurant or dairy quality delimer/descaler?
Posted on Nov 28, 2013
2 Suggested Answers
  • 4 Answers
SOURCE: not adding moisture to the air
Have you cleaned the unit lately? The following is from the owners manual.
1. Turn the humidifier ‘OFF’ and unplug the unit.
2. Lift the main housing and remove the water dispersion tray and the PermaWick™ Filters. The motor is attached to the main housing. Do not place the motor near water. Do not use a wet towel on the motor or motor housing as electrical shock may occur.
3. The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
4. After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
5. Remove the water tank from the base and empty any water that is left in the tank. Soak the base in a mixture of one (1) gallon of water and eight (8) ounces of vinegar for 20 minutes.
6. After soaking, wipe the base with a soft cloth or sponge to remove any mineral build up. Rinse with clean water several times. If you are planning on storing the humidifier, be sure the base is completely dry.
7. Fill the water tank with one (1) gallon of water and eight ounces of undiluted white vinegar. Replace the tank cap and shake the tank vigorously until all interior surfaces of the tank have been exposed to the water/vinegar mixture.
8. Empty the tank of the water/vinegar mixture. Rinse it several times with clean water and then replace the tank cap. If you are planning on storing the humidifier, dry it inside and out, leaving the cap off to allow the tank to completely dry. Continue to clean the other parts of your humidifier.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes. 41553-01 01/03/2008 6 © 2008 Hunter Fan Company
Rinse well and reinstall the water diffuser cap. Do not expose motor or other electrical components to water.
10. Wipe the surfaces of the main housing with a soft cloth.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
Posted on Jan 17, 2009
Changed wicks and change wick light is still on. how to reset?
Humidifiers - Frequently Asked Questions - iAllergy
www.iallergy.com/humidifier_answers.html
Do I need to replace filters, and if so, how often? ... quietest humidifiers available, and the ideal choice when noise level is a concern (if you are a light sleeper). ... Most evaporative cool moisture humidifiers use replaceable wick filters, and these should bechanged every 2 months on average (wick filter life varies depending ...
[PDF]OWNER'S CARE & USE MANUAL - Appliance Factory Parts
www.appliancefactoryparts.com/content/pdfs/116710-1.pdf
Refill light with Automatic Shutoff. • 2-Speed Fan ... If it still does not fit, ... Thishumidifier is ETL listed with Essick Air brand evaporative wicks in place. ... wick, the water evaporates into the air, leaving behind any white dust, ... We recommendchanging the wick ... Use only Essick Air brand replacement wicks and chemicals.
Amazon.com - AIRCARE 1041 Replacement Console Wick ...
www.amazon.com/...Replacement...Wick/.../B0002GD...
Amazon.com, Inc.AHAM certified output; Longer lasting, still at 96-2/5-percent after 90 days; Less energy consumption ... Essick Air 1970 Humidifier Bacteriostatic Treatment, 1-Quart ... BestAir CB41 Essick 1041 Replacement Wick Filter ... Super Wicks trap minerals and other particulates to prevent white dust and sprays, which are often seen ...
Jan 04, 2016 | Humidifiers
I had left my vicks vaporizer with water in it for like a month or longer and barely cleaned it out and now it doesnt work no steam or nothing will come out wats wrong is it broken???
The problem is more than likely due to a calcium and mineral build up in the tank and the tubing.
Hopefully, it's not to late to do something about it. So follow the instructions below,
Unplug the unit.
Remove any remaining water from the tank.
Mix a 50/50 solution of White Distilled Vinegar and Bottled Distilled Water (enough to fill the tank) and pour the solution into the tank. Allow t to sit overnight. In the morning, plug the unit in and turn it ON. If it doesn't start producing steam, turn the unit OFF, unplug it and empty the tank. Mix more solution as described above, pour it in the tank and allow it to set for 3 or more hours. The plug the unit in and turn it ON. Hopefully, this time, it will start to produce steam. If it does allow it to run until the tank is half empty. Turn the unit OFf and empty the remaining solution from the tank. Refill the the tank with Bottled Distilled Water and run the unit until it's empty. That will flush the system.
In the future, I would highly recommend the use of Bottled Distilled Water, rather than using tap water.
If the above didn't solve the problem, it's time to buy a new humidifier and use Bottled Distilled Water in it.
Jul 19, 2011 | Vicks Humidifiers
How to stop it from spluttering
The sputtering may be caused by a calcium build up the water system. To solve the problem do the following.
Turn the unit OFF and unplug it.
Empty any remaining water from the tank.
Mix a 50/50 solution of Distilled White Vinegar and Bottled Distilled Water (enough to fill the tank).
Pour solution into the tank and allow it to sit for 1 - 2 hours.
Plug the humidifier in and turn it ON. Allow it to run until the tank is only half full. If the sputtering has not stopped, turn the unit OFF and allow the unit to soak over night.
The next morning, turn the unit On and run for 20 minutes. Turn the unit OFF & unplug it. Pour out the remaining solution and refill with Bottled Distilled Water. Run the unit for an hour. This will flush out the lines. After that, it should run normally.
I would highly recommend using Bottled Distilled Water in the future, rather than Tap Water.
Hope this helped you to solve the problem.
Jul 11, 2011 | Vicks V150SG 1 Gallon Humidifier
For some reason after 2 uses it has decided to stop pushing the moisture up and the whole unit got very hot including the tank of water?? I have used humidifiers for the last 30 years and thought this...
stop pushing the moisture up? I feel you may have shorted out the unit. ultrasonic humidifiers differ from old humidifiers that relied on a motor and a little rod that sticks in to stir and disperse water droplets. (the old ones were designed to get wet).. Now they are little small vibrating disks and a fan to break down water molecules. the unit is designed to get the moisture into the room. but if it starts to **** the moisture back into it's self from the fan in the bottom. then no good can come. I messed up my first one from not knowing to keep moisture out of the bottom. but a good return policy does wonders! :)
Dec 23, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
Does not dehumidify
Hello. I am here to help. Let me begin by saying that a dehumidifier only needs to be operated if the humidity in your home is too high. If the humidity is low, the humidifier will have to work really hard to try and remove water from it.
Here is an overview of how the dehumidifier is supposed to work:
When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
May 20, 2009 | Whirlpool AD40U Humidifier
Motor runs, but does not collect any water in yank
Make sure any air filters are clean. Check to be sure the evaporator and condenser coils are very clean. Also could the humidity level in your home just be very low right now and just no moisture to remove? If all of this fails it could be a compressor problem or a refrigerant level issue. If this is the case determine if it is worth the expense to repair.
Good luck
Mar 28, 2009 | Whirlpool AD25BBR 25 Pint Per Day...
Venta humidifier is not humidifying much.
Buy a new filter cartridge. www.ventahumidifiers.com
Mar 16, 2009 | Venta Airwasher VS 207 3.7 Gallon...
Aprilaire 560 constantly drains water
check to see if you have 24 volts between to 2 yellow wires coming out of the water solenoid. if you have 24v, then it is still getting energized to run. if it does not have 24v and the water is still running, the solenoid is stuck open. most likely from water deposits. sometimes you can take the solenoid apart and clean it, but probably better off just getting a new solenoid.
Feb 07, 2009 | Aprilaire Humidifiers
Hunter CareFree Plus 33222 Humidifier Logo
196 people viewed this question
Top Hunter Humidifiers Experts
jdthefixer
Vernon Taylor
mike
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
