Question about Air Lift Air Tools & Compressors
Need 15 amp switched fusible connection for air compressor 2012 sierra
  • 2,113 Answers
First off... what country/state/province are you in? It helps us help you.
Posted on Nov 28, 2013
2 Suggested Answers
  • 14 Answers
SOURCE: I have a Kobalt 15 lb. 1 phase 175 psi 1.3 hp,
do not connect any powercord directly to your motor wires. if second hand compressor i would get the motor tested first. lead possibly cut off for reason.
Posted on Nov 12, 2009
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
How do i fix my dewalt 55155 air compressor
It is a 15 amps motor and will need 6 times (90) that amount of amps to start up. Plugging it into a 15 amps circuit may work but a 20 amps circuit is more apropiate. Kitchen circuits are 20 amp circuits.
You can try plugging the compressor directly into the wall and see if it refills with air without trippiing the circuit breaker. Using an extension cord should be done with a #12 or #10 wire gage type, smaller type will cause a power loss in the cord and will cause the compressor motor to trip the circuit breaker.
Power formula is I square R, or the amps multiplied by itself and by the resistance of the wire. E.G. 90x90x4 = 3200 watts. This is at start up. To find the voltage drop divide the watts by current, 3200/90 = .... get the point? Keep voltage drops to a minimum, use heavy wire gage extension cords.
Mar 11, 2015 | Dewalt Air Tools & Compressors
Ok susp light came on
A malfunction with the air suspension system has been detected
Start with the basics and check the switch in the right front passenger footwell , by the kick panel and see if the air suspension service switch has been turned off , or perhaps its fuse # 12 ( 15 amp ) for the air suspension switch , or fuse # 15 - 5 amp for the air suspension module ( but unless you have noticed other things not working it's probably not that fuse ) In the power distribution box in the engine compartment
( Ford states to disconnect your battery before servicing anything in the PD BOX ) fuse # 109 is a 50 amp maxi-fuse for the air suspension compressor , or it could be a sensor or the compressor itself etc.
Nov 14, 2011 | 1999 Ford Expedition
Changed ignition switch on 88 mustang after it wouldnt start. was also having issue with the blinkers not working unless the switch was exactly in the right position. battery is good. there is no...
If there is no power going INTO the ignition switch, you most likely have a burned fusible link. The ignition switch gets its power from fusible link "A" It is a 16 Gauge, BLACK fusible link connected to the YELLOW wire for circuit #37. The fusible link is connected to the starter relay located on the left fender apron between the washer fluid reservoir and the strut tower.
Circuit #37splits into 3 "legs" at splice #S105. One leg of this circuit goes to the fuse block where it feeds fuse #1 (15 Amp) and fuse #2 (10 Amp).
The other two legs of this circuit BOTH go to the ignition switch. (you should have TWO large yellow wires connected to the ignition switch.)
Aug 11, 2011 | 1993 Ford Mustang
1993 rodeo not running no power to fuel pump
if there is no power to the fuel pump check relays and fuses....UNDERHOOD FUSE & RELAY PANEL IDENTIFICATION Fig. 2: Underhood Fuse & Relay Panel Identification Courtesy of ISUZU MOTOR CO. Fusible Link Identification ? A - 80 Amp (1991-92 3.1L) ? A - 60 Amp Main-1 ? B - 30 Amp Main-2 ? C - 30 Amp (1993-94) ECM (3.2L) ? D - 30 Amp Condenser Fan (A/T Models) Relay Identification ? 1 - Headlight Relay ? 2 - A/C - Heater Relay ? 3 - Starter Relay ? 4 - A/C Compressor Relay ? 5 - Charge Relay ? 6 - Fuel Pump Relay ? 7 - ECM Relay ? 8 - Wiper Relay Fuse & Circuit Breaker Identification ? 1 - 15 Amp (1991) ECM, Fuel Injection System ? 1 - 15 Amp (1992-94 2.6L) ECM, Fuel Injection System ? 1 - 10 Amp (1992-94 3.1 & 3.2L) Heated Oxygen Sensor, Fuel Injection System ? 2 - 20 Amp (1991-92) Fuel Pump ? 2 - 20 Amp (1993-94 2.6L) Fuel Pump ? 2 - 15 Amp (1993-94 3.2L) Fuel Pump ? 3 - 10 Amp (1991) ? 3 - 15 Amp (1992-94) Turn Signal Lights, Hazard Warning Flasher Lights ? 4 - 10 Amp Horn, Door Locks ? 5 - Not Used (1991 3.1L) ? 5 - 10 Amp Charging System, Charge Warning Light WARNING: Always disconnect battery ground cable before servicing "high- current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician. Page 1 of 2 FUSES & CIRCUIT BREAKERS -1994 Isuzu Rodeo LS? 6 - Not Used (1991) (1992-93 2.6L) ? 6 - 10 Amp (1992-94 3.1L & 3.2L) A/T Interlock System ? 6 - 10 Amp (1994 2.6L) Heated Oxygen Sensor, Fuel Injection System ? 7 - 20 Amp Heater/Air Conditioning Blower Controls ? 8 - 10 Amp Air Conditioner Compressor Controls ? 9 - 10 Amp Right Headlight ? 10 - 10 Amp Left Headlight © 2008 Mitchell Repair Information Co., LLC.
Underhood fuse block swap out relay #7 thats the ECM relay.
Ground Circuits Using a DVOM, touch negative voltmeter lead to a good ground. Touch positive voltmeter lead to each ground terminal. With vehicle running, voltmeter should indicate less than one volt. If reading is greater than one volt, check for open, corrosion and loose connection on ground lead. See ECM GROUND LOCATION table for ECM ground location.
Page 1 of 1 SYSTEM/COMPONENT TESTS - 2.6L EFI -1994 Isuzu Rodeo
Mar 28, 2010 | 1993 Isuzu Rodeo
I have a Kobalt 15 lb. 1 phase 175 psi 1.3 hp, 120v, 15 amp, model 215902 VPK1381509 air compressor that either had no or someone removed, before I got it, the power cord. I cannot find anywhere to connect...
Nov 10, 2009 | Air Tools & Compressors
Motor will not turn on i hit the start switch it will buzz then it will pop the reset switch"
THIS PROBLEM IS MORE THAN LIKELY BECAUSE THIS PRODUCT NEEDS TO RUN OFF A 20AMP CIRCUT AND IS PLUGED INTO A 15 AMP CIRCUT.HOPE THIS HELP'S
May 18, 2009 | Coleman Powermate 02 - Gallon Air...
Air Tools & Compressors Logo
35 people viewed this question
Top Air Lift Air Tools & Compressors Experts
John Trevino
Lawrence Oravetz
Are you an Air Lift Air Tool and Compressor Expert? Answer questions, earn points and help others
