Question about Acer X193HQ 18 inch Monitor
Display only few minute then scree black - Acer X193HQ 18 inch Monitor
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Display turns dark pink for few minutes and goes
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Oct 23, 2013 | Eiki EIP-5000L 5200 ANSI Lumens DLP XGA...
Mitsubishi big screet HDTV after being on for a minute, the scree pops and goes black with some red lines, then the volume turns all the way up by itself.
Do the self check----if set has been unplugged plug it in and turn on for it to fail----when it shuts off ON THE FRONT OF THE SET press and hold both the menu and input (device) buttons at same time for at least 5 seconds and release both.
Power light will blink a two digit error code like, 1 blink, 2 blinks and pause and repeat it for a total of 5 times.
What if any error code do you find?
Jun 16, 2012 | Mitsubishi WS-55513 55" Rear Projection...
My compiter will not play any videos from any website it just gives a black scree
Good evening to you
Do you think that there are some adjustments to be made?
START-Control panel- display it is worth a tryGood luck
kollsgunn
Feb 21, 2012 | Dell Computers & Internet
I can log on using my password but then nothing happens -just a black screen - can do ctrl alt + delete and the options come up to do task manager etc but select anything and the scree is still black
Found this on the Dell support site.
  • "Function key combination — Can be used to select display
    arrangement but these are best used to cycle through views after
    display settings are chosen
    Press <Fn><F8> to select the desired display arrangement."
It sounds like the display has somehow been changed to display on "external monitor only.
Here is the link to your users guide where I found this info.
Support.Dell
go to page 224
hope this helps. GOOD LUCK!!!
Oct 18, 2009 | Dell Inspiron 1525 Notebook
Iphone displays default IMEI # and ICCD#
the phone is good but phone application is not working so you have to go to service center to resolve
May 18, 2017 | Apple iPhone Smartphone
Boot up problem
I thiknk your hard drive may have failed/corrupt. If so, a simple reformat will do. But if it has crashed, you will have to get a new hard disk. If you are really desperate about your data on your dead hard disk, go for a hard disk recovery activity. It may be costly though.
Jun 05, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Black square at center of screen
turn off the closed captions or set the feature to c1 to view. they are set to text now.
Jan 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Monitor gone black
Hi there, You do have a Hardware Problem, a Electronic Parts. If the scree is fine for about a minite and then goes black again then you may have a cold solder on the board of the monitor or a defective parts on Horrizontal Section for your screen. You may need to repalce some electronic parts. TY
Dec 21, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer X193HQ 18 inch Monitor Logo
13 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
