When i press the power key of cpu power cut of one second only
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 77 Answers
Typically the problem your describing is found in the power supply.
You will need to replace the power supply with the same watt rating and compatibility as your PC.
Just to confirm that is the issue, I would disconnect all attached interface cards and drives from the motherboard..with the power supply being the only attached item.
Power up the PC, if it stays on.. the power supply is good.
You will then install each component one at a time and restart.
You will identify the bad component when the problem comes back.
Make sure to disconnect the power cord each time you remove and install each component. Never plug any component into the motherboard while the power supply is connect to power.
Posted on Nov 30, 2013
My computer boot but switch off in 5 seconds after mountong it on a new case
HI,
Do this first step power on your CPU, then press F8 to show safe mode highlight and select
Last known good configuration(advance),then press enter key.
If switch off again.try this second step open cover of CPU get your hardisk and install to other CPU desktop need slave only to fix the data cross link and viruses if have.
Clean bad sector and viruses (if have), then connect again to your CPU
Just let me know if same problem again.
thanks for using Fixya.
Jul 14, 2011 | Computers & Internet
Monitor goes blank and power light remains on and when i turn it back on, it stays on for about 3 seconds and goes blank again. thank you!
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
May 15, 2011 | HP Compaq WF1907 Monitor
My dell moniter shows purple light at the power button instead of blue/orange.... and its not workin.. wat could be the problem
First of all you need to check you keyboard light it may be the issue with your CPU. So check you keyboard light and press Num lock key if it's getting on/off when you are pressing the key. If it's working or not. It must be blink when you press the num key. If it's constent or not getting on then check with you CPU first ....may be there is some issue with you CPU. Second you can remove the cable from CPU which is connecting to monitor to check ....when you remove it from cpu it will give you some message on the monitor screen that check you vga cable etc. If it give's such message then it will be for sure then you need to your CPU fixed up.
So please comment back with your troubleshooting details , hope it will help out you.
Thanks Sanjay Kumar
Apr 26, 2011 | Dell SE198WFP LCD Monitor
Error lost cpu rest
This error on the T6125 may be caused by either a hardware fault with the printer, alternatively the problem may be caused by some sort of external influence on the printer. Passable resolution to the problem include;
Hardware Fault
Locate the main logic board, check the CPU to ensure all pins are soldered correctly on the PCB. Check there is no solder over spill shorting any of the pins.
There may be a fault with the main logic board which may require replacement.
External Influence
1) External Print Server
One of the most common causes for the LOST CPU error is the use of external print servers connected to the Parallel Interface.
These printers are not reliable if connected to external print servers unless the printer parallel interface has been set Uni-Directional. To do this, you need to follow these instructions.
Set the printer to Offline.
Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access On)
Press the Mode key: display will show Offline Normal.
Press any Arrow key until display shows Offline Config.
Press the Forms/1 key.
Press any Arrow key until display shows Config Parallel.
Press the CPI/2 key.
Press any Arrow key until display shows Parallel Bi-Dir.
Press the LPI/3 key.
Press any Arrow key until display shows Bi-Dir Off.
Press the Enter key and the interface will be set.
Press the Clear key.
Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access Off)
On the external Print Server, you need to ensure that the unit is also set for Uni-directional working.
Electrical Interference
Check the area around the printer to ensure there is no external electrical interference eg Electric Motors, High Voltage Cables in near vicinity of the printer.
Feb 21, 2011 | Tally T6215 Matrix Printer
My computer will not turn off how do I make it turn off.
Select "Turn off" or "Shut Down" by clicking on it. orClick on Start button>Turn Off or "Shut down" computer. else, Press the power button of your CPU for a few seconds.
Hope it will be helpful to you
All the Best!
Nov 12, 2010 | Computers & Internet
How do I fix my computer moniter?the screen is black
When you power up then after 12 seconds check the num lock led status on key board press num lock key then if num lock led is on and off then your cpu is working fine.
For that make sure vga adapter from monitor is connecxted to cpu is properly.Then when you power up the computer press F8 key then you can see some menu enter in "Enable vga mode " then go to display property and change screen resolution to 1024*768 then apply and check.
But if num lock led is constant then then you need to open cpu cabinet cover.
Then reconnect ram memory .Try it in different ram slot.Make sure motherboard is not ground with cabinet.REmove pci or other card if any.
Then check.
Pull cmos cell from motherboard for 10 minutes then connect again.
Also reconnect processor and it's fan then check.
Let me know if you need further assistance.
Thanks for using FixYa.i
Jun 28, 2010 | Computers & Internet
The yellow power led light blinks on front of the emachine w2646. The CPU Fan works. The power button will not turn the PC on or off, you just have to plug in the power cord to turn it on. The monitor just...
Did you flash the main board ??
1.) remove battery
2.) press and hold the power button for 10 - 30 seconds
3.) replace battery.
4.) when the system boots it will say press XX (e.g F2) to load defaults and continue ,, press that key.
It could also be the power button is stuck!.
find were it connects to the main boad and unplug it
bridge the 2 pins it jacks into to turn the computer on. if it works u will need to replace that button or the case.
Feb 26, 2010 | E-Machines eMachines Desktop PC
Not staying on
proberly due to over heating matey,
try replacing the thermal paste on the CPU
if its still in warrenty then give dell a ring :)
Feb 17, 2009 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
