Question about Cooktops
Wolf gas stove top will not start
Gas appears as being shut off as we can not light manually and ignitor is working fine. Is there a shut off valve?
    Scholar:
    New Friend:
  • 81 Answers
All stoves have a gas shut off valve. Make sure your gas dryer still works because you paid your gas bill. Yours might be located under the stove or in the basement.
Posted on Nov 28, 2013
textonor
  • 130 Answers
SOURCE: Thermadore gas stove top - left 2 burners won't light
Either the potentiors or the simmer control.
Posted on Jan 06, 2008
  • 222 Answers
SOURCE: auto electric lighter for the gas stove no longer works
gud day,the problem is ur igniter ligther is totally damage & nid to replace, if u want to use ur cooktop use matches or ligther every time open ur gas cooktop,tnx gerbee
Posted on Nov 18, 2008
joboo1
  • 257 Answers
SOURCE: Counter top stove burner won't light
Hi, You asked a very generic question but I will try to give you a good answer. If the pilot is good and you can light the burner with a match, (this checks everything else) then the most common problem would be the burner holes in front of the pilot are clogged. When cool, remove the burner and inspect the holes, any debris needs to be removed, a bent paper clip works really well. Compressed air helps as well. If there is a tube to the pilot make sure it is exactly where it belongs and that it is clean. If the match didn't light the burner or the flames is not all blue like the rest, there is something else wrong and you need to get back to us with a make and model to better help you. Make sure the burner gets seated back on the orifice correctly and best of Luck to you!
Posted on Feb 05, 2009
SOURCE: Cleaning grates of GE profile gas stove
Sounds crazy, but this works. Soak the grates in warm to hot water with 2 dryer sheets (Bounce), let them soak for an hour or two. Unbeliveable how they came clean. I did have to use a Scotch Brite pad on the two that I use most, but it sure beats replacing them.
Posted on Feb 06, 2009
  • 222 Answers
SOURCE: maytag stove top gas ignitor keeps clicking
clean the bottom of the knob by using vaccium,remove the knob,pull it then clean the area of the control knobs.
Posted on Jul 04, 2009
What wood cause a burner to ignite and will not turn off.
Is there an orange glow in the burner area when this happens? If so then the thermostat is not shutting the ignitor off and needs replacing. If there is no glow then the gas valve is not shutting off the gas and needs repalcing
Oct 10, 2014 | Whirlpool Kitchen Ranges
Electronic ignitor on propane stove wont start
  1. Close all valves, including the one on the supply tank.
  2. Open valves SLOWLY starting with the tank. Safety valves are built in to prevent escape og gas if vales are broken off.
  3. Turn on ONE burner valve and, depening on the ignition type of your stove, light it. (some have an electric spark generated by a power outlet (120v) and make a sort of poping sound, some have a spark generated by a push button type mechanism.
  4. Once one burner lights, the others should light easily. Sometimes air gets in the lines, and this may have to bleed off, but it should only take a few seconds. -PS, make sure the stove is level, since gas tends to flow to the high spot.
Feb 20, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
My GE Monogram gas range will not light. The igniter keeps going off but the gas will not light.
Hi, sometimes cooking spills stop the ignitor from working. Clean the cook top thoroughly and try it again. Spills can also make the ignitor go off randomly when you are not operating your cooker. Check if the ignition point where the zap comes from is not turned or bent too far from its original position. If you have a gas shut off make sure it is fully open to supply enough gas. If all else fails buy a cheap hand held ignitor to start your gas stove. If the cause is a spill which sometimes the problem can persist even after cleaning it may take a while for it to work again. If the problem is with all six burners then your ignitor probably needs replacing. When you hear the ignitor zap check to see if the electronic zap appears to jump across to the edge of the burner. If it doesn't it will not light the flame no matter how many times you try. I hope this helps you.
Aug 21, 2012 | General Electric GE Monogram 48""...
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
When I turn any burner on, the ignitors work fine but it takes a very long time for the burners to ignite. Problem is worse the longer the top has been turned off. Once gas gets to the ignitor, it lights...
It seems like one of your burners is clogged. You made need to use some oen cleaner and a small toothbrush to clean the burner. If the problem occurs with all the burners, then you have a blockage in the gas supply line. you willm have to take it apart at the stove and clear it out. Check the main gas connection and at the burner(s) to spot the debris clogging. Make sure to shut your gas valve off behind the stove. Good luck... hope this helps.
Jul 15, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
What causes gas igniter to keep clicking when gas is off
Just solved this on the Kenmore model 911.33389 (same unit). Ignitors started with no one touching the cooktop. It has had a history of doing this and, this time, sparks were visible under the knob. Disassembled cooktop (don't forget to unplug and shut off the gas!). Performed "smell test" for burned electronics. Found smell in #3 ignitor switch. Disassembled and found worn, burned, and fried. Parts list was inside unit but had a typo for the "ignitor switch". Showed WB18T10240. Ordered that only to discover it was the transformer to ignitor wire harness set (no photo on website!). Wrong part... ugh! Dug deeper for the correct part #. It was WB18T10239 but it has been replaced with WB18T10344. Noted on some website that someone installed one and then the ignitor was NOT synchronized. Turns out, you can install WB18T10344 about three different ways. Mine was 22 degrees off vertical (different than original) and now my unit works perfectly! Also, install the new switch harness (if that's what you do) starting from the left front valve then clockwise. The original unit installed from the right front valve, then clockwise. Hope this helps.
Jun 20, 2010 | GE Profile JGP636 Gas Cooktop
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
Feb 04, 2010 | Miele 36 in. KM3474 Gas Cooktop
Stove top gas flow and gas oven bake cycle not igniting
This most likely is the solution for the bake problem you have:
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jan 05, 2010 | GE Profile JGP636 Gas Cooktop
All of the burners on my range started flikering at the same time and they were off. I could not stop them. I saw a little smoke escaping from the rear right burner. It finally stopped flickering and now...
yikes .. you have a very dangerous condition there ... ventalate the area and turn the gas off immediatly.. there is a shutoff valve somewhere in the gas line coming to the stove top .. if you cant find that then shut off the gas at the gas meter or call the gas company to do that for you (its free) ...
your problem is likely a loose pipe or cracked manafold .. it is leaking gas under the cooktop .. i would replumb the unit and check for cracks .. or call a professional .. your unit comes with a 1 year warranty or an additional 4 years if you bought extra coverage .. that probably wont cover a bad installation if thats the problem (unless the repair company installed the unit to start with) .. but will cover the stoves inside plumbing ..
your stove is not safe the way it is .. if you can still smell gas then you shouldnt be in the house until the gas is turned off ... windows should be open .. dont turn on lights or other things that can ignite the gas .. and absolutely dont try to relight the burners until the problem is fixed ..
Nov 12, 2009 | Maytag MGC5536 Gas Cooktop
Wolf range cooktop
I just installed a Wolf gas cooktop and had the same problem in that all 4 burners would light just fine but the electronic igniters would not stop clicking on all four. What I found was that the electrical outlet that my gas cooktop was plugged into had the polarity reversed. I tested the outlet with a polarity testing module (you can get one at Home Depot and it checks polarity, grounding, GFI and is handy to have around, small and inexpensive). I plugged it in and the lights told me that the polarity was reversed. I reversed the wires in the outlet (exchanged the white and black wires) put the cover back on, plugged in the cook top and now it works like a champ! no more constant clicking. By the way, we had a cooktop before this one with electronic ignition and never had a problem, apparently it didn't care about the polarity.
Nov 10, 2007 | Wolf Range 18 in. SPR-100 Gas Cooktop
Cooktops Logo
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
