Question about Do All Traps Do All Outdoors Aerial Assault Black 3.0 Automatic Trap Thrower
Trap will not release at full speed - Do All Traps Do All Outdoors Aerial Assault Black 3.0 Automatic Trap Thrower
2003 ford windstar pumping gas spits back
Assuming the spitting happens when the tank is NOT full, almost always it is caused by a blockage of some kind. Either the fill hose is kinked, or someone has stuck something down the filler tube. Check for blockage. One way to check, is to get about 4 feet of large (1/2" ?) clear plastic tubing and run it down the filler. Before you go too far past the neck opening, be sure you will be able to pull it out without getting stuck. Have a screw driver handy to release the trap door if necessary. You should be able to stuff at least two feet down. Though it is possible some filler hoses have a wire spiral trap device to keep things from getting into the tank, like siphon hoses, etc.
Sep 09, 2014 | 2003 Ford Windstar
Zanussi jetsystem 1600
Get all of your towels. That little square on the bottom there. Open it with a flat head screw driver. There's going to be a trap there. Unscrew the lint trap by twisting the filter counter clock wise. Be warned, this releases the water. Check to make sure that trap isn't completely clogged with stuff. Put the trap back in tight and properly make sure the tub holds water before putting the square plate back on. ; ) . Voila
Apr 27, 2013 | Washing Machines
Clutch Bleeding procedures for a 1995 BMW 530I
Loosen bleeder screw on slave cylinder ,release trap air,close bleeder screw have a friend pounch the clutch pedal 3 times and hold pedal down. Open clutch bleeder screw,this release trap air, and close bleeder screw. repeat process three time and always maintaining the clutch fluid level.
Feb 29, 2012 | 1988 BMW 530i
How do set a mouse trap - i torn directions off am scare to experiment
Rule number one, BAIT IT FIRST!
Rule number two, always keep your fingers out of the line of fire.
When you are looking at the trap, it is sprung. That is, the mechanism is tripped, and the spring has flipped the bar to the "catch" position. You'll see the bar and spring. Look, and you will see another, single bar, connected on one end to the trap, with the other end loose. This is the trigger release bar. If you look at the bait tray, you'll see a place where the metal is pushed out on the side. This is the trigger. Here's how it works: You fold the spring bar over the bait pan, and hold it tight against the base, keeping your fingers out of the way (see rules 1& 2 above). While holding the spring bar down, use your other hand to bring the trigger release bar over the spring bar and to the bait tray. The end of the bar rests under the notch on the bait tray. As you are setting the bar, you'll slightly reduce your pressure on the spring bar. This pushes the release bar tighter against the notch. When the bar is in place in the notch, the trap is armed. When the mouse is tugging at the bait, the bait pan will shift and release the trigger release bar. It flips backwards, releasing the spring bar, which then catches the mouse.
Best regards, --W/D--
Jun 02, 2011 | Microwave Ovens
My furnace will not start the ignition process unless I disconnect the pressure switch (combustion tube not blower tube). What could be the cause? It's a new pressure switch. The vent pipe is clean.
I assume when you say you disconnect the pressure switch you mean you jump the wiring terminals? You say your vent is clean,but what about your combustion air inlet piping? Is it clear. It is not unusual for a furnace to sit over the summer and have the condensate drain trap dry out. This drain will drain the condensation from the blower and discharge to drain. If there is no water in the trap, it can allow air to flow up through the drain, which will cause a drop in the negative pressure. Try "priming" the trap by pouring enough water down drain hose until water comes out by the drain. If that doesn't work check to be sure motor is going full speed and that there are no creatures that have crawled into your inlet piping over the summer.
Oct 28, 2010 | York Furnace Draft Inducer Blower Fasco #...
Water under vegetable bin
I got this when the J-trap on the back of the fridge was blocked, not allowing condensation to properly drain into the drain pan.
I solved this problem by pulling the black drain tube off the J-trap (you may need to loosen the holding clamp at the bottom of the tube), giving the J-trap (it's about 2" round) a slight twist to release it from the sheet metal, and carefully pulling it out. Be careful as the sheet metal is sharp. You will see a 1" PVC tube end that fits inside the J-trap. This must be inside the trap when reassembling.
Flush out the J-trap and reassemble.
Oct 29, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Bosch dryer warning sounder for container full will not stop
Hi
You need to remove the left side panel, this is the side where the drain container is, once removed you will see the drain pump with two pipes coming from it, remove the pipes and top cover, disconnect the wiring, remove the pump unit with the clip, clean the float unit and pump, also remove the congealed mess in the water trouth as this is what holds the float up and makes the machine think the drain container is full.
I bet you will find this will cure the problems you are having, it did with mine.
Sep 07, 2009 | Bosch Dryers
1997 bmw z3 conv. 1.9 overheated, changed radiator, new thermostat, hoses car still overheating , fill radiator w/water but water does not seen to go through , released air pressure from radiator and...
hi jasso, I would recommend checking the water pump if you see no flow in the radiator. Make sure when you fill up the cooling system, that you fill it cold, and that the vent screw in the radiator is loose. fill system until fluid comes out the vent screw. tighten the screw, start the car and have someone run at 1500rpm and check for flow.also, make sure that you have your temp setting full hot and blower on middle speed so that you don't trap air in the heater core.
Apr 04, 2009 | 1997 BMW 328
Do All Traps Do All Outdoors Aerial Assault Black 3.0 Automatic Trap Thrower Logo
93 people viewed this question
Top Do All Traps Sport & Outdoor - Others Experts
Are you a Do All Traps Sport and Outdoor - Other Expert? Answer questions, earn points and help others
