Question about Sony Audio Players & Recorders
Sony stereo hcd-eh15 keeps saying no disc any answers
Stereo unit trying to play a cd after it says reading it comes back no disc
    Problem Solver:
  • 8 Answers
Disk is damaged, or it was a disk made on a computer and the player is not recognizing the codecs that were burned into the disk.
Posted on Nov 29, 2013
  • Micky Johnson Jan 26, 2014
    The correct answer is that disc format is not recognized by unit. That's it for sure if normal retail disks are playing.
  • 4 Answers
Hi try unpluging it wait 30 secs and try again
  • 130 Answers
SOURCE: CD player
All this cd systems have the same problem. If you're using burned cd's sometimes they don't work so you need to close the session after burning in your burning program. If you're using original cd's it means that the device needs to be cleaned up (especially the lens) because the structure of a 5 cd combo device gets very dusty after a while. Also from my experience after cleaning it put a cd in each deck (even if it's off) so they could prevent it getting dustier again. Hope it helps, good luck!!
Posted on Feb 12, 2006
SOURCE: stereo won't read cds
You might try running a cleaning CD in it (which cleans the lazer lens). These are available from Wal Mart and many other sources. If a cleaning doesn't get it going, then you may have a lazer that is weakening and might need to be replaced (sorry!). Hope just a good lens cleaning will do the trick.
Posted on Jan 10, 2007
  • 319 Answers
SOURCE: cd player will not read disc
Unit probably has defective disk motor or function sensor
Posted on May 08, 2008
SOURCE: my sony mini hi-fi component model HCD-RV7, stereo wont come out
how can i remove push power protect
Posted on Oct 03, 2009
  • 6 Answers
SOURCE: Sony hcd gx450 blinking problem
your speaker are hooked up wrong.or there may be dust in or on the terminals.i used a q-tip with rubbing alcohol and wiped them down.hook up the speaker cords properly and try this again.if this does not work then unplug the stereo and let it sit overnight and try again.
Posted on Nov 16, 2009
Why does my CD player display "no disc"?
I had a similar problem with my DVD player. Cleaning the laser eye helped fix my problem. You can clean it manually if you are not afraid to remove the cover of the unit or you can try a cleaning disc. The eye can collect dust and prevent it from reading the ID sector of the music CD.
Jul 07, 2014 | Audio Players & Recorders
Hcd-eh15
The laser pickup assembly has a short causing the unit to shut down, The whole assembly would need to be replaced in order to resolve, not worth the cost to repair, cheaper to replace.
Apr 25, 2012 | Sony Audio Players & Recorders
I have a Sony CD/tape player model # HCD-NE3. When trying to read a CD - it says NO DISC. What should I do?
Typically a no disc display indicated dust on the optical unit ( lens ) or failure due to low laser beam emission. For the first case you have to remove the top cover and clean the lens very gently with a ear bud. The the cleaning does not solve your problem you have to replace the optical unit itself. Unless you have experience doing the above i won't recommend it. Replacement will cost you about 15$ plus labor.
Aug 11, 2011 | Sony Audio Players & Recorders
I put in the cd and it reads then it says play and it wont play
THATS NORMAL......SO DOES IT PLAY? IF NOT U HAVE A DEFECTIVE UNIT...TRY A DIFFERENT CD OR CD CLEANER DISC
Aug 29, 2009 | JVC AM FM CD DET FACE CAR STEREO
CD is not playing on my SONY Home Audio CMT-EH15
HI. that grinding sound is signaling a lens assembly issue. the linkage and gear assembly seems to be jammed. this assembly must be able to move freely i order for the lens to track the CD. if the lens assembly is stripped or jammed, it will not be able to read and it will shutdown into stand by mode to prevent the motor from damaging itself. its most likely gear failure.
Unfortunately, the repair parts for this unit are only available from sony repair depots and, you will need to contact sony manufacturing in order to receive a repair ticket.
May 19, 2009 | Sony Audio Players & Recorders
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Sony mini hi fi shelf system reads no disk
you may have a defective lense . but check your disc to see if they are dirty..
Jan 06, 2008 | RCA RS2505 CD Shelf System
CDX-M8800 won't read CD-R discs
hi mate did you make the cd if so make the cd on slow speed it will work then max of 16x on you cd ok mate
Oct 19, 2007 | Sony CDX-M8800 CD Player
Fw316C cd player will not read discs
Buy A CD Lens Cleaner and put it in to the CD Player and keep retrying until the drive plays it and then follow the instructions for the CD Lens Cleaner after its finished try playing a CD if it still wont play try another disc and if it does not play that try reset the player by unplugging it for five seconds if it still wont play the CD drive has failed in the drive and you need a new stereo. Stereos dont last forever so dont be surprised if you need to buy a new one
Aug 17, 2007 | Philips FW316C37 Shelf System
88 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
