Question about Cuisinart EM-200 Espresso Machine
Manual button goes to steam
When making coffe by using the manual button the machine goes tp steam option
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
Hinari instructions
Put water , close cap , insert coffe sac , twist , press button wait 5 minutes , put steam in cup with milk ,, add coffe , sugar to taste .
Oct 22, 2013 | Coffee Makers & Espresso Machines
My Francis Z1 machine has lost pressure. The coffe is not as good as it was, it´s more of water than foam on , i´m using pods. The steam is not working anymore. It leaks water and sometimes the...
Your machine have different small problems.
First the steam is not working since during descaling one small scale part blocked in one poind the pipe or valve so the water can not pass and create steam out.
The second problem you describe is that the thermostat which is located on the thermoblock-boiler is not working properly so it does not switch off heating thas you have overheating and thus the valve explosion when the pressure go very high. Also if you try to make a coffee with this very high pressure so very hight temperature then the coffe will burn so you will have atery coffee without cream.
So your machine need to desasembel and manual descale pipes and valves and also to replace the thermostat.
It worh it if you can do it your self or if you find a service that will not charge a lot since you mostly need labour and not parts.
Good luck and thank you for voding
Aug 10, 2010 | FrancisFrancis! X1 - Stainless Steel...
My meile coffee machine cva620 is not froffing properly
check to see if your steam nozzle is clear unscrew tip and clean also run descaler thru to make sure steam tank is clear if still not ok steam tank thermostat may be faulty need to service machine hope this helps
Nov 05, 2009 | Coffee Makers & Espresso Machines
VENTILATE appeared on the screen. machine stoped working?
Try open for steam, it could be that there`s an airbubble inside the fluidsystem. Or maybe check the manual if ypu need to empty the system after using the steam, I know some older models has to be ventilated after the steamprocess.
Jul 07, 2009 | Saeco Royal Cappuccino Espresso Machine
Grinder runs with NO beans inside
Fill beans before they run out!
If you hear the grinder running empty, press the same button you pressed to start making coffe to cancel the current cup -or, if some beans were ground, stop the water a bit earlier to make a shorter coffe using the same method (press the button you pressed to start the cup). The auto-detect of beans missing is a very minor and largely useless feature.
Jul 29, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
No water coming out
Well on a Aroma I allways test to see if its just not air in the machine.
Turn on the machine.
press the coffe button.
Then press the steamer button ( dont turn off the coffe button.)
Do it come out hot water from the steam nossle then after a while?
Then turn of the steam button, if the filter is not blocked there should now come water from the coffe outlet.
Jul 21, 2008 | Saeco Aroma Espresso Machine
Water pump does not work
Try to open the steam knob and turn on the button to make coffee, when the water flow out off the steam pipe, close the knob and the button.
Jun 06, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Steamer
If the machine also did not work again, you have blown an internal fuse or the boiler heater has failed. If lots of steam came from inside the machine when it went bang, you have probably blown a hose, or a safety valve blew off because the heater failed to regulate temperature. Good luck, Saeco are expensive people!
Dec 21, 2007 | Saeco Vienna SuperAutomatica Coffee...
Cuisinart EM-200 Espresso Machine Logo
15 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
