Honeywell th6110d1005 heat setting set at 70 and temperature reads 70 and the heat pump runs continually. The actual temperature in the home is 79 yet the heat continues to run.
    Genius:
  • 1,198 Answers
Make sure it's in auto, not manual.
Posted on Nov 29, 2013
3 Suggested Answers
  • 5127 Answers
SOURCE: thermostat won't keep furnace fan running
You probably have a loose or broken wire to the fan relay. Check the wires on the thermostat first. Pull up on the bottom of the thermostat to remove it from the wall plate. You should see several screw terminals and the conductor wires that should be connected to them when you look at the wall plate. Check if any of the wires are disconnected or broken. If a wire is broken, strip a portion of the unbroken section of the wire and secure it to the appropriate screw. (The fan relay terminal is G for most setups.) If none of the wires are loose or broken, then you have to check for damage to the wires between your heating system and the thermostat or at the heating system. It could be a bad wire going to the jumper on control board or damage to the board itself.
I hope this helps. If the problem is not at the thermostat, you may need to have a professional diagnose and fix the problem. However, if you post additional comments about your heating system, Fixya experts may be able to help you diagnose the problem.
(we had the broken wires at the thermostat keeping the fan from working in the past. It's an easy fix if you are willing to handle small wires carefully.)
Posted on Jul 06, 2013
mikadot
  • 2113 Answers
SOURCE: i have a honeywell thermostat t6360.the light
Many thermostats have battery backup as well as the 24 volt ac. Have you replaced the batteries to see if it fixes all of your issues at once?
Posted on Nov 02, 2013
What does it mean when the aux is flashing on my thermostat?
I assume that you have a heat pump system. If this is the case, the outside temperature is probably lower than the heat pump is sized for and it is using the auxiliary heating system to keep up. The auxiliary heating system usually is an electric coil in the heat pump unit which supplements the heat being produced by the heat pump. This is normal operations and does not indicate a problem with the heat pump, it is just really cold outside. If it is not colder than usual outside, there may be a problem with the heat pump and you should call a heating contractor to check it out.
Jan 10, 2015 | Emerson 1F89EZ-0251 Blue 2" Thermostat,...
Honeywell emm-3 goes to high heat when thermostat does not call for heat
Replace it (thermostat), but first make sure its in a good location to read the space temperature.
Nov 29, 2013 | Heating & Cooling
Aux heat comes on
If you turn your heat on and the temperature is set 3 degrees above what the actual temperature of the room, the auxillary heat will automatically come on. The auxillary heat is an electric heat strip that provides heat to your home while the heat pump is in defrost cycle or if there are extremely low temperatures outside. Try not to set the temperature more than 2 degrees above the actual temperature of the room. Hope this helps.
Jan 25, 2013 | Honeywell Programmable Thermostat Heater
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
How do I change my Honeywell FocusPRO6000 TH6110D1005 thermostat to from Fahrenheit to Celsius?
Press and hold the up arrow and fan buttons until the display changes. Then press Next until you see 14 in the display. Change this value to 1 (with the up and down arrows) to get Celsius. (O is Fahrenheit.) Press Done to exit and save the setting.
The manual is available here: http://customer.honeywell.com/Honeywell/ProductInfo.aspx/TH6110D1005 . Scroll to the bottom and choose a manual then press Download. This particular section is in the Installer's Guide.
I hope this helps.
Jan 30, 2011 | Honeywell Programmable Thermostat Heater
Installed the Honeywell RTH2300
at the thermostat you have a small tolerance (most have 5% + or -) few degrees is not a problem ex...70F= 21C and 82F=27C this diference is inertial, you can set a lower temperature(ex...60 F to reach 72 F) the problem is if the temperature grow and never stop until the saftey thermostat stop the heating.also is posible to have a broken thermostat(work thermostat) and in this case it must be changed whit new one or the teperature probe is plced in a wrong place.
Feb 14, 2010 | Heating & Cooling
I have a honeywell th6110d1005 in my house i just had built. went to adjust the thermostat on heat and it will go down but wont go above 59
take the face off of your thermostat or open the front cover. there will be selector swithces the say HE, HG, and possibly one for heat pump. Heat electric and heat Gas. Make sure it is set to the type of furnace that you have. The wire should be red to the rh or rc terminal.(Should have a jumper wire), yellow wire to the y terminal, White to the w terminal which is for heat, and green to the g terminal. there is another adjustment to be made on the heat anticipator, but you would need an amp meter to set properly
Nov 26, 2009 | Honeywell Electronic Programmable...
I have just had a new boiler fitted and wanted to run the thermostat (honeywell cm921) on auto, the electrician set the timer to come on at 1 & off at 2 disabled at 3 & 4 and on again at 5 and off...
Complicated because I need more info....but in General a Boiler should not be on a Programmable Thermostat as it takes too long to heat etc...do you have Radiators in your house???Or ductwork for heat???It will make a difference...if you put the boiler on a program it may come on anyway as some boilers maintain there own internal temperature regardless of the thermostat.....if you want to run it on a program adjust the temperatures so there is only about a 2 degree swing....70...down to 68....back to 70.....etc...there should also be a switch in the thermostat to set for Boiler...or Electric heat...make sure that switch is on...otherwise its difficult to give you a more conclusive answer
Nov 11, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Thermostat RTH7400D
The thermostat will not cut off the A/C until the thermometer reading gets to 76.
If there is not a heat source near/behind the thermostat which is causing the thermometer to read higher than actual room temperature, it sounds like the thermostat thermometer is out of calibration.
There are ways to calibrate it, but much to involved to go into here.
One solution is to just set the thermostat at 80, knowing that it's really set on 76.
Another solution is to replace the thermostat.
Charlie
Aug 14, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
