Question about Dewalt Tools & Hardware - Others
Dewalt 703 mitre saw
Cant move the base angle on the saw, can unscrew the knob and the release handle but the base just wont turn
    Problem Solver:
  • 4 Answers
Lorraine - Next to the knob, is there may be a spring that you can pull back towards the knob. If so, after you loosen the knob, pull the spring back toward the knob and hold it while turning the base. If that does not do it, blow some compressed air between the two surfaces and then spray some WD 40 into that gap to lubricate the area.
Posted on Dec 06, 2013
4 Suggested Answers
  • 384 Answers
SOURCE: i have smoke coming from motor of my dewalt dw-708
Stop and unpug it if it hasn't already burnt the house down.
Posted on Aug 05, 2009
  • 384 Answers
SOURCE: What type of mitre saw blade for Pine Casing?
Fine tooth or plywood cutting blade.
Posted on Sep 11, 2009
  • 65 Answers
SOURCE: problem with m y dewalt 704 mitre saw type 1, at first the trigger stuck, and now the saw won't run at all, any help would be appreciated.
you need to change switch,when trigger stuck,2 contact on switch weld ,after no contact at all because of wear
Posted on Nov 20, 2012
Where do I find the release mechanism to raise the blade height
UNPLUG THE SAW
Take some time to determine every function and how each one works.
PRACTICE EACH FUNCTION WITH THE SAW UNPLUGGED UNTIL YOU ARE CONFIDENT THAT YOU KNOW WHAT YOU ARE DOING.
Then, plug the saw in and
PRACTICE,
slowly and carefully on easily handled material.
DANGER - THESE MACHINES CAN HURT YOU!
If you don't know exactly how everything works
DON'T EVEN PLUG IT IN.
Aug 26, 2015 | Dewalt Saws
Mitre saw cod211lsm
Few budget tools and especially generic, brand engineered tools imported from the far east are superbly accurate but tend to be "near enough".
You didn't say whether it is a hand operated mitre saw or a power saw.
Most power mitre saws have a number of stops that can be adjusted or filed in order to calibrate the angles and this process should be done when the saw arrives. Once both 45 degree angles have been calibrated accurately the angles in between should fall into place fairly well.
One problem with low cost mitre (chop) saws, even some so-called professional saws is the construction is so light, when pulling down the handle the machine flexes and spoils the cut. This is especially true when the handle is not set exactly in line with the blade or when not paying full attention when making a cut.
Having experienced such saws I have learned much about them so when I visit a tool store I examine their stock by twisting, rocking and pulling the saw heads and the amount of movement in many new saws of popular brands is disgusting, even some pretending to be premium brands. So far only a few of the most expensive types have impressed me.
That doesn't mean the others are unusable and with care fairly accurate cuts can be made when a suitable technique has been developed - like using a rifle with bent sights...
Nov 27, 2017 | Tools & Hardware - Others
Can't change mitre angle
you need to remove the guide fence with the screws on the back. then you remove the throat plate and there is the bolt is that keeps it all together.
Just took one apart last week, not really difficult
Dec 26, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
I lost my manual and need to adjust the bevel settings
Make sure its a compound mitre and not just a mitre saw. The check in the back for a round knob with degrees marks on it, theres your adjuster.
Sep 24, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
My mitre saw wont lift up into the cutting position it seems stuk
look on the left side of the saw just past the blade there is a knob there pull it out as you hang onto the handle of the saw ,the knob is spring loaded,plus the if you dont hold onto the handle the unit will come up very fast.possible of hurting you or the saw.
Mar 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Why when i cut a bit of 6" skirting board it does'nt cut square on a brand new ryobi ems 2026 sliding mitre saw
Don't ever assume that the markings on the angle setting are correct and accurate. Always check squareness with a square before you use a miter saw. With almost all brands of power tools being built overseas nowadays there is unfortunately a question of accuracy on most brands. Always check.
Mar 16, 2009 | Dewalt Mitre Saw Workstation
I have a makita mitre saw and need to adjust the angle to 45 degrees. I unlock it and try to turn it but it won't turn. Any ideas?
you have to turn the handle, it works like a bolt, you cant see it but it is tied in, you have to unscrew it before trying to move it
Dec 13, 2008 | Makita 10" Dual Bevel Sliding Compound...
How do you adjust the angle of the miter
It should move if you unscrew the handle at the base of teh table. There is also a lever on most of these saws, under the handle. Unscrew handle, operate lever to release locking pin and move. That's the theory anyway.
Oct 24, 2008 | Makita 10" Miter Saw LS1030N
Tools & Hardware - Others Logo
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
