Question about Frigidaire Affinity ATF7000E Front Load Washer
Door will not unlatch after wash
Door does not unlock after wash, my wife has tried to rewash the load 3 times, dooe will not unlock. is there a way to open it manaully?
    Sergeant:
  • 175 Answers
Hi..remove the lower front panel use torx 15,reach up to the
lock and pull down on a ring that comes down below the lock
assembly and the door should open.
try this out..
thank u..
kindly rate my response..
Posted on May 09, 2009
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Lg wd 10490tp door
Is it loked, you know how you have to wait for two minutes before the lock unlocks and you hear a click, then you can open the door. Try a program like emptying the machine, or the program with the lowest temperature and as short as possible. Kolbrun
Sep 19, 2013 | Washing Machines
My lg door will not unlock
this kind of door lock is called PTC door lock.It is designed for protecing you from opening the dooe during the washing and spining cycles which may hurt you.So, if you want to open the dooe during cycles,pls press "stop",then ,wait 2 mins,you will be able to open it by then.the other situation is that,the power is cut off during working cycles,solution is:re-start the washer and directly open the door.Pls note that this kind of lock has to work under power
Mar 14, 2010 | LG WD-12126RD Front Load Washer / Dryer
Washer loader door is locked and i cant open it
this kind of door lock is called PTC door lock.It is designed for protecing you from opening the dooe during the washing and spining cycles which may hurt you.So, if you want to open the dooe during cycles,pls press "stop",then ,wait 2 mins,you will be able to open it by then.the other situation is that,the power is cut off during working cycles,solution is:re-start the washer and directly open the door.Pls note that this kind of lock has to work under power.
Mar 14, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
When i hold the start button, the machine will not begin the cycle
get a chair look behind the washer and unplug the electric cord and then wait a few seconds and plug it back up then do a drain and spin to get the washer to finish gettting the water out so you can get the door open or just rewash the clothes. You may have to try this a few times. My wife has had the same problem and this is what I do to get the washer going again.
Nov 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing cycle has finished but now the lid wont unlock. i have tried pulling the knob out then pushing it back in. i have also tried rewashing the load but now. not only will it not unlock, but it also...
you probably have a faulty lid switch/ locking mechanism. it is all in one. if the machine does not sense that the lid is closed properly, it will not start. you can try unplugging it to see if it will release the lid lock.
Oct 11, 2009 | Frigidaire FWS833A Top Load Washer
Aquarius Hotpoint.. keeps doing rewash after rewash.. door won't open when i switched the washer off its like its trying to either empty water, but making a noise when its trying it.. what wrong and can it...
Unplug First!!!!
You Can Pry The Top Off With A Big Flat Head Screw Driver Where The Seam Meets The Casing.
Then You Can Check The Belt Thats What Is Most Likely Your Problem. Take The Broken Belt To Your Local Auto Part Store And Tell Them you Want One That Size And Replace.
Jan 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I have a Samsung J1043 front loader. The door wont unlock after washing. Help
I rewashed the clothes a couple of times and finally the door released.
Oct 02, 2008 | Washing Machines
Washing machine dooe lock
Try some WD40 on the machine door mechanism, not on the door; & open/close the door while the machine switch is off.
Apr 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
489 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
