Question about E-Machines T2792 PC Desktop
Machine shuts down when loading Windows
Starts up ok, then 20-30 seconds into load, it shuts off. PS is still on. Have to pull plug to reset and try again. If it isn't doing anything with drives, it will continue running.
  • Art Ellison
    Art Ellison May 11, 2010
    Have you tried to boot up without the CDs connected?
    Sergeant:
    Champion:
  • 245 Answers
Hi looks very confusing to me....fist u say pc is running the it turns off.....but also RUNNING....what is running/? is power to ur pc on or off/? as u also say u have to disconnect or pc from the power outlet....looking all this means to meu have a problem with ur powerpac and needs replacing or ur setting is wrong in power option
u can email me on skorpio_2@optusnet.com.au and i may be able to help u more if u give me more details
cheers
Posted on May 22, 2009
LG washing machine shuts off randomly, why?
only suggestion, next time it happens, unplug like you've done and then hold in power button for 15 seconds to see if that resets it.
Aug 30, 2015 | LG WM3470HWA Front Load Washer WM3470HWA
This morning i got a update for windows.. well!! i updated it and then a error screen came on.. i tried to reboot the note book but its stuck in windows boot manager screen.. my lap top wont shut down.....
Boot into safe mode then go to system restore and restore it to before the update or go to control panel and uninstall the update.
To boot into safe mode:
Right after bios loads up and before windows starts loading start hitting the F8 key
Choose safe mode with or without networking doesn't matter
Nov 09, 2009 | Dell Inspiron 1525 Laptop
M9700 starts up but shuts down few minutes after vista loads
Sounds like it is a problem with the m9700 overheating. I have just repaired an m9700 with this exact issue and it was resolved by taking the CPU heatblock off, removing the dried/caked-on heat compound, and replacing it with my own (Arctic Silver 5).
Was 91c before, now down to 74c max on load (Measured with coretemp). Random crashing has stopped.
Sep 03, 2009 | Alienware PC Systems Alienware Aurora High...
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
Sony Vaio desktop will not load windows
what your describing is a hard disk failure the computer cant or wont read the hard disk to boot the machine, so it shuts down. Sounds like the hard disk died from a bad virus. and the computer wont run. Best I can do for you is either format the Hard disk and reinstall the operating system or buy a new hard disk. Cheers
Apr 01, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
Toshiba Satellite A105 problems
Sounds like a program is not loading properly. You should try to load in Safe Mode, And see if it starts properly. If it does you then can do the diagnostics to find which program is trying to load and shuts machine down. You may also try starting in step by step and catch it right away. Depending on your version of Windows you are running you may be able to restore to a previous time when your machine worked right. Good Luck and have a good day.
Mar 08, 2009 | Toshiba Satellite A105 Notebook
Liteon na115 mainboard can't display/load bios
1) Try re-seating the RAM
if it's still the same problem, then the power supply maybe bad.
Try with a good PS.
Jun 17, 2008 | Lite On NA115 Motherboard
The Phaser just keeps shutting down...
That really sounds like corrupted software.There are some procedures you can try, but they will require setting up the network on the printer , so print a configuration page before you do this.
First though. shut the printer down, on the back of the machine is 2 D shaped knobs. Line them up to the edge of the printer then remove the main board. Reseat your memory cards and reseat that main board assebembly. Be sure everything is seated.
Then do memory resets
PS NVRAM AND JUST A NVRAM reset.
Under troubleshooting
Enter service diagnostics then l and reset PS NVRAM as follows: 1. From the diagnostics Main Menu use the UP and Down arrow keys to highlight Print Engine Menu and press OK. 2. In the Print Engine Menu, use the UP and Down arrow keys to highlight Function Menu and press OK. 3. In the Function Menu, use the UP and Down arrow keys to highlight Clear PS NVRAM and press OK This will set the values in PS NVRAM back to factory defaults. 4. Power the machine off for 30 seconds then power on.
Apr 22, 2008 | Xerox Phaser 8400 Laser Printer
MSI K8TNeo2-F v2.0
This is not too uncommon scorcher63.
From what you stated, when windows does start it only goes so far & than re-starts it's self, like loading in a loop. Than at times it loads the start up options.
For reasons unknown, your windows (startup files) are corrupted. Easyest way to fix this is. Put you windows CD in the cdrom, shut down the system. Start the PC & press the F8 key every 2 seconds. A boot menue will load. Use the up & down arror keys & choose the cdrom drive. You will see (to boot from cd press any key), press the space bar. The cdrom will startup. Windows will start to load. You want to repair windows. This option will re-install windows but will leave most of your personal data alone. Like My Documents your username. Some programs "may" need to be re-installed. After installation is complete remove the windows cd & shut off the PC. Start the Pc, windows should load. Run Windows Update. If you have a antivirus program please do a full system scan. Run windows Defrag program.
scorcher63, if you have more question just post them here.
Feb 21, 2008 | MSI K8T Neo2-F Motherboard
E-Machines T2792 PC Desktop Logo
130 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
