Microtek digital inverter 600 va battery charging problem
5 Suggested Answers
Simpsonizer
  • 4 Answers
SOURCE: i have a digital inverter and its not charging the battery now...
Hi! depending on how long you had the UPS the batteries only have a limited life. So lets say you had this UPS for a wile and the batteries are discharged often, the batteries can fail to hold a charge after about three years. If it is likely a year old I would check into the warranty. But three to four years may need replaced and can usually be done by an end user. PS: the inverter may appear not to work at all or just shut down with a bad battery as a safety mechanism. If a new battery or set of batteries does not remedy the problem, then there is a problem with the electronics. If I know the symptom of witch I can help with that as well.
Posted on Nov 21, 2008
SOURCE: Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Posted on Mar 09, 2011
caroldon
  • 17130 Answers
SOURCE: my inverter (500 va) (battery based electric
This a possible failure of the voltage detection circuit in the inverter main board and requires the fault be identified by checking the voltage/current feed/limiter to the battery.
Once when the battery voltage has reached the threshold set up the charging should stop and then the circuit will analyse the voltage on the board to trigger the charging to be put ON.
This can be a failure of the detection circuit and if not checked can damage the battery.
Posted on Jun 20, 2011
SOURCE: Battery back up supply
Fan is not work in his inverter output bt any outher supply presents when fan is work..
Posted on Oct 22, 2013
Microtek inverter 1000w is not charging battery, but battery is ok.
Do you have an input to the charger? If so, check the fuses.
Oct 08, 2017 | Inverter Electronics - Others
How do you adjust the voltage on a 600 ups Microtek inverter ?
Adjust what voltage? Input range? Output range? Need a lot more info, for a useful response!
Apr 18, 2017 | Microtek Computers & Internet
Can i use 150 am 12 va battery with 2000va microtek inverter
You can use any size you want, just your UPS can charge the battery.
You can also add an extra charger in special cases.
If your UPS calculates backup time, you need to tell how big the UPS batteries that you have ...
Aug 19, 2014 | Computers & Internet
Hi, I have Microtek 810 Inverter, it is charging properly, problem starts when mains goes off and inverter is in Battery mode, then output of inverter shows no voltage, even i conected multimeter to...
Good day!
You have to do is:
Check the battery if it is leak.Use a voltmeter to test the output voltage of the battery.If your battery had a low supply voltage even you charge it for 3 hours and above.Replace the battery immediately.
Thank you and good luck.
Apr 21, 2011 | Vacuums
I am using microtek 810. Inverter section is ok. In the pcb there are two 40amp fuse which were blown off. suspected heavy current drainage. both fuses are in parallel and in the battery -ve line. i...
If this is a 12 volt battery situation, 24.6 volts is not doing good things for your batteries--it will buckle the inner plates causing immediate battery failure. Were the fuses themselves blown or just the fuse mounts which may have been underrated. You definitely need a schematic for this system--try googling 'microtek 810'. Good luck!
Aug 15, 2010 | Garden
I buy a new power inverter ERP 2300 12v/220Volts
What does the inverter over 600 Watt.
By what type of battery is the inverter supplied? How many Ah? What is its state?
In order to achieve 1000 Watt for 1 hour you need a fully charged 12 V / 100 Ah lead-acid battery.
If your battery is less then 100 Ah and is not very well charged or old (bad) you may not have over 600 W, but not bacause of the inverter, but the battery.
If your inverter stops due to low input voltage (you can see it in the digital display during operation).
If you want to check the real output power of the inverter you should connect it to a big (more than 200 Ah) well charged battery.
Jul 22, 2010 | PowerBright Power Bright ERP2300-12...
MICROTEK INVERTER HELP
Bad batteries, replace all of them together.
Oct 02, 2009 | Electronics - Others
Jan 17, 2009 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
