Question about Mitchell Fishing
Mitchell blue 6000 manual
Cant assemble the reel right
Where can I get a schematic for the Mitchell 330?
I would ask them direct. Normally you can work it out. Take pictures as you disassemble.
http://www.mitchellfishing.com/
Spinning Reels Mitchell 300 Mitchell
Apr 27, 2016 | Fishing
My mitchell gold series reel will not retrieve line the motion is but the line will not wind around the spool
wrong type of knot at the start perhaps . A small bit of tape usually will fix that .
May 23, 2015 | Fishing
Fishing reel diagrams
I have a Mitchell Avocet 4. I went to take the bail off to lubricate and the spring along with other parts and I need for somebody to show me how to replace those parts.
Jan 30, 2014 | Fishing
AIWA AD-F810 reel torque
If you have a service manual, go to exploded view 3 and look at 31.
This is the FR idler sub assembly. Check the rubber tyre or tire, see if it has hardened. This is driven by the reel motor and flip-flops between the table reel assemblies to drive fast forward,reverse, and play take up.
Also check the reel assemblies for oil that's gone to gunge.
I'm using brass valve oil with PTFE by Denis Wick, That's musical !
Feb 11, 2012 | Audio Players & Recorders
Replace airbag on `92 honda accord
When an SRS cable reel assembly is removed and set aside during vehicle repairs, the cable reel may rotate inside the assembly so it is no longer centered. If the assembly is reinstalled with the reel off-center, the cable can break when the steering wheel is turned to full lock. The cable reel holding fixture locks the reel while the assembly is off the vehicle, keeping it centered for reinstallation.
CABLE REEL REMOVAL PROCEDURE
1. Follow the procedure in the appropriate service manual for disconnecting the battery, and removing the dashboard panels, steering column covers, airbag, and steering wheel.
^ Always install short connectors on the connectors for the driver's and passenger's (if so equipped) airbags.
^ Make sure the front wheels are pointed straight ahead before removing the steering wheel.
2. Verify that the cable reel is centered; the yellow gear tooth is lined up with the alignment mark on the cover. Install the cable reel holding fixture in the cable reel assembly as shown. Use a TORX T-10 wrench.
3. Disconnect the 6-P connector, then remove the cable reel assembly.
CABLE REEL INSTALLATION PROCEDURE
1. Verify that the front wheels are still pointed straight ahead.
2. Reinstall the cable reel assembly, and reconnect the 6-P connector.
3. Remove the cable reel holding fixture.
4. Follow the service manual procedure for reinstallation of the steering wheel, airbag, steering column covers, and dashboard covers.
5. Verify SRS operation as described in the service manual. Road test the vehicle.
^ If the steering wheel spoke angle is not correct, change it by adjusting the tie rod ends. Do not remove and reposition the steering wheel.
PARTS INFORMATION
Cable reel holding fixture:
For 1992-95 Civic and Ohio-produced 1992-95 Accord
P/N 77900-SPO-999, H/C 4733564
For 1991 Accord Wagon, 1992-95
Prelude, 1995 Odyssey and Japan-produced
1992-95 Accord
P/N 77900-SM5-999, H/C 4733572
WARRANTY CLAIM INFORMATION
Use the Flat Rate Manual information for the repair being performed.
Jan 28, 2009 | 1992 Honda Accord
Fishing Logo
41 people viewed this question
Top Mitchell Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a Mitchell Fishing Expert? Answer questions, earn points and help others
