Question about 2000-08 Volkswagen Polo 9w Muranorot Pearl Professional Touch Up Paint
My VW POLO 1.6 clasic keeps overheating I have removed the thermostat no improvement I have replaced the thermostat top rad pipe hot bottom rad hose cold water not circulation replaced radiator still no joy I have replaced engine still overheating I have flushed all hoses and engine and radiator still overheating fans come on but water not circulation throug the radiator what now
  • 528 Answers
Have you changed the water pump - if not, that could be it. Typically cold lower hoses imply water pump impeller not turning.
That would definitely be my next move.
Hope this helps and thanks for using Fixya!!
Posted on Nov 28, 2013
Overheating but ive already replaced the thermostat water pump but still rung hot no water flow circulating need answers .etc
When its cold remove the rad cap, start it up, put your heater blower on full and full heat on, then when the engine gets hot look inside the rad you should see the water flowing. If its not flowing feel the top of the thermostat housing/rad hose it should be nice and hot, it its not your stat is not opening. Are you sure you got the correct temp stat for this car? Was it properly installed and is the system full with no air in it? You can also get a melt stick from your local Napa, making sure its the right temp stick for your car, put it on the stat housing and see if it melts. If it does and you still have no flow either its stuck closed, or its the wrong temp stat.
Mar 16, 2015 | 1999 Cadillac DeVille
Vw polo overheats
a cold hose indicates an air lock in the cooling system, if this is the case have it bled to remove the air lock. it could also be combustion gases leaking into your cooling system indicating a possible head gasket failure, your anti freeze can be tested for traces of combustion gases.
Nov 28, 2013 | Volkswagen Polo Cars & Trucks
I have a 2002 1.4 vw polo overheating. The temp gauge just keeps going up. I have no hot air coming through the vents and the bottom radiator hose stays cold but all other hoses get hot. The car was fine...
It's not likely the thermostat as they tend to stay open when they go bad; but you have no circulation when the lower hose remains cool. Most likely it's too low on coolant for circulation or the water pump is failing.
Apr 21, 2013 | Cars & Trucks
Overheating Polo
this sounds like a thermostat fault, but also could be the sensor switch to the radiator but is more likely the thermostat, it should be located at the front top of engine, follow the top water hose to the engine and you will find the thermostat housing, also just a heads up, these had a problem when first made, according to the known fixes and problems with VW's the hoses corroded inside and started loosing water, this could be wise to get the system presure checked to...hope this helps
Feb 08, 2010 | 2001 Volkswagen Golf
My BMW 318i has had a new expansion tank fitted after overheating and splitting.After bleeding the cooling system it seems as though the bottom hose is not getting hot any suggestions would be welcome
NORMALY THE HOT FLOW ENTERS THE TOP HOSE AND COOLER WATER LEAVE THE BOTTOM HOSE BACK TO THE BLOCK, SO IF THE TOP HOSE GETS WARM THEN THE RAD IS BLOCKED , IF NIETHER GETS WARM/HOT THEN THERMOSTAT NOT WORKING, OR YOU HAVE BLOCKAGE ELSE WHERE, SO REMOVE BOTH HOSES FLUSH RAD WITH HOSE PIPE, (WHEN ENGINE IS COLD) SEE IF WATER FLOWS OUT AT SAME SPEED AS U R FILLING IT, IF NOT ITS BLOCKED, 2ND REMOVE THERMOSTAT AND FLUSH ENGINE OUT, U CAN BUY RAD FLUSH/CLEANER AND TRY THAT,
Dec 05, 2009 | 2003 BMW 330
1990 toyota corolla wagon 1.6 liter 5 spd. overheating
you've got a possible blockage in the head or block.
Oct 03, 2009 | 1990 Toyota Corolla
1994 Honda Civic LX\overheating within 2 mile drive
Remove and raise upper hose at thermostat end and remove lower rad hose.
Fill rad with a hose and watch for flow from bottom rad hose and/ or bottom rad hose connecton.......water should fall though rad easily.
Honda rads are cheap.....any restriction....replace rad.
Remove thermostat....fill thermostat housing with hose and watch for water flow at bottom rad hose.
Flush good.
Remove heater hoses.......flush back and forth until a good flow is present "With heater control set to hot" if no or poor flow....replace heater core.
Stop leak can plug everything.
Also.......not likely causing over heating....but ....at your mileage,if you do not know if the timing belt has been changed.....CHANGE IT NOW!
Water pump is optional at this mileage.
Aug 23, 2009 | 1998 Honda Civic
My car keeps overheating and i dont know why it does not show any problems with the thermostat and i reaches temps of 240 and 255 and runs hot
when the radiator cools of remove the cap on top of the radiator
and check the level make sure is up to full,run the engine and
rich the temp.over 200 check top rad. hose and lower hose, if
top is hot and lower is cool replace thermostat,
May 03, 2009 | 1999 Cadillac DeVille
2000-08 Volkswagen Polo 9w Muranorot Pearl Professional Touch Up Paint Logo
121 people viewed this question
Top OnlinePartsBin Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an OnlinePartsBin Vehicle Part and Accessory Expert? Answer questions, earn points and help others
