Question about Cuisinart Microwave Ovens
Table top halogen oven how to reset it
Goes off on its own after about 10 seconds.brand new oven.
  • 2,113 Answers
All microwaves you need to undo all the screws and replace the fuse just inside where the cord meets the microwave
Posted on Nov 28, 2013
How do I fix e5116 on my Bosch steam combi oven
sad thing brand new items should have a service call made to the manufacturer. if you try to fix yourself it could void any warranty they gave you .
Sep 20, 2016 | Bosch Microwave Ovens
How do I enter a time of less than 1 minute? Bought a brand new Oster Microwave model OGZJ1104. I cannot figure out how to heat up a cup of coffee for example - for 30 seconds. The user manual has
Usually a quick start button along with dial to scroll down from one minute.check if any buttons are push click to see if they extend away from fascia once pressed or try select one minute then use main dial anti clockwise to reduce time.hope this helps.
Feb 01, 2015 | Oster Microwave Ovens
Panasonic genius microwave - not working, timer shuts off in about 10 seconds
It sounds like a bad door switch to me. You need an ohm meter and know how to use it. Checking door switches on microwave ovens can be tricky..
Jan 31, 2015 | Panasonic Microwave Ovens
Brand new microwave never used turns on for 2 seconds then shuts off. Model hmt5750. Callers customer support, they have no idea. Before I call a repairman does anyone have an idea I may try.
Take it back to the place of purchase and demand a replacement, you are covered under warranty. The problem could be caused by a faulty magnetron.
Mar 13, 2012 | Bosch HMT5750 Microwave Oven
Oven only runs for 5 seconds no matter the time programmed in. the power level can be set and it does not matter, the oven runs for 5 seconds and shuts off.
I would need your full model number to help you best, but I'm guessing that at least it's a Panasonic?
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If yours is not a Panasonic, please create a new post with your brand and model number so we can help you.
Oct 10, 2011 | Panasonic NN-H264 Microwave Oven
After 10 seconds oven will go into( see hand book ) in window. model NNA883.
I don't know what the oven goes into but I would guess it requires either a magnetron or invertor board, or both.
Shutting down soon after switch on can sometimes be the result of those items failing.
Feb 21, 2011 | Panasonic Microwave Ovens
Microwave only runs for about 3 seconds.After
Chances are you have a failing magnetron.
But to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "Microwave only runs for about 3 seconds then stops and the timer goes back to the clock mode.After several attempts then it will work.Problem is intermitten"
Dec 04, 2009 | Panasonic NN-S252WF Microwave Oven
Brand new panasonic nn-ct776. When using microwave only goes for about 5/6 seconds and then stops other oven cooking methods works OK.
If it stops after 7 seconds, it has a problem with the inverter.
Plus, since it's new (less than one year old), it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Aug 09, 2009 | Panasonic Microwave Ovens
Brand new.......clicking noise, will only run 2 seconds
Since it's new, I would let Whirlpool cover the repairs.
You can contact their customer service at http://www.whirlpool.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 17, 2008 | Whirlpool MH1170XS Microwave Oven
Microwave Ovens Logo
Top Cuisinart Microwave Ovens Experts
William Miller
William Miller
Lawrence Oravetz
noel
noel
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
