Question about Pioneer PDP-4350HD 43 in. Plasma Television
Pioneer PDP-R04U receiver blinking Help!?!
So i am looking for a solution to my problem with my 50" plasma Tv. It is a 2004 50" Pioneer Plasma with a receiver model number PDP-R04U. Currently the problem i am having is that my receiver is not turning on or setting up at all; no cooling fans running. The red stand by light comes on for about 3 seconds and then the green power light starts too flash in slow intervals of 9 with a brief stop in between. I have read up on what this problem may be but with no result. i replaced the ribbon cables in the receiver directly connected to the mother board as well as replaced the power supply board as i read it could be possible it was a bad power supply. i have hit a wall as to what is wrong with the machine. If anyone can help that, knows quite a lot about this sort of nature it would be very much appreciated. Thank you very much
    Top Expert:
  • Pioneer Master
  • 75,320 Answers
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/ Pull up older posts.
Posted on Nov 28, 2013
4 Suggested Answers
  • 3 Answers
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Posted on Jan 04, 2008
SOURCE: Hi my Pioneer Plasma #
I have this same problem someone help
Posted on Jan 10, 2011
SOURCE: I have a Pioneer PDP-R05G
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
http://www.pioneer.owner-manuals.com/PDP4360HD-service-manual-PIONEER.html
service manual link above,
as an aside here, sometimes things in storage can quickly degrade especially big low value capacitors, these increase in internal resistance, and all sorts of problems ensue, this is why, say, military things are cycled at least weekly when in "Moth balls" to prevent exactly this.
Posted on Mar 12, 2011
My pdp r04u media reciver red and green ligth not blinking only stady lit when i hook up my plazma with laptop i get green light blinking no picture just i want to know what happen my pdp-r04u problem
if this is only with the laptop,, you need to replace your hdmi board if its with the cable
and you receive sound and no picture replace the tcon board. if you dont have neither
picture or sound replace the power supply.
for any parts you can order at tvpartsandmanuals. com
Dec 14, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
Pioneer PDP-r06xe 50 in. Plasma Television Problem. During a Rain Storm - a lightening strike in my loft - the save system it has protect several electronics, but when I try to switch on - the TV it turn...
when switch ON it blinks 7time blue led - then switch OFF by SELF and blinks 8time blue led. Of-course when it switch off by self the TV swap the led from blue to red but the blinking Blue led is on the Receiver (The switcher on the TV is never blinking)
May 22, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
What tv did an pioneer PDP-R05U go with?
Here's a list of Pioneer plasmas using the PDP-R05U media receiver:
PDP-4345HD, PDP-4350HD, PDP-4351HD, PDP-5045HD, PDP-5050HD, PDP-5051HD
Mar 10, 2010 | Pioneer PureVision PDP-5050HD 50 in....
Upgrading media receiver on Pioneer PlasmaPDP-5030HD
You can use a PDPR06U if you can find one for sale its 2 generations later than your's. Look on Ebay. I might have one too but I got to look.
Jan 04, 2009 | Pioneer PureVision PDP-5040HD 50 in....
HDMI inputs on my PDP-R04U are not working
From home set up on remote, choose option, enable HDMI.
Dec 16, 2008 | Pioneer PureVision PDP-5040HD 50 in....
Pioneer media receiver pdp-r04u
try testing dvd player direct to tv dont use uvsal remote go to tv turn it on and change inpput to dvd see it works
Feb 06, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Can I use media receiver PDP-R04U with PDP-436PU display?
You need the pioneer media cables hooked up to the media receiver to the plasma unit itself. each end has 2 different plugs. one has 2 thumb screws and the other is a squeezable end that clicks into place. They MUST be on before you plug in any power what so ever!!!! And yes, other information is being passed through.
C-Dog
Sep 18, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer PDP-4350HD 43 in. Plasma Television Logo
742 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
