Question about One For All URC-3415 Remote Control
I have a gva 22ua2c and its lock how can i hard reset it
I have a GVA 54cm Full HD LED LCD TV Me del GVA22FLEDJ & I can only get channel 9 ! What do I need to do to fix this problem
Do a factory reset, and then re-tune it. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 02, 2017 | Televison & Video
I have a 43in gva and it won't turn on power is fine when I turn it on the screen stays black
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
Dec 27, 2016 | Televison & Video
How I reset the password as I forgotten the password on gva 32 ledf tv
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/. Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Nov 11, 2016 | Televison & Video
Need a remote control for a gva 42inch plasma TV. Have tied to remotes all ready none worked.
http://www.ebay.co.uk/sch/i.html?_odkw=remote+control+for+a+gva+42inch+plasma+TV&_from=R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.TRS0&_nkw=remote+control+for++gva+42inch+plasma+TV&_sacat=0ub5kip
May 06, 2015 | Televison & Video
Correct code for a old gva tv
GVA was Good Guys brand made by Hisense Try code 0208
Mar 27, 2011 | One For All URC-3415 Remote Control
Remote control for gva hgg6830
I do not know who the primary manufacturer of GVA is but I can tell you who sells the brand. I provided a link to the web site. As far as universal remote go I don't think you will have much luck because GVA is what known as a house brand.
Hope this helps.
http://www.thegoodguys.com.au
Aug 24, 2009 | Macally Televison & Video
GVA TV
I have a GVA TV problem with his remote First four minutes it work properly then stop working. Batteries replaced many times still same problem. Give the solution.
Jan 12, 2009 | Televison & Video
One For All URC-3415 Remote Control Logo
24 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
