Question about Home
Turn cartridge type jty026 from top operation to bottom
Fault 41 keeps on coming up when printing
In most cases unseating and reseating the cartridge in the unit to dislodge residue from the cartridge contacts can resolve the problem. If this does not immediately resolve the problem, continue the reseating process up to five times. Follow the instructions below. Unseating and reseating the cartridge Turn the unit on and open the lid or top cover. Remove the cartridges. Re-insert the cartridges. Close the unit's lid or top cover. Cycle the power to the device by turning the printer off for a few seconds. Turn the printer back on. Print a test page. If this does not solve the problem, proceed to the next section. Wiping the cartridge contacts Turn the unit on and open the lid or top cover. Remove the cartridges. Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom (see Figure 2). The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts. The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom (see Figure 3). Re-insert the cartridges and close the printer's top cover. Print a test page. If the problem persists, perform a hard reset as described in the next section. Performing a hard reset on the unit When the printing unit detects an issue with the cartridge, a software flag is set inside the device. This flag may not reset until performing a hard reset on the device Verify that the unit is switched on. Open printer and remove both cartridges. Unplug the power cord from the printer. Wait 30 seconds. Plug the power cord back into the printer. Open the top cover and reinsert both cartridges. Turn the unit on. Print a test page. If the problem persists, the cartridge should be replaced.
Feb 09, 2014 | HP DeskJet 1220c InkJet Printer
Writing tip on pen will not come out when I twist the bottom
Pull up the top of the pen (with the clip). Remove the refill cartridge and examine it. If it is not damaged put it back in and fasten it in place by twisting. The cartridge comes with a colored plastic top. The cartridge must be inserted with the plastic on.That top must not be removed.
Nov 09, 2013 | Cross Century II Classic Ball-Point Pen
Top and bottom screens are white
Sorry for the delay. If the dsi won't turn off when you first get the white screens, hold the power button for 8 seconds. The unit should go off. Take the game cartridge out of the unit and inside that cartridge slot, is a reset button. Using a toothpick or something, press it. Turn the unit back on and it should be fine. Hope this helps :D
Nov 13, 2011 | Nintendo Dsi Pink Console
HP Photosmart 5180 has ink cartridge problem, Says following ink cartridges appear to be missing or damaged.
Solution
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.NOTE:The printer will not operate unless all six ink cartridges are installed Step one: Reset the printer Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.Without turning the power off, remove the power cord from the back of the printer and from the wall socket.Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.Check the printer for the error message. If the error message still displays, go to the next step.Step two: Clean the cartridge contacts Lift the top cover. Figure 1: Lifting the top cover Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch.Figure 2: Unlatching the cartridge 1 Black cartridge 2 - Color cartridges Remove the cartridge indicated in the error message.Figure 3: Removing the cartridge Gather the following cleaning materials:Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.Lightly moisten the swab or cloth and squeeze out the excess moisture.Holding the cartridge by its handle, wipe the copper contacts.Figure 4: Wiping the contacts 1 - Copper contacts Replace the cartridge and then close the latch and the printer top cover.Check the printer for the error message. If the error message still displays, go to the next step.he printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.Step three: Replace the cartridge If the error message still displays, replace the indicated cartridge with a new cartridge.
Oct 04, 2011 | HP Photosmart C5180 All-In-One InkJet...
Cannot find where and how to replace ink cartridges
hi,
  • You have to lift the access panel on top of the printer to view the cartridges at the opening.
  • Press down the top of each cartridge housing to expose them.
  • Turn off the printer.
  • Remove them from the housing.
  • Take the new cartridges and remove the orange tape on top/bottom.
  • Fit the cartridges into their housing such that the words on their top are facing the front of the printer.
  • Close the housing.
  • Press down the access panel to close it.
  • Turn on the printer now.
  • Insert a few papers into the paper tray for the printer to align the cartridges.
  • After the prints,align the cartridges by selecting the clean and align option on properties on the printers program.
Sep 17, 2011 | Canon i 320 InkJet Printer
Replaced ink cartridge still shows ink low needs to be replaced but is printing? Can it be reset?
  1. Remove your current empty cartridge from your Dell printer. Turn on your printer and lift the cover and top half of the unit. You can suspend it in place by lifting the blue plastic lever and securing it to hold up the top of the printer. At this point the ink cartridges should move to the center of the printer and be easy to access. Follow the instructions locate on your printer to remove the cartridges. You can do this by pressing on the blue tab to remove the colored cartridge or the black tab to remove the black cartridge. Once you press the tab, the cartridge cover will pop open. Carefully pull out the exposed cartridge from it’s setting. Save the empty cartridge so it can be refilled.
    Remove the sticker from the newly refilled Dell ink cartridge. Follow the directions on the opened printer to insert the cartridge. Hold the cartridge so the writing is on the top and the ink spot is on the bottom. Gently push it into the opened setting until it is securely in place. Close the cover of the cartridge holder by pressing down on it gently until it clicks into place. Remember that the black cartridge goes into the black setting and the color cartridge goes into the blue setting. Close the top of the printer. You will hear the ink cartridges move back into place.
  2. Test your newly refilled Dell ink cartridge and load your printer with paper.Print a document so either in color or black and white (depending on the type of cartridge you had refilled). Review your printed document to make sure the color is consistent and you are pleased with the outcome.
    Repeat whenever you run out of ink.
Apr 30, 2010 | Dell V305w All-In-One R840635AU InkJet...
How do i insert cadrige
Turn the orinter off and follow these steps:
1) Remove the top cover by opening the top of the printer
2) Pull the older tone cartrige out, taking care of noticing how it is inserted into the printer.
3) Insert the NEW cartridge
4) Close the printer cover
Mar 31, 2010 | Samsung ML 2010 Laser Printer
Replacing ink cartridges
Replacing your cartridge:
  1. Make sure the printer is switched on.
  2. Pull the operator panel forward and open the cartridge access door. (Note: The cartridge carrier moves to the loading position, unless the printer is busy).
  3. Pull the old cartridge forward and then lift it out.
  4. If the cartridge is new, remove only the sticker or transparent tape on the bottom of the Cartridge.
  5. Insert the cartridges into the carrier and push back firmly until they snap securely into place.
  6. Close the cartridge access door and the operator panel.
  7. From the operator panel, press Options to select the cartridges that were changed.
  8. Press Start (Start/Yes), Options to select the cartridge type installed.
  9. Press Start (Start/Yes).
Sep 16, 2008 | Office Equipment & Supplies
Put new ink cartridge and can't install
Won't print black, just color
1. Turn the unit on and open the lid or top cover.
2. Remove the cartridges.
3. Using a clean, dry lint-free cloth (a coffee filter works well),
wipe the cartridge contacts, from the top to the bottom. The contact
4. The contacts inside the printer may also require cleaning. Using a
clean, dry, lint-free cloth, 5. gently wipe the contacts, from the
top to the bottom.
5. Re-insert the cartridges and close the printer's top cover.
Do not use refilled cartridge.
Thanks
Nov 22, 2007 | HP PSC 2410 All-In-One InkJet Printer
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
