Question about Sharp Microwave Ovens
Microwave want continue running.
My Sharp microwave (R409YVA)will power off after running for about 2 minutes. when I unplug and plug back in it will power up after about 1 minute. I never get more running time. It is less than a year old. Is there something I can do?
SOURCE: Fans continues to run.
door switches or control circuit, may be loose contact or open check all wiring and circuit...
Posted on Dec 18, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave won't heat
Sorry my Clarification Request came out as a single blob of a paragraph.
That's not how I typed it. I never write that way!
So I've pasted it here, but as a solution.
Magnetrons generally should last about 2000 hours, but several factors can shorten that.
If it's not OVER ten years old (from the purchase date or the date on the tag inside the unit) then the magnetron is still under warranty.
From the owner's manual:
"For the second through the tenth year from the date of original purchase
"The magnetron tube, if the magnetron tube fails due to a defect in materials or workmanship. During this nine-year limited warranty, you will be responsible for any labor or in-home service costs.
"For the above limited warranty: To avoid any trip charges, you must take the microwave oven to a
General Electric Customer Care® servicer and pick it up following service. In-home service is also
available, but you must pay for the service technician’s travel costs to your home."
GE Customer Service is here, and you can verify the warranty status and find your nearest authorized servicer.
If you're sure the magnetron's bad, it's still under warranty, and you or a friend are handy, they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
It does sound like the magnetron overheated and the magnetron's thermostat opened until it cooled down.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
Since yours is a counter top model, there are less of those factors to worry about.
When you hit Start to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
You can find helpful exploded view diagrams and order parts if needed by entering your full model number from the tag on the oven here.
Let us know what you find out or decide.
Posted on Jul 07, 2009
  • 4088 Answers
SOURCE: Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Posted on Aug 19, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp model R-1871 shuts off every 59 seconds
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 30, 2009
Testimonial: "traced to motor for damper. Would not have had a clue without this information provided by fixya"
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave keeps shutting off
The magnetron is overheating, tripping the thermostat, which shuts off all power until it cools down.
This is usually caused by a blocked air vent, failed internal cooling fan, or failing magnetron.
If it's out of warranty, I'm sure you'll find it's uneconomical to repair, even if you could get parts for this brand.
Good luck.
Posted on Dec 30, 2009
Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Apr 15, 2013 | Microwave Ovens
The switch button is not working..
Hi, kindly unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the problem continues, the touch pad should be replaced asap.
Mar 27, 2011 | Amana RFS18MPS Microwave Oven
Microwave lost all power while running and breakers and fuses are fine.
My maytag just did the same thing. Unplugged everything and let it set for 30 minutes. Just tried it and it came back. Hope you have the same luck.
Nov 26, 2009 | Sharp R-1850A Convection/Microwave Oven
Our GE countertop microwave key pad does not work. The start and clear button does not work. owners mamual jes1651 . unit is 2 years old.
HI. Kindly, unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the error continues, the touch pad should be replaced asap.
Oct 19, 2009 | GE Microwave Ovens
SHARP R-1460 MICROWAVE WAS USING ON A SANWICH IT DID NOT COMPLETE HEATING. NOW HAS NO POWER ON PAD ETC. OUTLET POWER IS OK
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, it will need to be checked. I would suspect the magnetron thermostat, cavity thermostat and fuse.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
It's often more economical to order parts from Encompass here or you can call them toll-free at 866-779-5835.
May 17, 2009 | Sharp R-1460 Microwave Oven
My microwave lost all power.
The plug should be located in the small cabinet above the stove. Leave it unpluged at least for 10 minutes. Mine does it occasionally when it gets hot. I haven't had a problem since I turn the fan on when I run it.
Apr 04, 2009 | Magic Chef CMV1000B Microwave Oven
Microwave won't work
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 22, 2008 | Sharp R-220BW Microwave Oven
Trouble shoot microwave
Also, are any other of your electrical items (light bulbs, DVDs, etc.) failing lately? This could indicate improper power line voltage.
Jul 18, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
My microwave continues to run, (turntable and exhaust), when the door is opened.
all microwaves have 2 safety switches at least... but these are tied to a set of relays that turn it on, my bet is a sticking or stuck relay because you unplug it right and plug back in its not running?-relay ... if always runs driver transitors.
Dec 27, 2007 | Panasonic NN-T990SA Microwave Oven
Dec 18, 2007 | Sharp R-1470 Microwave Oven
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
