Question about Lands Phones
MItel sx50 9104-060-102-SA
This is a hotel phone. When the night button is on normally it will answer all incoming calls with a recording. Now when I turn on the night button the phone just rings and the recording does not answer the calls. Is there a way to reset the phone or that particular function so that when I turn on the night button the recording will once again answer all incoming calls when I press the night button to turn it on? I'm tired of answering this phone.
4 Suggested Answers
SOURCE: receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Posted on Oct 17, 2008
SOURCE: phone won't ring with incoming calls
I just bought a new Uniden DECT 6.0 phone and had a similar problem. It wouldn't ring when plugged into my Linksys voip router, but my old 5.8 GHz did ring. It would get a dialtone and make calls, but when called via an outside line, it would appear as if it was ringing. If I picked up during this "silent ring," it would answer and take the call. It wasn't a ringer volume issue. I called tech support, they said on the main headset, unplug the battery, then unplug power from the base, then unplug the phone cord from the base. Wait 15-30s. Plug the phone cord, then power, then reinstall the battery. Press the End button on the phone. Put the phone on the base for 15-30s. Pick up the phone. Press and hold the Find button on the base. Do this Find thing 3 times. Put the phone back on the base. Wait 10-15 minutes. Then try calling it to see if it rings. Worked for me, finally got it to ring before I decided to return it.
Posted on Jan 13, 2010
SOURCE: landline phone does not ring out when there is an incoming call
incoming calls ringer on corded land line phone no longer works
Posted on Mar 11, 2010
Is phantom calling rooms 1am to 6am there are no alarms set all cleared.
Pull the plug on the whole system for 5 minutes and plug it back in and it will reset its faults.
Jan 04, 2016 | Mitel SX-50 SX50 MS-55 PBX PHONE SYSTEM...
We cant get the recorded message for night mode to change. How is it done?
Here is a link to the user manual for your phone. The directions are very vague about turning off the night mode. They state: To disable Night Answer: • Press the key you programmed to Night Answer.
If you look on page 30 of the manual it tells you how to get into the settings mode. You should be able to go into settings then scroll through the settings to find out which key is programmed for Night Answer. http://edocs.mitel.com/UG/EN/33_5330-5340_UG_EN.pdf
Dec 02, 2015 | Mitel 5340 IP Phone
How do I auto answer using Plantronics Headset (Savi W740) on a Mitel 4250 Phone?
Plantronics makes an adjunct device that attaches to the telephone base (Velcro) and can lift the handset when the button on your headset is pressed. Unfortunately that's the only way to directly integrate the Plantronics (or any other brand) headsets with the Mitel 4XXX series phone. This handset lifter is actually bundled with some of the SAVI headsets, depending on the actual model you get. Separately it's about an additional $50 option. I recall the Plantronics part number is HL-10. Hope this helps.
Jun 19, 2014 | Mitel Lands Phones
How do you auto answer using a Savi W740 Handset on a Mitel 4250 Phone without pressing the Multicall Button?
You neet the Plantronics HL-10 Handset Lifter kit. Sold bundled with certain SAVI models and sold separately for approx $50. Contact your Plantronics dealer else get it from Amazon
Retrieve incoming phone number
Not on a Mitel SS4025, but if it's absolutely mission-critical, your PBX support person should be able to retrieve the call record from the system logs provided you get to them before the buffer overflows. Hope this helps.
Jan 07, 2014 | Mitel Superset 4025 Corded Phone...
Trying to answer call in hotel back office Mitel 5212 phone frm Superconsole phone at front desk. How do we do that?
Attendant Directed Call Pickup
Description
The attendant can perform a directed call pickup from the console. This will permit calls to be retrieved before the recall timer expires or if calls have been transferred to the wrong extension.
Conditions
None.
Programming
Assign an access code to Feature 09 (Directed Call Pickup).
Enable COS Option 218 (Directed Call Pickup).
Operation
• Dial the Directed Call Pickup code.
• Dial the extension number of the ringing telephone - the call is connected.
Apr 24, 2011 | Mitel 5212 IP Phone
Mitel Superconsole 1000 switchboard in a hotel. Shows 1 call waiting and the phone is ringing. Unfortunately, that is not a "real" and if you press the answer key there is no way to answer this...
Do you know if this is on an SX2000 or SX200? If it's on an SX2000, it is a software glitch and requires upgrade to the latest software. As a work-around, you can de-program and re-program the console. It should clear the problem for a while.
Feb 25, 2011 | Mitel LR582906200 MITEL 3000 8-BUTT FULL...
Need to have a Mitel SX 50 Phone System ring on cordless phones
You can switch to "night" mode on the console and the incoming calls should ring on the cordless. try it.
Nov 11, 2008 | Uniden 5.8GHz Cordless Phone
Lands Phones Logo
41 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
