Question about Cell Phones
Scanning to ftp port on utax blue bps901
Download
Can I use Kyocera toner for utax Copy machine?
take the cartridge along to a ink refiller shop and ask them as they have a good knowledge of product inchangeability
Aug 12, 2016 | Kyocera Office Equipment & Supplies
Tip
Bullet Proof FTP Server Tutorial
This is for the BulletProof FTP Server 2.10. However, It should work fine on most following versions as well.
I'm assuming you have it installed and cracked.
Basics 1. Start the program. 2. Click on Setup > Main > General from the pull-down menu. 3. Enter your server name into the 'Server Name' box. Under Connection set the “Max number of users" to any number. This is the limit as to how many users can be on your sever at any time. 4. Click on the 'options' tab of that same panel (on the side) 5. Look at the bottom, under IP Options. Put a check in the box “Refuse Multiple Connections from the same IP”. This will prevent one person from blocking your FTP to others. 6. Also put a check in the 'Blocked Banned IP (instead of notifying client). VERY IMPORTANT! If somebody decides to 'Hammer' (attempt to login numerous times VERY quickly) your server/computer may CRASH if you don't enable this. 7. Click on the 'advanced' tab 8. At the bottom again look at the 'hammering area' 9. Enable 'anti-hammer' and 'do not reply to people hammering' Set it for the following: Block IP 120 min if 5 connections in 60 sec. You can set this at whatever you want to but that is pretty much a standard Click 'OK'
Adding Users 11. Setup > User accounts form pull-down. 12. Right click in the empty 'User Accounts' area on the right: choose 'Add' 13. Enter account name. (ie: logon name) 14. In the 'Access rights' box right click: choose ‘Add’. 15. Browse until you find the directory (folder) you want to share. In the right column you will see a bunch of checkboxes. Put a check in the following ones: Read, Write, Append, Make, List, and +Subdirs. Press 'select'. 16. Enter a password for your new FTP account. 17. Click on 'Miscellaneous' in the left column. Make sure 'Enable Account' is selected. Enable 'Max Number of Users' set it at a number other than zero. 1 for a personal account and more that one for a group account. Enable 'Max. no. of connects per IP' set it at 1
18. Under 'Files' enable 'show relative path' this is a security issue. A FTP client will now not be able to see the ENTIRE path of the FTP. It will only see the path from the main directory. Hide hidden flies as well. Put a tick in both of these.
Advanced: You don't need to do any of this stuff, but It will help tweak your server and help you maintain order on it. All of the following will be broken down into small little areas that will tell you how to do one thing at a time.
Changing the Port The default port is always 21, but you can change this. Many ISPs will routinely do a scan of its own users to find a ftp server, also when people scan for pubs they may scan your IP, thus finding your ftp server. If you do decide to change it many suggest that you make the port over 10,000. 1. Setup > Main > General 2. In the 'Connection' Area is a setting labeled 'Listen on Port Number:' 3. Make it any number you want. That will be your port number. 4. Click 'OK'
Making an 'Upload Only' or 'Download Only' ftp server. This is for the entire SERVER, not just a user. 1. Setup > Main > Advanced 2. In the advanced window you will have the following options: uploads and downloads, downloads only, and uploads only. By default upload and download will be checked. Change it to whatever you want. 3. Click 'OK’
While you are running your server, usually you will end up spending more time at your computer than you normally do. Don't be afraid to ban IP's. Remember, on your FTP you do as you want.
When you are online you must also select the open server button next to the on-line button which is the on-line Button
You also have to use the actual Numbered ip Address ie: 66.250.216.67
Or even Better yet, get a no-ip.com address
on Feb 08, 2010 | Computers & Internet
External display video monitor
On Page 10 of the Operating Instruction Manual
for the Panasonic Toughbook CF29, it shows
the "External Display Port" or VGA Connector
located on the back side with the cover closed.
This port is located approximately in the center
of the back side, just to the right of the
port replicator port and may be colored "BLUE".
The manual can be found here:
ftp://ftp.panasonic.com/computer/om/cf-29htlgzbm_en_om.pdf
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Feb 02, 2014 | Panasonic Toughbook CF-29 Notebook
FTP Privileged Port Bounce Scan is a security problem
I would need more information. I have figured out several deep issues regarding nessus. Such as how to remediate Microsoft Advisory 2974294. Search for MRT.EXE and delete it.
Dec 16, 2013 | Copystar CS-2050 All-In-One Printer
Download scan program
You will need sharp desk, it uses FTP Ports and you will have to unblock these ports in the firewall once installed. here is a link to sharp desk software.
http://www.sharpusa.com/ForBusiness/DocumentSystems/MFPsPrinters/SoftwareApplications/WorkflowAndDocumentManagement/Sharpdesk33.aspx
Feb 11, 2012 | Sharp AR-M207E Black and White Copier
Utax cd 1018 error code C6400
I have problem Utax cd 1018 he said technician call this code C6400
Jan 30, 2012 | Office Equipment & Supplies
I am trying to scan a document on my HP Photosmart 2575 All-in-one but when I press START SCAN - it says NO SCAN OPTIONS
Hi phil4877 ,
Please try re-installing the Drivers and Software for the Printer in the Computer to fix the issue. Also install the Critical Update in the Computer to fix the issues with Scanning.
First, please download the Complete Software and Download package from the below link. After that, please double click on the downloaded file to begin the installation. After installation please restart the Computer for the settings to take the effect.
ftp://ftp.hp.com/pub/softlib/software11/COL31018/mp-76975-1/AIO_CDB_2570_Full_Win_WW_130_141.exe
Once you have restarted the Computer, please download and install the Critical Update from the below link. Please save the file on the Desktop, double click on it to begin the installation. After that, restart the Computer again for the settings to take the effect.
ftp://ftp.hp.com/pub/softlib/software11/COL32261/oj-79942-3/CPE_SCAN_DESTINATION_UPDATE_hpcom_001_003.exe
This should fix the issue.
Hope this helps.
Please let me know if you have any further questions or require any further assistance.
Thanks for using FixYa.
Dec 21, 2010 | HP Office Equipment & Supplies
Utax cdc 1725 printer driver
Download them off their web site.......Click the link below
UTAX.COM
Dec 13, 2010 | Computers & Internet
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
