Question about IBM (2005B16) Ethernet Switch
IBM 2005 16B SAN SWITCH
Hi, We have an old switch installed by a supplier a while ago and that we wish to connect a new tape library we bought. The problem is that no one knows about how the switch were configured. I tried to connect through the console without any success. Made the try with TIA RS-232 straight cable with DB9 connectors => I see nothing on the screen COM port settings are as follow: •Baud: 9600 bps •Data bits: 8 •Parity: None •Stop bits: 1 •Flow control: None
  • 29 Answers
If I were you I'd try to reset it to factory default and then reconfigure it.
The default ip address is 10.77.77.77
Posted on Nov 28, 2013
Testimonial: "Hi Marko many thanks, The big trouble is that someone changed the default IP address and i don't know the new one. Please share if you have another ideia."
  • 2 more comments
  • edson raimundo congolo
    edson raimundo congolo Nov 29, 2013
  • Marko Kmeti?
    Marko Kmeti? Nov 29, 2013
    The switch shuld have a reset button on the back side if you hold it it reverts to the default and so you have the default ip as I mentioned
    This kind of switch does not have the reset button, so i have to do it trough CLI.so as i sayd I tried to connect through the console without any success.
    I have cisco console cable and an USB adapter to connect to my Workstation.
    New Friend:
Did you ever get a resolution for this? I'm having the same problem
Posted on Feb 06, 2015
IBM ts3200 tape library default service password
You will need to contact IBM support and after providing proper I.D. verification , they should be able to give you a password which you will be able to use. Due to security issues with stored info, you will have to provide the proper ID info as the original purchaser. Best Wishes
Sep 01, 2014 | IBM System Storage TS3200 Tape Library...
IBM TS3200 Code 9F 08
The manual is online with IBM.
Chapter 8 explains the error codes and 9F (mean Error code) means Rotation range out of specification 08 9sub error code) means error during rotation initialisation, get range failed.
Then the manual says: "Isolating a library controller card versus accessor enclosure problem" on page 7-11
But I guess you better look it up yourself. If you don't have any parts, you have to contact IBM.
Look yourself? start in chapter 8, page 225 of the manual under this link.
http://publibfp.dhe.ibm.com/epubs/pdf/a320545c.pdf
Feb 16, 2014 | IBM System Storage TS3200 Tape Library...
IBM TS 3100 drive broken
how to repair Tape drive broken ts3100 ibm
Jul 04, 2012 | IBM System Storage TS3100 Tape Library...
HE: drive broken: needs repair
Then raise a call with IBM Hardware:
How do I create a PMR (aka Service Request) for support?
http://www-01.ibm.com/support/docview.wss?uid=swg21507639
Apr 17, 2012 | IBM System Storage TS3200 Tape Library...
IBM embedded security sub system
is this a laptop?
if so tape down the cover switch (this is a mini switch on the mainboard)
Feb 25, 2012 | IBM ThinkCentre M50 PC Desktop
ECM Giotto toggle (power) switch needs replacement ASAP in Seattle area.
i had this happen myself a few months ago, power switch blew, i took the machine apart took out the power switch, and visited a few local electrical component suppliers, its a standard switch but its 2 stage single throw switch, home depot/Lowe's don't carry this type. ended up going to 3 diff suppliers and finally found a commercial supplier that had it connected the new one and now its fine, works better than the old one ever did. just make sure you bring the broken switch with you when you go to show them, most good suppliers can match it and see if they have one like it in stock.
Apr 21, 2011 | ECM Giotto Espresso Machine
IBM TS3200 is a single tape library or multiple?
ibm ts3200 is a single tape library with 2 versions, 2U and 4U, the 2U version support 2 drives HH and the 4U version support 2 FH and 4HH.
Jun 11, 2010 | IBM TS3200 LTO4 TAPE LIB W/ SCSI (3573L4H)...
I am unable to get IBM UlTrium TD4 SCSI device drivers for windows 2000 server
if you "have not" using Backup Software (e.g. Symantec Backup Exec, CA), you can try this IBM LTO-4 driver for Win2K.
IBM LTO-4 Device Driver for Windows 2000
Ned Huang
Tandberg Data Taiwan
Technical Support.
Oct 15, 2008 | Computers & Internet
Error on IBM 3581 tape library.
Error 5 states that there is a problem with the drive and not the library, either the tape path or read/write head. Replaced drive - works fine
Apr 01, 2008 | IBM 3581 Ultrium Ultrium Tape Drive
Not able to access from linux
just restart the server ,it will again connected.
Jan 10, 2008 | IBM DS4300 (25r0168) Hard Drive Array
Computers & Internet Logo
699 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
