Question about Canon CanoScan LiDE 25 Flatbed Scanner
Error in scanner . Turn off scanner and follow instruction in manual,scanner drive will be closed(Error 201)
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Have you tried hooking it up to another computer?
Posted on Nov 28, 2013
5 Suggested Answers
  • 111 Answers
SOURCE: error 201
Which scanner is this? Error (201) usually indicates some sort of power issue...such as the scanner is not getting enough power. If this is a USB powered scanner you may try connecting to different USB ports on the computer.
Posted on May 08, 2008
SOURCE: CanoScan Lide 25 error message
ok, I solved this problem in an unorthodox fashion but it worked... so far that is. First a little history, I was getting this problem constantly and I was at the point where I was going to dump the machine in the trash... therefore I decided to do a little surgery.
Solution: I ripped off the plastic sides of the scanner and lifted the glass from the front while it was still in the back of the machine. I started to try to scan. After doing that I received a different error. After that error I replaced the glass without the plastic sides and it scanned with no problem. It works for me and it has worked since. Unorthodox? Yes it is, but when I forced a different error and forced recognition. I believe this is a software problem and not a hardware. Good luck to the rest of you. Any questions, I'll try to reply.
Posted on Aug 29, 2009
  • 736 Answers
SOURCE: By Massoud on Mar 28, 2008
if that scanner is powered by the USB port .. you might want to try a different port or a powered external port .. sometimes some USB ports cant supply enough power ..
Posted on Dec 23, 2009
  • 126 Answers
SOURCE: Error in scanner.
This error can be caused by many different issues. Try the following resolutions in order until your issue is fixed-
1. You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
2. unistall and re-install drivers-
1. Place the CanoScan Setup CD-ROM into the CD-ROM drive.
2. When the CanoScan Setup Utility menu appears, click the option to 'Uninstall the Software' and then follow the prompts.
3. Disable Third-party Software
Software applications that are active during installation can cause errors, installation difficulties and even abort the installation.*1 Close all running applications, including anti-virus programs, before installing Canon Software. You can also prevent these applications from starting through 'System Configuration Utility' (also referred to as 'msconfig') in Windows 98/Me, Windows XP and Windows Vista.
If your computer is part of an office network: Network permissions, security software, etc. may be interfering with proper communication. Please contact your System or Network Administrator before attempting to disable software on your system.
a. See your applications' documentation for instructions on how to close it.
b. If you are unable to locate the documentation or the application appears to be running after it is closed, disable the startup items in the Windows 'System Configuration Utility'.
c. If disabling startup items in 'msconfig' does not correct the issue, disable non-Microsoft related services in 'Services' tab of 'System Configuration Utility' window.
d. Attempt to install the Canon software (drivers). If the drivers were already installed, uninstall them (keep the third-party software disabled) and then reinstall the drivers.
e. After installation is complete, set 'msconfig' back to 'Normal Startup'.
//javaftper
Posted on Jul 31, 2010
If I try to scan or copy some files, it writes me: 'Error in scanner and follow instruction in manual. Scanner driver will be closed.(Code:201)'. Please help
copy and paste the link below to your browser...
http://www.google.com.ph/search?q=CanoScan+3000F+Flatbed+Scanner+code+201&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Mar 01, 2011 | Canon CanoScan 3000F Flatbed Scanner
Error in scanner. Turn off scanner and follow instructions in manual.Scanner driver will be closed. (code:201) Unable to open TWATN source Please check connection Then re-start Toolbox.
//javaftper
Jul 31, 2010 | Canon CanoScan 3000ex Flatbed Scanner
By Massoud on Mar 28, 2008" " When i try to snan ,i come up with a aignal"Error in scanner . Turn off scanner and follow instruction in manual,scanner drive will be closed(Error 201)
Dec 23, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Can't find "cartridge error 50C" in my Dell owner's manual
Cartridge Error 50C
Cartridge Error
Aug 13, 2009 | Dell A940 All-In-One InkJet Printer
Jul 24, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
MP800R: Error code:201 - Printer can print but not Scan!MP800R: I can use the printer for printing al right, but when I try to scann I get a message that I should close the printer, and read the manual...
Error code:201 occurs due to USB conflict or software not running properly....
Solution#1: Take out the scanner from USB port... shut down the computer.... then restart the computer and plugin your USB plug in anyother USB port(not the ealier one).. Then check if that works.
Solution#2: Click on Start > Click on Run > Type Services.msc press ok.... on the services window check for "Still Image Service" right click on it and select properties .. then click on stop then start(if it is already stoped then click on start).... also make sure the Startup Type: Automatic....
Jul 17, 2009 | Canon Office Equipment & Supplies
Please rate!!
Jul 17, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Error 201
Mar 28, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
CANON 3000F
If you are runnnig XP or Vista this will happen
Go to Start/Programs/Accessoris/System Tools/Compatability Wizard
Reset the machine for Win 98
Mar 20, 2008 | Canon CanoScan 3000F Flatbed Scanner
Canon CanoScan LiDE 25 Flatbed Scanner Logo
105 people viewed this question
old marine
old marine
