Question about Masterbuilt Turk-'N'-Surf's Turkey Fryer
Will not come on
Plugged in power is on but will not turn on button does not work
  • 2,113 Answers
Duplicate
Posted on Nov 29, 2013
How do I turn my toshiba satellite radius p55w on if it's fully charged and the power button isn't working?
try holding power button in for about 50 seconds. Then try pressing power button again. Could be locked up. make sure no other display screen is plugged into laptop. make sure nothing plugged into USB port at boot up.
Aug 04, 2014 | Computers & Internet
My 7" android sky wi fi tablet won't switch on
Will it turn on while plugged into the wall charger? If so, you may have a battery issue.
Try holding the power button to power one while plugged in, if that does not work, press and hold the power button and volume down button to see if it will turn on.
Jul 24, 2014 | Tablets & eReaders
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
My Nextbook wont turn on
Although it is not recommended for normal operation, try turning it on with the charger plugged in. If this works, check the battery status indicator. If it shows a full charge, try disconnecting the charger. If the Nextbook quits working, the battery is bad.
If it does not turn on, try holding the power button for five seconds, then while holding the power button on, plug in the charger and continue holding for five seconds. If nothing happens, release and press the power button again with the charger still plugged in. (This may reset the internal power management chip.) Also, try the recessed reset switch (see your owner's manual).
If none of this works, verify that the charger unit is good. The simplest and safest method is to measure the output voltage on the output plug with a digital multi-meter while the charger is plugged into an AC outlet. It should be within 5% of the nominal output voltage on the charger label.
The most common power problems are battery failure, broken charger wire (usually next to the plug or the power conversion box), or broken charger jack in the unit.
Jan 10, 2012 | Office Equipment & Supplies
Is there a way i can turn on my pantech jest without using he power button because the power button wont work due to water damage.
I accidentally dropped my phone in water and then the power button (red) wouldn't work. But then I took out the battery, plugged it in the charger, and then replaced the battery while it was still plugged in. It worked!
Nov 10, 2010 | Pantech Cell Phones
Canon pixma IP2000 not starting
dear,
uninstall the software of your printer and reinstall it...hope it may work.
thanks.
Jun 16, 2009 | Canon PIXMA iP2000 InkJet Printer
Had my laptop plugged in overnight. I turned it on
try to press the power button for more than 10 seconds and try to power it again
Jun 08, 2009 | Acer Aspire One PC Notebook
Computer won't turn on though plugged into wall
Make sure you have power at the outlet. Take power cord off and remove battery. Hold power button down for 10 seconds, plug just power cord. Try to turn on. If dose not work , you have a hardware issue.
Apr 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Whirlpool Duet HT
Mine just did the exact same thing. I unplugged it, then plugged it back in, and it worked perfectly. Good luck!
Dec 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Masterbuilt Turk-'N'-Surf's Turkey Fryer Logo
78 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
