Question about GE JVM1650 1000 Watts Microwave Oven
Daewoo koc 180k how do you change the bulb - GE JVM1650 1000 Watts Microwave Oven
Daewoo koc-985t bi - Not heating food equally. ie. middle of food cold. Sometimes food takes double the time to warm.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 18, 2011 | Daewoo KOC-925T Microwave Oven
How do i change the bulb lamp on a Daewoo KOC-875TSL microwave
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Jun 07, 2009 | Daewoo KOC-925T Microwave Oven
Manual for Daewoo KOC-985T Microwave cooker required please. HAVE BEEN GIVEN COOKER IN NEXT TO NEW CONDITION, BUT NO INSTRUCTION BOOK
I have the manual with me.
Can u help me in return, who can do repair for this model KOC-985T; and where the spares are availble?
Contact me at prabirjose@hotmail.com
Feb 28, 2009 | Daewoo KOC-925T Microwave Oven
Daewoo KOC-1B0K no interior light and turntable not rotating
Looking at the service manual at our site, that would be a failure in the "motor relay" (relay 4) or one of the components that drive that relay, such as transistor Q8.
The part numbers for this relay are OJ-SS-124LM (generic) 5SC0101405 (Daeweoo).
Jan 27, 2009 | Daewoo Microwave Ovens
Where in Sydney can I purchase a replacement lamp for a Daewoo KOC 984 Microwave oven.
Normally a grocer or department store or hardware store will sell replacement bulbs of this type.
You can take the old one with you.
Otherwise, try:
Daewoo Electronics Australia PTY. Limited. (DEA)
Unit Q5, Regents Park Estate Princes Road East, Regents Park NSW 2143, Australia
Tel: 61-2-9738-5111
Fax: 61-2-9738-5511
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 25, 2008 | Microwave Ovens
Daewoo KOC-985T - Help me find manual!
http://www.2instructions.com
Jan 08, 2008 | Microwave Ovens
Need a service centre
Can u suggest a service center for a daewoo microwave oven at bangalore. I wanted a glass turntable for my daewoo microwave oven. I wanted its telephone or contact number.My daewoo mocrowave oven MODEL NO.KOC-8H4T. Pls reply soon
Dec 09, 2007 | Microwave Ovens
GE JVM1650 1000 Watts Microwave Oven Logo
48 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
