I'm running Windows Vista and PC Suite version 7.0.8.2 fails to open up due to the following message: 'This application has failed to start because ConAPI.DLL was not found. Reinstalling the application may fix the problem.'. I have re-installed several times and the same error message occurs. This started happening after I installed some other software but I'm not sure which, as I am building my new laptop and am installing a lot of software. It might have been Quicken 2008 but I'm not sure. A Google search for this issue reveals that possibly Adobe software might be the culprit. I do have Adobe Photoshop Elements and I did move the NokiaManager.mox file out of that product as recommended by others, but this didn't fix the problem. I also uninstalled 'PC Connectivity Solution' in order to try to fix the issue, since that software contained ConnAPI.dll (which I presume is also from Nokia and I'm not sure what installed that.) After uninstalling PC Connectivity Solution and reinstalling Nokia PC Suite, I got the same error. This time, I believe ConnAPI.dll is not on my system and clearly Nokia PC Suite did not install it even though it requires it! I could switch to some other connectivity software but I have Lotus Organizer and want to sync. with that and I don't believe anything else syncs with Lotus Organizer these days. Has anyone else had this problem, and if so, what is the solution?
    New Friend:
  • 32 Answers
Just download connapi.dll here Download connapi.dll and try to install it.
Posted on Nov 29, 2013
    Problem Solver:
  • 3 Answers
Hi there...
I had a similar problem with .DLL error messages. This is typically something going in the start up menu system of your computer. I used a program called RegCurePro and is very simple to install and run. Once it completes its first scan, find the "ConAPI.DLL" in the list, right click and delete it. Should be fine from there on out....
Posted on Nov 28, 2013
4 Suggested Answers
ryanb006
  • 48 Answers
SOURCE: odd application failure... missing assembly?
Mark,
Do you have the Visual C++ 2005 Redistributable installed? The "Dependent Assembly..." error indicates that you do not have it installed yet. You can download it at the link below. Please report back with your results.
http://www.microsoft.com/downloads/details.aspx?familyid=200b2fd9-ae1a-4a14-984d-389c36f85647&displaylang=en
Ryan
Posted on Mar 23, 2009
  • 205 Answers
SOURCE: .Net Framework 1.1 sp1 Install Fails
You need to uninstall and install the latest version of .net frame work
You can download it from www.microsoft.com/downloads
Posted on Apr 15, 2009
  • 4961 Answers
SOURCE: Need help with missing libgimpui-2.0-0.dll file
The problem is you didn't completely uninstall Gimp before you installed it again so the Gimp install file got confused when it found some residual files or registry keys from a previous install and thus it skipped installing some files (libgimpui-2.0-0.dll was one of them for sure) You need to completely uninstall Gimp before you can install it again properly. Get a copy of Revo uninstaller from the link below and use it to uninstall Gimp for you. You should be good to go after that.
Revo Uninstaller 1.94 Link:
http://majorgeeks.com/Revo_Uninstaller_d5706.html
Posted on Jun 15, 2012
The application will not open in windows 10. Uninstalled it, removed folders& regkey entries.Installed clean version. Installation went fine. However the application it self will not open.
According to the software release notices, it wasn't until version 7.0d that they made it Windows 7 compatible. You aren't saying what OS you are migrating from, but it may be that you are running too old a version of the program. You could try one of two other options.
  1. Try running the program as an administrator. Right click on the program icon and select "run as administrator".
  2. Try running in compatibility mode for the OS you were using it with previously, right click on the program icon and select the "properties item". Then click on the compatibility tab and use the pulldown to select the OS to simulate the program for.
If they both fail to work, you may have to upgrade to a newer version. Many older applications stopped playing nice starting with Windows 8. Many of them actually worked if you loaded VISTA drivers and/or compatibility, but not all. Most Windows 7 and later software has no issues with Win10.
Oct 02, 2015 | Sony ACID Pro 7 for PC
Tip
How to solve Adobe "Licensing for this product has stopped working" errors ?
Solution No 1
Set the FLEXnet Licensing Service to Manual and Start the service
  1. Choose Start > Control Panel.
  2. Double-click Administrative Tools.
  3. Double-click Services.
  4. Double-click the FLEXnet Licensing Service to open the Properties dialog box.
  5. Click the Startup Type menu, and then select Manual.
  6. Click Apply.
  7. In the Services Status section, click Start to start the service.
  8. Click Apply, and then click OK.
  9. Close all open dialogs.
  10. Launch your Adobe application.
solution no 2
Rename the FLEXnet folder to FLEXnetold in the following locations:
  • On Windows XP:
    C:\Documents and Settings\All Users\Application Data\FLEXnet
  • On Windows Vista or Windows 7:
    C:\ProgramData\FLEXnet folder
on Feb 19, 2010 | Adobe Creative SuiteĀ® 3 Master Collection...
How to fix software problem in nokia 5130?
If you use a PC, Nokia Ovi Suite can check your phone's current software version and download new versions when they become available, using your PC's internet connection.
Nokia Ovi Suite also helps you to back up your contacts and photos, synchronise your calendar and update other applications such as Maps.
To update your phone's software using Nokia Ovi Suite on your PC:
On your PC, open Nokia Ovi Suite and connect your phone In Nokia Ovi Suite, select Tools > Software updates. From the list of available updates, choose what you'd like to install. It's free to download and use Nokia Ovi Suite. It runs on Windows 7, Windows Vista and Windows XP.
Note: If you're a Mac user, you need to update your software from your device as Nokia Ovi Suite is not available for Mac OS.
or
go to Menu > Settings > Phone > Phone Updates. search for updates on phone and follow onscreen instructions to update.
Oct 30, 2011 | Nokia 5130 Cellular Phone
How to update nokia 3110cmobile
Oct 29, 2011 | Nokia 3110 Cellular Phone
I am having trouble with Microsoft Office Home and Student 2007
This article describes how to troubleshoot problems that you may experience when you try to activate a 2007 Microsoft Office application. Additionally, this article contains several methods that you can use to troubleshoot activation issues.
This article is intended for a beginning to intermediate computer user.
You may experience the problems in the following scenarios:
Scenario 1
When you try to activate a Microsoft 2007 Office suite, you may experience one of the following symptoms:
  • You receive the following error message:Your software cannot be activated because the product key you installed with is not valid. Please uninstall the software and reinstall it using a valid product key.
  • The activation process fails. Additionally, you receive a message that states that you have reached the limit on the number of computers on which you can activate the 2007 Office suite.
Scenario 2
When you successfully started a 2007 Office application and all functions worked correctly for you in the past, you receive an error message. The error message indicates that significant changes were made to the configuration of the computer. In addition to this error message, you may also experience any of the following symptoms:
  • When you try to activate the 2007 Office suite, the Activation Wizard disappears.
  • When you try to to activate the 2007 Office suite over the Internet, you receive a communications-related error.
  • When you try to activate a 2007 Office suite , the Activation Wizard does not start. Additionally, you receive no error messages.
Scenario 3
You try to activate the 2007 Office suite over the phone. However, after you enter the confirmation ID that the support staff supplied to you, you receive an error message. The error message states that the confirmation ID is invalid.
Scenario 4
When you successfully started a 2007 Office application and all functions worked correctly for you in the past, the 2007 Office application now runs in a reduced functionality mode.
Scenario 5
When you start a 2007 Office Trial version for the first time after you complete License Activation, the 2007 Office Trial version runs in a reduced functionality mode, and the Office Activation Wizard is displayed. Additionally, the following text is displayed:
2007 Office system is expired. In this expired state, many features of the version are unavailable until you convert to the full product. Click Convert to begin the conversion process.
Note This activation problem indicates that the Opa12.dat file is corrupt for the 2007 Office application. Scenario 6
When you try to obtain an activation key for a trial version of the 2007 Microsoft Office system over the Internet, you receive the following error message:The Microsoft Activation Assistant was unable to request your trial activation key
This issue is temporary until the updated version of Try Microsoft Office 2007 is available. Microsoft is in the process of updating Try Microsoft Office 2007 based on the January 2010 update for Office Word. For more information, click the following article number to view the article in the Microsoft Knowledge Base:978951 Description of the January 2010 update for Office Word
Oct 26, 2011 | Microsoft Office Home and Student 2007...
Create a card gold fails to run on windows 7
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 05, 2010 | Broderbund American Greeting CreataCard...
Software incompatible window 7
Step by step instructions for Windows 7 32-bit follow:
Insert the Panasonic CDROM.
Don't use autorun - Cancel autorun popup.
Right click on CDROM drive in "My Computer" and select 'Open'.
Right click on Setup application & choose 'Troubleshoot Compatibility'.
Select 'Troubleshoot program'.
Select "The program worked in earlier versions of Windows but won't install or run now' & click
the "Next" button.
Select 'Windows Vista (Service Pack 2)' & click the "Next" button.
Click on "Start the program..." button.
Proceed with program installation.
When installation finished cancel out of the 'Program Compatibility' window.
If you have Windows 7 64-bit the instructions are:
Insert the program CDROM.
the "Next" button.
Installation will start.
VideoCam Suite will probably be flashing on the taskbar so select it.
The window will show: 'This application does not support this 64-bit operating system. Are you
sure you want to install?'
!!! Click the "Yes" button !!!
Dec 28, 2009 | Panasonic SDR-H80 Hard Drive Camcorder
Cannot connect my LG Viewty to the computer via the LG PC suite
hey.. if u connect ur phone via usb, be sure that ur phone is in home screen, because if not, for example if you connect your phone and you're in your message menu then you will open some apps in your pc suite the message will appear saying 'Fail to connect to the mobile handset, Please check the COM port and connect in idle screen. Due to the multifunction, despite idle screen, it can be failed to connect' now try it by connecting the phone but in home screen mode.. gotcha buddy?? hope soo..
Apr 13, 2009 | LG KU990 Viewty
Side-by-side configuration
The "side-by-side" component is associated with the Vista Windows Resource Protection (WRP). You may have a corrupted file in the SxS folder.
To resolve this issue, use the System File Checker tool (SFC.exe) to repair these files.
To do this, follow these steps:
1. Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as Administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow/Continue.
2. Type the following command, and then press ENTER:
sfc /scannow
(The sfc /scannow command scans all protected system files and replaces incorrect versions with correctMicrosoft versions.)
This may take some time to run, so be patient.
Hope this fixes the problem.
Apr 07, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
David Payne
David Payne
