Question about Daewoo KOR-1B4H Microwave Oven
HAVE REMOVED COVER BUT CANT SEE BULB
THERE IS ANOTHER COVER ON TOP IS THE BULB BELOW THIS
  • 2,113 Answers
I don't know your model but where the light previously was coming through a lens either remove the lens and replace the bulb or remove a square panel just opposite it on the side of the microwave to replace the bulb.
Posted on Nov 28, 2013
How to replace burned out light bulb
You need to remove the top cover to access the bulb. That is the only way on most microwaves.
Dec 02, 2011 | Emerson MW8107WA Microwave Oven
Light bulb has gone, can't see where it is located or how to change the bulb
Do as follows. Do not connect the microwave oven to mains while doing the following activities. Even the accidental switching ON will harm you from the microwaves. Open the top cover by unscrewing side screws & the screws at the back. Lift the top cover by tilting upwards from rear end. Remove the wave guide of magnetron & there you will find the bulb. Wave guide is rectangular small ducting (pipe enclosure) to guide the microwaves from the magnetron.
Sep 17, 2011 | Microwave Ovens
I did as it said and removed the cover but I cant find the light fixture so WHERE IS THIS LIGHT BULB ?? I CANT FIND IT !! please help
take the lid off u should have a plastic cover covering the bulb ..see inside were it lights up then look were it is under cover. it will have a black housing or white. also a screw holding it in ..PLEASE MAKE SURE U UNPLUG UNIT B4 TAKING COVER OFF...
Feb 23, 2011 | Sharp Microwave Ovens
How do i change the bulbs on a jvm1870sk03 microwave
That's covered on pages 35 & 36 of the owner's manual here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug. *
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
* If your control board was damaged (lights won't come on, won't go off, fan or turntable not working right) after a cooktop light bulb blew or was inserted or removed while power was on, see here.
Apr 25, 2010 | GE JVM1870 Microwave Oven
Light bulb replacement
the light bulb is usually in cavity behind the control board.to access that first remove the outer cover of the unit by removing all screw at the back.after removing the cover u will have access to yhe cavity behind the cntrl board and the light bulb.....good luck.
Aug 19, 2009 | Emerson MW8168B Microwave Oven
Replace light bulb in a microwave
Normally the bulb is located inside the microwave and to replace you will need to diassemble the cover using a philips screwdriver(most likely a philips one), then once the cover is removed you will see the bulb right away.Be careful to disconnect electricity supply to it.Also the whole cover has to be removed..where there is a vent on top etc..that is the one.Again careful with it as you could end up with electric shock.
Jul 04, 2009 | Microwave Ovens
Replacing bulb for microwave
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You should be able to download your owner's manual from Panasonic.net by choosing your region & country, then Support.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Jan 03, 2009 | Panasonic NN-2505A Microwave Oven
Replacing interior light bulb for ge spacemaker xl1800
If it's an over the range type, remove the vent grille across the top to check if you can access the bulb fromthere. There may be a panel on the bottom covering the light(s), instead.
you may have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy,
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
hope this helps dont forget to rate this
Sep 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
BULB NOT WORKING ON MY KENWOOD GRILL/MICROWAVE GJ/SS25
First unplug microwave. Check to see if there is a cover in front of the bulb that can be removed with a screwdriver normally philips. If not, you must remove the entire top cover for access to the bulb housing.You will have to remove side screws if any, and just the rear screws that hold the top cover on, remember you may find that some if not all may be torc screws.In this case you will need the correct tool.Usually a T20 tamper driver.After you remove the top cover you can find where the bulb cover is and replace the bulb.CAUTION:ALWAYS BE CAREFUL TO KEEP HANDS AWAY FORM THE HIGH VOLTAGE SECTION. Sometimes the high voltage capacitor will not discharge on its own and will retain voltage plugged in or not.
Nov 01, 2007 | Microwave Ovens
Is the Advantium Mod: SCA1000HCC03 the same as the SCA1001SS?
They are indeed the same bulb, a 10W halogen. Care must be taken not to touch the lamp, as the oils from the skin will shorten its life. In many recent models, the oven must be removed from the wall (a two-person job due to safety concerns) and the cover must be removed. The manufacturers consider this a "technician-only" type job to lessen their liability. You can find helpful exploded view diagrams of both ovens and order the bulbs here: http://tinyurl.com/gv383
May 03, 2007 | GE Advantium SCA1001SS Convection /...
Daewoo KOR-1B4H Microwave Oven Logo
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
