Portable provence gas heater wont ignite - Heating & Cooling
5 Suggested Answers
  • 101 Answers
SOURCE: Pilot light will not stay on my provence gas
first thing to do is make sure you got gas? figure you know that so here we go.
where the gas comes out for the pilot flame. use a pipe cleaner and run it down in it about 2 or 3" .
sometimes a spider web will block the flow of gas and it's not enough to heat the probe that keeps the pilot flame lit. or the flame sensor is bad. it's rare to have the sensor go bad but it can. a can of air and blow it out good is always a good thing. Good luck. always be careful.......
Posted on Jan 07, 2011
SOURCE: Dayton 3VE59 Gas Utility/Portable Heater won't
Just repaired one of these, problem was that main gas valve was not opening, valve is controlled by a vacuum switch, vacuum is created as fan blows air down tube past bent up metal flap near front bottom of heater (slight low pressure zone created). If vacuum switch is miss adjusted it will not close when fan is running and no gas flows. this is easy to check as vacuum switch also has a pressure port on it. With gas disconnected, remove bottom cover, locate vacuum switch (it has a hose clear plastic hose connected to it, in opposite corner is another hose connection, attach a length of hose to it that you can blow lightly into. With heater plugged in and no gas connected (USE CAUTION OF WIRE!!!), turn heater on you should hear after a few seconds the ignition and then a loud click as the gas valve opens, if no click blow lightly into end of your added tube, if you now hear a click the gas valve just opened. if you stop blowing you might hear the gas valve click again as it re-closes. If this is the case the vacuum switch needs to be adjusted slightly. THIS switch is hear for your safety, Adjust at your own risk!!! This can be done with a screw drive in the top, rotate screw slightly while checking if the fan alone causes enough vacuum to make the switch work. DO NOT over adjust. check safety operation before hooking up gas by placing a piece of cardboard or wood over the air intake and the exhaust to block airflow, if the air flow is blocked you should hear the gas valve drop out and reconnect as air flow is reestablished. Hope this helps
Posted on Feb 13, 2011
  • 4736 Answers
SOURCE: our delonghi portable gas heater's
The problem you described can be caused by 3- things. A dirty pilot, a failed thermocouple or thermopile or low gas pressure.
Cleaning the pilot with a can of compressed air with a straw nozzle (like to clean your computer with) will take car of the dirty pilot. The two other things, may require a service technician depending on if you's handy or not with tools and familiar with gas heating products and can get the necessary parts.. The low gas pressure situation is definitely a job for a pro.
Posted on Apr 08, 2011
Nomadfeet
  • 59 Answers
SOURCE: I recently bought a Provence
New burners need to be run for a bit to burn off factory oils and the like for a bit (making sure of good ventilation in the house first). If this has been done and your smoke detectors are also carbon monoxide detectors turn the unit off and call a service tech before continuing use.
Posted on Sep 25, 2011
How to get rid of yellow flime in gas heater Provence.
yellow flame is lack of air . So burner needs cleaning or appliance does Yellow flame causes soot and co2 so needs to be sorted asap best turn it off until sorted out.
Dec 10, 2017 | Heating & Cooling
VERY GOOD "spark" HOOKED UP YOU CAN SMELL THE GAS WHEN YOU HOLD THE BUTTON IN IT WILL IGNITE THE GAS WHEN THE FAN OFF BUT DOES NOT
Possible weak gas flow to igniter may require adjustment, have a qualified gas technician check it.
press the helpful button
Jan 08, 2016 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
I recently bought a Provence Calor Gas Stove for the house. The portable heater type. It is brand new but every time we switch it on, all of the smoke detectors in the house go off. Whats up with that?
Sep 25, 2011 | Heating & Cooling
Pilot light will not stay on my provence gas heater at any setting
Jan 07, 2011 | General Heating & Cooling
I have everything hooked up on my heater and nothing is coming out of the heater and it wont ignite
There is a plate with 4 screws in it on the bottom of the heater. Take it off and make sure you have it set for ng (natural gas) if you are using natural gas.
Dec 19, 2010 | The Companion Group Kozy World Portable...
I have an empire corcho model 15-1. It will not light with the ignition button what are the possible problems? LP gas is to the unit.
ignition out of postion , it needs cleaning , end of ignition brunt off or too short, blocked pilot, ignition shorting out on heater causing short spark
Nov 28, 2010 | Reddy Heater RLP100 Portable Forced Air...
Propane heater wont stay running
is the sensor for the thermocouple located in the right spot in the flame,remove it and if you have access to a propane torch,heat the end till its red hot and leave it connected to the gas valve,then start the unit and this will tell you if the sensor is properly positioned in the pilot flame on the unit itself,if not you could have a defective new thermocouple or another safety device keeping it from staying lit or the gas valve is faulty
Jul 28, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
My coleman karosene heater won't work
Hi
Change the sparkplug with the same heat range.Clean the air filter and the gas filter.Change the gas from the gas tank.Disassembly the carb and clean it.Start the engine.
best regards savumihai71
Dec 22, 2008 | Coleman Powermate Premium Plus 6250W...
Heating & Cooling Logo
1,345 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
