Question about Kitchen Ranges
I cannot get the oven to turn on after a power outage
  • 54 Answers
Change the power socket, if still persist get a technitian to check it, the outrage may have messed it up.
Posted on Nov 28, 2013
Ovens work fine . .ONCE ! Then buttons do nothing until you turn off the wall breaker for an hour. Then the oven works ONE time again.
Tom Sh, you own every kind of appliance, or you are attempting to be a repairman with free advice from Fixya?
Replace the touchpad. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Ovens Ovens
Beko built in double oven alarm after power outage
Switch oven on using the function knob (first knob on left hand side)then press and hold(for 3 to 5 seconds) the left top button right next to the display screen this should give you a chance to set the current time on the oven after setting the current time switch oven off at function knob and on agian problem should be solved
Jul 05, 2015 | Ovens
Power interruption and now my plug,n go seems to be frozen. Cannot set time or clear anything. Screen reads 9.80 or something close
I had a similar problem with my Bosch wall oven after a recent power outage-restart-outage-restart cycle that lasted only about thirty seconds altogether. The difference would be in that while I could reset all the things like day, date, time, etc., the oven would arbitrarily go off on its own and make up the day, time, date, year, etc., with no apparent correspondance to reality. Here's what I did: I completely shut down the oven at its outside breaker (you will need to do whatever it takes to remove the power from the 'plug-n-go'). I waited five or ten minutes before turning the power back on and resetting the various items. Two days have passed and there have been no more mind-of-its-own excursions into another time zone. Problem solved, unless/until another power outage cycle comes along. Hope this helps, or at least gives you an idea about where to start.
Dec 15, 2014 | Hardware & Accessories
My Westinghouse 668 wall oven won't allow me to set the time. We had a power outage and I have checked the power and it's fine now. But the display flashes between 0:00 and auto and I can't hold the two...
Does the rest of the oven work ok? Did the timer work OK before the outage? Is the oven under warranty? Was the power outage at your home only? Check with the manual to see if it addresses your problem, there may be a way to reset the system and then I would say that you would need to contact Westinghouse and explain the situation.
Nov 06, 2014 | Ovens
Bad line ge nomogram
You need to think of these ovens as electronic devices. If you get this message after a power outage, it is behaving just like your cable box or internet router when they have functional upset from a power outage. Turn the power off to the oven at the electrical box for 10 minutes then turn it back on. The oven should cycle up and then work. Mine did!
Mar 17, 2014 | GE Monogram ZDP48L4GHSS Dual Fuel...
Baking in the oven, and had a power outage. When the power is restored, will the oven remain "on" - afraid oven will come on while I am away, if power is restored.
The oven will come back on if power is restored. However just turn oven selector switch if applicable to the off position. If it is all electronic then it will automatically reset and not turn on when power is restored. If you need an absolute guarantee to to the breaker panel and turn off the breaker that feeds the range receptacle.
Aug 29, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Oven pilot went out due to power outage. I don't know where the pilot oven light is. where is the pilot light to light the oven?Ge XL44
pilot over lights do not require power to stay light or should it go out in a power outage! do you have to normally light pilot with a match? if not you have a glow coil and its a electronic ignition range and power will affect it. once power is restored you should just be able to turn on over and everything would be ok.if it is a pilot light you need to remove the bottom door stick arm in to back and you'll see the pilot assembly at back if you look up! hopethis helps...
Feb 06, 2010 | GE Ovens
Thermador Oven E10 error message--due to power outage?
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
Dec 08, 2009 | Ovens
F7 code on maytag cwb3100aab 24" wall oven.
Hi, The Function key is shorted or stuck.
Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Apr 11, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
No burner/oven heating after house power outage.
try reseting the clock as lots of ovens will not work untill clock is set
Jan 19, 2009 | Amana AER5515QA Electric Kitchen Range
Kitchen Ranges Logo
60 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
