Question about Janome Sewing Machines
Janome cxl301 needle shudders then gets stuck in fabric
Needle shudders and gets stuck in fabric, wont stitch and fabric is jammed
SOURCE: Fabric doesn't advance
Have you checked your feed dog position? The fabric will not advance if the feed dogs are in the down position. For the machines which don't have the raise/lower feed dog capability, there is a plate that covers the feed dogs and must be removed to advance the fabric when sewing.
Posted on Jun 16, 2007
dupina
  • 110 Answers
SOURCE: tension
Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine.
Posted on Nov 30, 2007
bargainbox
  • 1388 Answers
SOURCE: My Janome my excel 23x
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 25, 2008
SewExpress
  • 41 Answers
SOURCE: bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Dec 03, 2008
  • 5 Answers
SOURCE: Bobbin problems
Are you using a size "A" (Class 15) bobbin? If you are using pre-wounds and they are not this size... they will jump around alot. The size of an "L" is very similar, but they are not as tall (height off the table when laying flat on the round side... like when sitting in the bobbin case.) There are tricks to using the thinner bobbins... See if you have a "taller" size "A"/Class 15 and if that corrects the trouble. tjsews2008@gmail.com
Posted on Mar 02, 2009
How do I do a Pin Stitch with a wing needle on my Janome 12000?
I believe you pretty much use a wing needle like you would a regular needle. These links may be helpful:
What is winged needle
How To Sew Hemstitch Using Wing Needle
Tips on Using Wing Needle
Be sure to practice on scrap fabric before using it on your garment.
Oct 05, 2016 | Janome Sewing Machines
Why does the fabric get stuck in the feed dog plate?
try changing the needle it could be blunt
also make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin are for lint
Mar 24, 2016 | Brother Se425 Computerized Embroidery &...
Model 525B. Why is bottom stitch loopy and the hand wheel and needle jam?
try a new needle
try adjusting the top thread tension to see if that helps the bottom loopy stitch
Jan 10, 2016 | Janome Sewing Machines
Hemming knit fabric with ball point needle but have skipped stitches.
you may need a new ball point needle, the tip to the needle could have some damage to it. How to Choose Sewing Machine Needle for Knits eHow
Feb 21, 2014 | Janome Sewing Machines
Needle thread jams with first stitch
try rethreading the machine
change the needle--one that is correct for the fabric
turn the bobbin the opposite direction
clean under the needle plate and in the bobbin area for lint
Dec 16, 2012 | Janome Sewing Machines
Machine stitches 2 0r 3 stitch then skips stitches on rest of seam
Sewing machine skips stitches
needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Jun 01, 2012 | Janome 6019QC Mechanical Sewing Machine
How do I turn corners with the overlock foot for a Janome 2049?
Sew to the end of the fabric, slowing right down to within a stitch or two of the end, manually turn wheel to complete last two stitches, stop, raise needle, raise presser foot, turn fabric so the back edge of the fabric is just under the needle, drop needle, drop presser foot and resume.
Mar 13, 2010 | Janome 2049LX Mechanical Sewing Machine
Sewing Machines Logo
77 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
