Question about Plumbing
The method statement required for concrete column plumbness
  • 2,113 Answers
Http://www.ugdc.nsw.gov.au/sites/default/files/file_root/PDFs/Precincts/Redfern_Waterloo/North_eveleigh_bridge/Appendicies/Appendix%20D%20Construction%20Method%20Statement.pdf
Posted on Nov 28, 2013
If I clean up concrete contaminated by a post-1987 spill pursuant to state clean-up standards, can I continue to use the concrete? If not, what are the requirements?
You may use non-liquid materials such as concrete that were contaminated with PCBs $50 ppm provided the materials are decontaminated in accordance with a PCB disposal approval, or an applicable PCB spill cleanup policy, . The decontamination standard for concrete is <10 µg/100 cm² and requires that cleanup be initiated within 72 hours of the spill. If the state cleanup met these standards, you may continue to use the concrete. http://www.qjpcb.com/ Skype : wang.michelle35
Jun 29, 2016 | Office Equipment & Supplies
Installing a bathtub on concrete floor
Other than chopping out more concrete.elevating the tub is probably your only other solution. I would think 2" would be adequate.
Hope this helps.
Bob
Feb 08, 2012 | Crane & Co Crane Plumbing 2430W Whirlpool...
I was given an older spa and in the process on reconnect some broken pvc pieces. This is not an issue, but I have to built the side support and someone told my wife that I had to have at least one and a...
I think you were told that by someone who was taking into consideration the room needed to drain the spa and the clearance needed for the drain plumbing.
But you can rest the spa on the ground but I would at least put down some type of barrier between the fiberglass and concrete.
Fiberglass is very soft compared to concrete
Dec 04, 2010 | Dynasty Leisure Bay Dynasty Spas
Install plastic (fibreglass)shower floor tray. Do
no, they are designed to require no support. You may use small columns of expansion foam for added strength, but do not fill entire space with foam as it will raise the whole floor upon expansion.
Sep 22, 2010 | Home
I am instaling a shower under my house and i was hoping to get away with not cutting into the concrete for the drainage, is it possible to raise the shower bottom a foot of the ground for the drainage, and...
Yes, you can raise to avoid the cut by raising shower as long as gravity drain can occur, i.e. you can drain the shower to connect to existing drain lines. Definately put the s-trap in, if no trap then plumbing gas comes back and shower will smell. Remember to put in a plumbing vent or tie in to existing vent.
Mar 19, 2010 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
I need a manual for a 636 flowcrete concrete pump
Parts inside your printer are at the end of their service life. See your printer documentation.
sir, what should i do?
Nov 03, 2009 | Plumbing
Excel function
an2net21,
The simplest solution is to use the if function.
In your example you coudl use:
=IF(A1="girl",1,0)
IF "girl" is in a1 then b2 would show as 1.
If anything else but "girl" is in a1 then b2 would show as 0.
Feb 25, 2008 | Microsoft Office Professional 2007 Full...
Plumbing Logo
48 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
