My samsung un46eh5300 keeps powering off and powering on every 3 minutes,what could be causing this?
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Check whether the 'off timer' is set to 3 minutes or so. If not, the fault is with its main board. Contact any service technician. For more information go to http://electronicshelponline.blogspot.com/
Posted on Nov 28, 2013
  • 5 Answers
Check if everytime when enter Smart Hub, TV shuts off/on.
If it so, you need to upgrade FW version (latest is 02004).
You can download FW file from support Samsung site.
If TV keeps doing the same behaviour even upgrade FW version,
then it seems you have an issue with Bad Capacitors on Power Supply Board.
Posted on Apr 06, 2016
Every time I turn on my tv the red light just blinks
There may be an open internal fuse or the power supply may have failed.
Jul 08, 2016 | Samsung Un46eh5300 46 Inch 60hz Led Hdtv
Samsung tv repair
I was a Samsung Tech for over 3 years, I would take it apart and look for loose connections to the panel. If that does not work, you will have to start out with smaller parts. In my opinion its the main board. Whats the model number?
May 04, 2016 | Samsung Un46eh5300 46 Inch 60hz Led Hdtv
Picture dimmed. can see the picture and in menu increased the backlight to max but did not go back to normal. checked eco settings and did factory reset. still very dim but can see the picture.
Yah kindly follow this tip. After loosing the back cover when the tv power cord is removed from power socket, check for bulged or defect power capacitors in both the primary & secondary side of the power pack if found any kindly replace it with the actual or equivalent value as this electrolytic capacitor defects is much common for Samsung power packs
Apr 04, 2016 | Samsung UN46EH5300 - 46" LED-backlit LCD...
My Samsung LED tv (UN46EH5300) bought 2 years ago is powering itself off and turning back on. Just before it does this it becomes not responsive to the remote. Smarthub wont come up and it wont allow
Had this too. I found that I had accidentally plugged a cat 5 cord into two ports of my router (like a loop). As soon as I unplugged the offending cat 5, TV quit powering on and off. Fixed it.
Dec 12, 2014 | Samsung Televison & Video
UN46EH5300 adjust screen size to get whole picture and closed captions
Sounds like you have it on zoom setting. Go to the picture menu and scroll through the options. Start with 16:9 and try others if this doesn't work. If you've already tried this, you may have to go into screen setting and manually draw the picture in horizontally and vertically - but make sure you've got it on 16:9 and paused on a typical picture before you mess around with these settings.
Aug 22, 2014 | Samsung Un46eh5300 46 Inch 60hz Led Hdtv
Tv repair diagnosis
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 18, 2014 | Samsung Electronics UN46EH5300 - 46in...
Samsumg galaxy tab 3 shuts off every 30 minutes
Check the power settings to see if that is the cause of it shutting down. Streaming music does not produce the keep alive activity that is required, so it thinks that it isn't being used and turns off.
Mar 19, 2014 | Samsung Galaxy Tab Tablet PC
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
