Question about Philips Shn9500 Active Noise Canceling Headphone
Philips SHN9500 Noise-Canceling stopped working
About a month ago the noise cancelling function stopped working. When I turn the headset on it works for 1-2 sesc and then stops. Headset works fine if noise canc swithced off
2 Suggested Answers
SOURCE: PHILLIPS HEADPHONE NOISE CANCELING RIGHT SIDE
If I can get my password for facebook back I can use it. Becouse I can not remember my password
Posted on Sep 20, 2011
I have a pair of philips SHN-9500 noise canceling headphones and the left speaker is not working how do i fix this?
Unless you are really good and have the correct soldering gear, I\'d sudgest taking it to a repair centre. If you are going to have a go, you need a variable temp, needle point solder iron, a solder \'sucker\', a magnifying glass and a steady hand. The wires to each side are in s single unit. Here is a break down, from the centre, + then insulation,then the common which is rapped around that with another layer of insulation. Good luck!
May 17, 2014 | Philips SHN9500 Consumer Headphones
Logitech speaker feedback
Feedback is a sharp, loud noise that can come through the earphones of a headset unexpectedly---it occurs when the headset is getting sound (feed) from someone else speaking or playing music into a microphone. This sound can create a dangerous situation for someone who is operating expensive equipment or flying a plane at the time since it can disable hearing temporarily.
If you experience feedback often, it could also lead to serious hearing problems.
Mic Too Close to the Speaker or Volume Too High
The main cause of a feedback sound in a headset is proximity to a speaker. If a person holding a microphone on the other end gets too close to a speaker, it creates a loop of re-amplified sound that results in the loud, screeching noise. When the volume on the other party's microphone is too high, it is more vulnerable to picking up unwanted noise and feedback from speakers and sound output devices in the room. So make sure that you ask the other party to turn down the microphone to a normal level and stay far from speakers. b> Two Microphones Gathering Same Sound b> When the other party places two microphones too close to each other, it could cause feedback. When positioned toward the sound source (such as a person speaking) the microphones will both pick up the same audio and compete with each other when creating the output of sound, causing a sharp noise in your headset. This problem, called acoustic phase interference, is resolved by simply ensuring that the other party uses one microphone at a time. Poor-Quality Headset or Microphone b> One common cause of feedback is simply a poor-quality headset or microphone. Most modern headsets and microphones have noise-canceling features that manage and kill feedback before it has a chance to occur. These noise-canceling headsets are essential for pilots and aviation crew members. If you hear sudden feedback that is strong enough to hurt your ears, the headset or microphone is simply not properly equipped to actively cancel that unwanted noise before it hits your ears. Buy a higher-quality noise-canceling headset to manage the feedback noise when you're going about your tasks. Hope this helps.
Dec 23, 2012 | Logitech Z623 Speaker System
PHILLIPS HEADPHONE NOISE CANCELING RIGHT SIDE BROKE FROM HEADSET CAN IT BE REPAIRED
May 26, 2011 | Philips Audio Players & Recorders
I bought a new noise canceling/reduction headset. How can I set it up? I tried to set it up by myself following the instructions being fed to me but the person I was chatting with could still hear some...
Usually with a noise-canceling headset, it might block out most noises, and varying to the quality it might or might not work with people's voices. Normally, there is a small switch on the headset themselves to start emitting a kind of "white noise" to cancel out the outside noises. The headset might cancel out noises that YOU hear from the outside, but it doesn't guarantee that through the mic.
I don't think there is software needed to be installed. I would look a bit more to the instruction manual to see the precise specs on the headset.
Please Rate. Thanks :-)
Apr 03, 2011 | Computers & Internet
I have a Dynex microphone headset, but the mic's not working.
I have the same problem, I however do not know what the solution is.
Nov 28, 2010 | Dynex Mono USB Headset with...
How to make my headset work on my acer
You should be able to plug the headset into any available USB port on your ACER and then follow the prompts to download the drivers from the web. If that doesn't work then you can go to the Dynex site for support. This is the website to use:
http://www.dynexproducts.com/p-616-dynex-mono-usb-headset-with-noise-canceling-microphone.aspx
If you have any further questions please let us know.
Nov 02, 2009 | Dynex Mono USB Headset with...
Dynex Stereo Headset w/ noise canceling mic: Headset Won't Work!
More than likely it just burned out or the battery is defective.
May 19, 2017 | Dynex Stereo Headset with Noise-Canceling...
Crackly Headset
Mate, im having the same Problem i have no idea what to do!
When the Red light is on, it doesnt crackle, but when the Red light is on.. i cant use it as a Microphone.
But when i turn the red Light off.. there seems to be a crackly noise everytime i speak!!
I did manage to fix it for like a day.. i just pushed all the wires and it seemed to work. but hasnt for over a month now..
Aug 16, 2008 | Microsoft LifeChat Stereo Headset with...
Dynex Earclip Headset with Noise-Canceling Microphone driver
ok umm....it is a noise canceling microphone, the earpiece works but when i talk into the microphone no one on the internet can hear me please help me with my dynex earclip headset
Aug 08, 2008 | Dynex Earclip Headset with Noise-Canceling...
Philips Shn9500 Active Noise Canceling Headphone Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
