Question about Husqvarna Garden
How to check oil in transmission
Auto transmission working slow
2 Suggested Answers
  • 61 Answers
SOURCE: 2003 Mercedes C180 Compressor AUTO BOX transmission oil check
The transmission fluid is not to be checked or touched unless there is a malfunction in the system and the fluid has to be drained to repair it. The transmission is sealed form the factory and the fluid lasts the lifetime of the unit.
Posted on Jan 29, 2009
Bad transmission silinoid
You could have Explained What the car was doing BUT you most likely
need a transmission Rebuilt since most Transmission lockup solenoid's can't be accessed to easy, BUT I'll Assume and say your having Shifting problems slow take offs most likely seems to be taking off in 2nd gear or seems stuck in 2 gears at once after warm,, Not to mention may be dying out at stop lights?.. But feel free to add more Info, :)
Oct 20, 2014 | RTO Automatic Transmission And Engine Oil...
Why is my 1996 ford explorer having trouble engaging its transmission
Hi there
It sounds like the bands need adjusting or you are low in oil which causing the bands it get hot and slip,so get it checked out by the auto people .
Aug 23, 2014 | Cars & Trucks
Why does my 2004 4.4 X5 auto transmission **** until it reaches about 80kmph?
run the fault codes to check for problem servos and solenoids . Possibly a change of transmission oil would help. At 80mph you should be in OD so there would be no more servo /solenoid operation until you slowed down and the bands and clutch packs are again being used.. A band clutch pack adjustment may also be in order as out of adjustment will also cause jerky / slap on changes.
May 04, 2014 | BMW X5 4.4i
Slight jerking around 65mph 2002 jeep grand cherokee
if its a auto transmission check for the transmission oil.I would check the oil level or do the trans service.
Feb 05, 2014 | Jeep Grand Cherokee Cars & Trucks
Transmission
There are two types of transmissions in 1991 Toyota Corolla. Manual Transmission and Automatic Transmission.
1. Manual Transmission:
The transmission oil is checked through a level bolt which is provided to the left CV joint side in the middle of transmission. To check the oil level, park the car on a level floor, remove the level bolt with 22 mm or 24 mm spanner. If the oil starts coming out of this hole the oil level is considered OK. If not, top up the oil till it starts coming out and tighten the bolt. The recommended manual transmission oil grade is 75W/ 90W and total capacity is 2.4 Litres.
2. Automatic Transmission:
Warm up the engine, park the car on level floor, pull up the hand brake, gear lever stick in P, keep the engine start, let the radiator fan come on, take the auto-transmission stick out, wipe it with a clean dust free cloth, insert it in, again take it out, keep the stick in horizontal position and check the oil level. At operating temperature the auto-transmission oil level should be at upper level (Hot). If not, add oil to mach the mark. The recommended auto-transmission oil is Automatic Transmission Fluid (ATF) Dexron II, and total (drain and refill) capacity is 1.4 Litres.
Oct 09, 2013 | 1991 Toyota Corolla
Mazda 323 auto gear box when engine up to running temp and been driving for about 15 mins it keeps wanting to change gear culminating in the hold light flashing...and lumpy when slowing down or speeding...
You need a full service of the auto transmission. Check the oil condition for burnt smell.
The oil may be burnt out and fails to lubricate when temperature goes up.
But most likely the gear gaskets or gear teeth are worn out.
Mar 17, 2011 | 1994 Mazda 323
Auto Transmission problem: Feels like it doesnt shift into OD and accelerates slow as if it stays in one gear. When put in 1st, it feels like the park brake is up of you're riding the brakes.
have you check the oil level on trans and have you change the oil on the engine lately check the levels on both. Usually on engine is too much oil car drags and on trans if low oil it usually stays in gear to protect the trans. your car is telling you check oil. No lubrication some warning lights do not come up for trans
Jun 25, 2010 | 1991 Subaru Legacy
Transmission slipping
Did you check the trans oil level. When you changed
the RADIATOR you will loose some trans oil.
If the transmission oil was low when you changed
the radiator it's lower now. Check it now.
Now, if thats not the problem. With that many miles
have you changed the trans oil lately theirs a filter
above the trans oil pan that may be pluged up change
it and the oil. Also, buy a can of trans X it's the only fix
in a can stuff I"LL use.
Nov 09, 2009 | 1998 Dodge Ram 1500 4WD
I have a 2001 750il. The auto transmission is
Hello
I do not know how your mechanic making that judgement , but most probably it could be repaired . You will know for sure after dismantelling the transmission and checking the interior parts of it.
Usually the vibration comes from the Transmission convertor and that happens if low on oil or oil pressure is law.
You will need to check the status of oil and filter before you do any thing as some times if the filter is in need of change , could do that too.
Jun 13, 2009 | 2006 BMW 750Li
Car run slow, even step on the acceleration.
is it auto or manuel transmisson, diffently sounds like a transmission problem check oil level, and change if dark..may help
Jun 02, 2009 | 2001 BMW 325
Garden Logo
14 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
