The washer has hot and cold feeds but I only have cold water feed have used a y splitter but the cycle will not finnish and washing stuck in
SOURCE: Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
SOURCE: Tricity Bendix 1000 washer
you need to replace the element. remove the rear panel and you can access it
SOURCE: tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
SOURCE: washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
