Question about Masterbuilt 20070106 Electric Smoker
Display shows EAFF when heating - Masterbuilt 20070106 Electric Smoker
My laars series 2 spa heater stays on max heat. i cant lower the heat
if connected to control system maybe relay stuck on or temp sensor showing not up to heat if display you cannot change bad display
Apr 03, 2016 | Pool & Spa
I have a honeywell rth110b thermo and the other day I noticed that the display was fading and it looked like the battery icon was showing so I changed the batteries and now the display is completely blank...
The manual does not have troubleshooting steps.
Check the battery polarity, and clean points of connection.
Otherwise honeywell.com has customer care number
Oct 07, 2017 | Water Heaters
Nuheat thermostat keeps rebooting
replace the thermistat module..sounds like it has a bug in the firmware
Jan 08, 2014 | Nuheat Harmony Thermostat
Where do i get a book or assembly instructions also need igniter
Uniflame Patio heaters are manufactured my Blue Rhino. You can find what you need at the following link. http://www.uniflame.com/BRWEB/getdoc/74bac003-eaff-41fe-9d7c-7b02c79b6c3b/Outdoor-Heaters.aspx
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Uniflame 200209 Open Flame Patio Heater
LG DLE5932W no heat on permanent press , no problem with normal heat. Have replace the whole heating module, still no heat on permament press setting. Ran the diagnostic, ON pressing the start/pause button...
Check the "heater element" for continuity on both elements in the assembly. I think that you will find that one of them is bad. Here is a link to the part in case you need it.
Jan 02, 2011 | LG DLE5932W Electric Dryer
Spa / hot tub does not heat
Your temperature control is way out of calibration or, it's wired wrong. Remove it and check it in a glass of water. Use an ohm meter across the heater wires. As you add hot wwater, the heater contacts should open.
Aug 11, 2009 | Jacuzzi Home
My bosch dish washer won't work. A number 1 is displayed on the electronic panel. what does this mean Paul
Helloduranjp,
Welcome to fixya.
You said, Your Bosch dish washer won't work. A number 1 is displayed on the electronic panel.
If it is displaying"01" then that means the extra dry setting is being applied!
Did you try to use the extra Dry setting?
Did the dishwasher work before this or is it brand new?
What is the model number and year?
Let me know ! I'm waiting for your response
Below is and example of the usage of 01 or 00 in a Bosch Dishwasher!
Extra Dry Heat
With this option you can raise the temperature of the rinse water and increase the drying
time which will result in improved drying.
To activate :
Press and hold the left cancel drain button ,
Then press and hold the on/off button when the LED display shows a, "00" or a "01"
To enable the additional drying heat,press the left cancel drain button until the LED display shows a "01"
To disable the additional drying heat,press the left cancel drain button until the LED display shows a "00"
press the on/off button to save the settings.
Huuum
Oct 02, 2008 | Bosch Dishwashers
Masterbuilt 20070106 Electric Smoker Logo
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
