Question about HP PSC 1210 All-In-One InkJet Printer
Printer seems to be out of ink. installed new ink
Printer seems to be out of ink. installed new ink cart. and it will print one page and the next will be blank.
  • 527 Answers
Sir,
check these 2 links and go through the sites....
link 1
link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on May 09, 2009
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
I refilled my tri-color cartridge at Costco and my printer wouldn't print the alignment page. I bought a new cart and it worked fine. Then I re-installed the refilled cart to verify the fix, and it still...
a refilled cartridge IN NO WAY can lead to printer failure
the ink is the last thing on printer and has no effect to mechanical failures.
check here how you can refill your cartridge
http://www.youtube.com/watch?v=II9gpIXs_lE
Jul 02, 2010 | HP PSC 2210 All-In-One InkJet Printer
After cleaning/maintenance, pages are still blank.
If you have just bought new carts (ink) and installed them into the printer and there is blank pages. and the printer is acting like its printing (moving from left to right) and sending paper out then i would say 99.9% it is defintally the head. On the printers that have the head built in and you insert your carts (ink) into the head and you don't print but very so often this is a common problem with ink printers the head gets clogged. If you are attached to your pinter you can take it to a print shop and have them clean the head (they have to remove it from the printer)
When buy a printer if you dont print alot i always suggust to get a printer where the head is built into the cart (ink) like hp they are more expensive to repalce the ink but you get a new head every time :)
Hope this helps
Steven.
Apr 21, 2010 | Canon PIXMA MP130 All-In-One InkJet...
No color ink
To solve this issue what u can try is remove the ink cartridges from the printer. Unplugg and replugg the power cable. Clean the copper contacts of the carts using a dry paper towell. Snap the cart back to the printer and install the cart as the new cart. Print the alignment page. Also uninstall and reinstall the driver using the original CD, sometimes Windows can change to an "updated" driver with Windows update. It may have installed a B&W driver.
If all this fails it might be the issue with the encoder strip. Call Lex Tech Support and get help to fix the encoder strip.
Mar 02, 2010 | Lexmark X5470 All-In-One InkJet Printer
Colors are not printing correctly. put in a new cartridge, test page came back with only black, yellow, and blue. fiddled around with it a bit to no avail. put in anther new cartridge, test page came...
I use a small diameter silicone tube to carefully "prime" stubborn new carts by sucking a drop of ink out of the tiny print holes in the printhead part of the cart. Ink can dry at the head and since these carts work by electrical excitation, there needs to be liquid of each color at the holes. Slap a drop of water with your finger on the holes to start easy hesitant ones. Do not get the contacts wet.
Jun 04, 2009 | HP DeskJet 932c InkJet Printer
Lenmark printer black ink doesent print,
Suggest installing a new black print cart. espically if you have refilled the current one.
May 10, 2009 | Office Equipment & Supplies
Print head
Check that all, printhead and ink are seated and contacts are correct.
Power down the printer and allow for a complete power on and self test.
Dec 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Vertical lines
1. Took out the ink carts and cleaned the copper contacts of both the ink carts.
2. Clean the copper contacts on the ink carts slot in the printer and then insert the ink carts in the printer and then print out the page.
Dec 11, 2007 | Epson Stylus C60 InkJet Printer
Printer won't print in black
This could be to several reasons:
1#  The black cart contains blue ink-> Change to a brand new cart.
2# The cart assy has a bottom that is a foil. Sometimes this foil leaks.
Ink will mingle: You need a new cart assy.
Run the cleaning cycle twice after inserting a brand new bk ink cart and print out a test print. If you still see blue instead of bk the assy is leaking.
BTW the bk is darker than blue (or better cyan). You must see bk! So it seems to be the prob with the right ink....
Nov 11, 2007 | Brother Multi-Function Center® MFC-215C...
No printing
There can be a few causes for the ink light to blink. 1 - the cover isn't well shut. open and close it, and check for any obstructions. 2 - you're out of ink. let's assume you have this option covered, but if you want to check, look for the yellow indicator arrow on the cartridge. 3 - the carts don't sit right, or have a bad connection due to dried ink on the contacts. Take a damp cloth and gently wipe the contacts on the printer side till you get most of the ink off. Next, take the carts, and submerge them in hot water(1-2 mm high) so that only the contacts are in the water. Let the water dissolve the ink for a few minutes, take the carts out, give the contact area a few more wipes, wipe them dry, and try inserting them into the printer again. If you want to check with new parts, but rightly don't want to waste the money, try borrowing. Hope this helped
Mar 29, 2006 | HP DeskJet 1120cse InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
