Question about Polti Eco Pro 3000 Canister Steam Vacuum
My eco steam master is leaking water from base plate and not allowing the steam to escape help
Why is my iron leaking water from the sole plate
Can be two things
It needs descaling.
You are storing it sole plate down with water in it.
Oct 06, 2015 | Morphy Richards 42220 Power Steam Elite...
Shark Steam and Mop Vac - Model MV2010- My shark is heating up but not steaming. What could be the problem?
solution number 2 works. however, you don't have to take it apart, the base plate has a steam hole in the center, just clean out with a paper clip. watch out for the residual steam, it actually helps clean out the mineral deposits
Nov 07, 2012 | Vacuums
Hi. my mop is leaking water where the steam should be coming out, although the device is producing steam (which is escaping from the water reservoir)
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
=-=--0
Feb 19, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My polti vaporetto 2300 is belching with steam,have changd the safety cap seal,but hasn't helped --any ideas
My polti 2300 vaporetta is heating the water but not getting up to steam, could the problem be the safety cap?
Nov 17, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
Steam builds up but does not come out of the iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Jan 19, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
It does pick up the water
Sometimes the counting screws to the base of this machine get broken off and will not allow the dirty water tank to set just right to create suction. You may have to buy a new base housing for this machine.
Nov 28, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Polti Eco Pro 3000 Canister Steam Vacuum Logo
65 people viewed this question
Top Polti Vacuums Experts
Billy Detlefsen
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
