Question about OKI C3530N Color MFP Printer
OKI MC360 ADF Center Position Error
PRINTER WILL NOT PRINT AND IS COMING UP WITH ERROR ADF Center Position Error
Hi,, i have an oki MC160n,, that has an error coming up after a couple of pages being printed.. it says "paper size error, reset paper (1lt) press start key" can you help me fix this please
Please check the settings in your printer that you have selected correct paper type and tray from which you are printing. Also while giving print command make sure paper size is same.
May 05, 2011 | OKI Office Equipment & Supplies
My Artisan 810 ADF gets jam error. There is no paper there. The motor just whirls and then gives ADF jam error. My 810 is near new, less than 300 sheets printed, less than 100 scanned using...
Just fixed my problem today. It was the ADF assembly motor. The spur gear had cracked open where it can no longer grip tightly to the center rod when the motor spins. I bought a new motor assembly from CompassMicro for the total amount of $23 and my printer is back in running order like normal again. Beats taking it to a repair center and get ripped!
Sep 10, 2010 | Epson Artisan 800 All-In-One InkJet...
Oki mc360 appears offline. How do I get it back online?
Press the ONLINE button, or go to Control Panel / Printers and uncheck WORK OFFLINE
Mar 20, 2010 | OKI Office Equipment & Supplies
How come my canon mp830 printer prints a black line on left side when using ADF?
there are many possibilities that you will have to check out for: 1)either there is any dust got collected in the ADF assembly.so that dust is also coming in the prints. 2) of there is any thin object like hair got stuck up in the inner side of the ADF assembly.so whenever the print comes this copy of hair comes in every print out. 3) also there can be a slight crack in the ADF glass assembly.so this slight crack is giving the line in prints. 4) also the other reason can be that the black cartridge is low on ink.in this case it needs replacement of cartridge or the cartridge refilling. ----- so the first step you can follow is that you take a cleaning brush and clean all the dust on the upper ADF glass assembly where you place the paper.then take a moist tissue and clean the glass of the ADF assembly. then check out.if still the same problem then take a air blower and blow the air in the inner as well as outer area of ADF assembly and check out.if still the same problem then check out if any crack on the ADF assembly glass.if no crack then its the fault in the inner side of glass.for this the assembly and printer both needs to be disassembled.but this will require proper tools.its advisable to get it done by local printer/copier repair technician familiar with this brand/model. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Mar 09, 2010 | Canon Office Equipment & Supplies
073 fatal error in OKI c3530
Oki ERROR 073 is a H/W Overrun detect. this occurs when the video circuit has set the overrun bit. Restart the printer and check the first print out. Try printing a different job and then reprint the same job that the error occurred. If you get the same error again, try using a different driver, ie swap from PS or PCL whichever you were using to see if that clears the error.
Dec 28, 2009 | OKI C3530N Color MFP Printer
Have a oki c9800 ...gives error 923. have replaced the motor unit for black image drum but it prints some pages and gives the error again
923: Error - Black Image Drum Lock Error
The K ID unit is not operating
properly.
Check to confirm that Image Drum is seated properly.
Check to confirm that the K ID
unit is in position.
Replace the K ID unit.
Replace the K ID motor.
Dec 10, 2009 | OKI C9600hdn Laser Printer
Computer shuts off when a document is about to print.
first you should un install your driver,then install it again.
Jun 26, 2009 | OKI B4350 Laser Printer
Printing index cards on oki printer
i changed the settings on media to rough paper & made sure all paper was to come from mp tray, but it does jam frequently, and every time it does, i need to open & re-open the front cover to get it to clear the error that appears. the error reads mismatched paper size, as there is not a custom size of small index cards of 3.5 x 5.
Mar 06, 2008 | OKI C5500n Printer
Double Printing
check the printer drvier properties and make sur the defaulf is not set to print 2 copies.
Jun 14, 2007 | OKI MICROLINE 520 Matrix Printer
OKI C3530N Color MFP Printer Logo
114 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
