Question about Zebra 105SL Thermal Label Printer
We have a Zebra 105SL thermal printer. When I print to it with any application, the error light and paper out comes on.
    Sergeant:
    Habit-Forming:
  • Zebra Expert
  • 122 Answers
Sounds like it may need a calibration. Press the calibration button on the front of the machine.
Posted on Dec 17, 2013
3 Suggested Answers
ozztech
  • 285 Answers
SOURCE: Zebra 105sl felt paper error
check if the sensors behind the printhead (small metal open case)is on the same position that the uper sensor(black plastic bit with the screw behind the printhead) Run the sensor profile, check if he check the gap.
run manual calibration from the settings.
worst case senario, Reset the printer to Factory defult (Press PAUSE and CANCEL buttons and tun printer on, then relese the butons after 5 secounds.
Posted on Nov 13, 2010
printertech1
  • 96 Answers
SOURCE: We have a Zebra 105SL
The data light indicates that the printer is receiving data. Hold the cancel key for 10 seconds while powering on. This will print printer configuration. Use to troubleshoot. If the data or format is wrong it will not print as you send data. Make sure you are using the 105SL printer driver. To test the printer functionality you can go to www.teklynx.com and download a demo copy of labelveiw, select the 105SL printer and try to print a simple label. If you can print with labelveiw then it is not a printer problem. Double check your driver and label format.
Posted on Nov 21, 2010
Zebra 105sl printer labels print too small
There are 3 different DPI Printheads for Zebra printers if you print a label set up for a 200 DPI Printhead on a printer with a 300 DPI Printhead installed it will be about 66% of the size.
Feb 13, 2014 | Zebra 105SL Thermal Label Printer
We have a Zebra 105SL thermal printer. When I print to it with any application, the data light comes on, but it doesn't print. It has ribbon, media, calibrated, no error lights
Nov 12, 2010 | Zebra 105SL Thermal Label Printer
Jul 06, 2010 | Zebra 105SL Thermal Label Printer
Zebra 105SL thermal Label Printer prints blank with new supplies
Some possible reasons:
1. The darkness is not set high enough for the paper/ribbon combination
2. The ribbon is on backwards. Zebra uses coated-side out ribbons so the ribbon should be coming off the right side of the roll if you're looking at it from the side.
Hope that helps !
Apr 16, 2010 | Zebra 105SL Thermal Label Printer
Will print on sticker labels, but not on thick price ticket paper
If you are not using ribbon, the tickets are probably not Direct thermal. Try using a Ribbon and see if it works
Mar 02, 2010 | Zebra 105SL Thermal Label Printer
Zebra s4m error condtion paper out
Sounds like you will need to perform the calibration procedure.
when you access the menu system go to advanced menu, the password is 9999, use the keys to navigate to manual calibration and follow the instructions. when it states load backing this is refering to backing paper, so remove the labels from the backing and place in label path. hope this helps
Jan 16, 2009 | Zebra 105SL Thermal Label Printer
Poor Quality Print on Zebra 105SL direct thermal
How many labels has the printer printed? Because it sounds to me like you just need to replace the print head.
They are around $400 from whomever your supplier is, and very easy to replace.
Nov 12, 2008 | Zebra 105SL Thermal Label Printer
Paper out light comes on at 105sl printer
Dear team
sorry for lating to response to your question amd thanks very much for your help, the answers for your questions as follows:
the date i sent to printer through PC is anumber example( 2w1x326)
I use Thremal Transfre Mediatype
thanks very much
Jun 19, 2008 | Zebra 105SL Thermal Label Printer
105SL PRINTER PAPER OUT PROBLEM
What data you are sending to the printer?Can you post it?
What Mediatype u are using(Thremal Transfre or themal Direct)?
Zebra 105SL Thermal Label Printer Logo
70 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
