Question about Acer Aspire One PC Notebook
System restore for Acer Aspire one
Missing components need to system restore
    Top Expert:
  • Acer Master
  • 22,170 Answers
Try going back in time. Win7? Press Start, type "restore point" in the search box and select restore to an earlier time.
This will not affect your data just your registry..
Posted on Nov 28, 2013
4 Suggested Answers
zohail
  • 1223 Answers
SOURCE: restore factory settings
there are 2 ways for doing this
1) Fast and easy without backup disk just do this
Acer: When you turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
2) If the method above doesnt work u can do it thru backup disk u have got when u purchased ur laptop u shud have made it thru Erecovery software.
Pls rate me FIXYA for help !
Posted on Apr 13, 2009
  • 52 Answers
SOURCE: acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
gauravkumar6
  • 560 Answers
SOURCE: restore factory settings to acer aspire laptop
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, fget technical assistance at
http://www.vtechsquad.com/acer-support/
Posted on Sep 24, 2012
Acer aspire one restore failed: wont start now
the reason its saying,,ntldr is missing is because its lost somthing from the hard drive that it needs to run,it would have lost that when it stopd loading your windows.try it again and if it gives you..repair windows ,,,then do that.and it should do it because it should fint the missing file that it needs to carry on loading.
May 04, 2014 | Acer Aspire One Netbook 8.9" Notebook
Missing components
I'm not clear on what your question is? Missing Components? Are you, have you done a OS upgrade? If you need to do a System Restore/Recovery, assuming you have written over it, try the procedures found here:
Nov 28, 2013 | Acer Aspire One Netbook
Windows cant open bootmgr is missing, press ctrl+alt+del but not working how to fix it aspire one D257
Have you tried a System Restore/Recovery? Can you boot to safe mode? Try the restore/Recovery procedure: Shut down, unplug, remove battery, plug in, push the on button and When Acer splash is on screen hold Alt and keep pressing F10...
Apr 14, 2013 | Acer Aspire One D257 Netbook
Hello i have an Acer Aspire One model zg5 netbook
You're going to need to boot it from the Windows XP installation disk, which means if you don't have a CD drive you'll need to get an external CD-ROM drive. This will fix the problem.
Jul 16, 2010 | Acer Aspire One PC Notebook
Acer Aspire x1300 Desktop/Vista. Ethernet Controller Driv
First thing to try, is to do a system restore. You can go back to an earlier time. Pick the lastest time right before you installed the updates. System restore should be found in the Control Panel.
Dec 27, 2009 | Acer Aspire X1300 (PV.SCC0X.002) PC...
I have no backup or restore systems. I need to restore to factory settings. Please help.
There are only two ways to restore to factory settings.
1. use existing disks or purchase the original Aspire restore disks.
2. buy a new copy of Windows XP and then download any missing drivers from the Acer website.
with Item 1, if you have the original sticker under the computer showing the License Product ID code, then the replacement disks from Acer will be inexpensive. If you need a new licence as well, then the price goes up a lot!
Nov 21, 2009 | Acer Aspire 5610-4648 Notebook
My acer aspire one says is missing or corrupt system32 file how can i fix that?. EDWIN
A system32 file is a program file for your 32bit OS (Operating System) you could attempt a system restore from your start menu by finding the system folder and rolling your PC back to an earlier date, another last resort alternative is to reinstall your system or use your restore partition to reset your acer to factory settings by pushing F10 or F11 (dont remember which) when your system is booting up
Sep 29, 2009 | Acer Aspire 5610-4648 Notebook
1 Solution for "laptop windows/system32 config/system missing and a password" acer aspire 5100
Sounds Windows is currupt you will need to run the restore CD and reinstall to the way it was when you received your laptop.
NOTE, you will lose everything on the hard drive once you do this.
Good Luck.
Mar 04, 2009 | Acer Aspire 5100 Notebook
Recovery cd for acer aspire 3000
The "NTLDR is missing" error can sometimes occur when the boot.ini file is corrupt or missing but in your case it sounds like the HardDrive is the problem.
Try the Following:
Start>Run>Type "Cmd" and enter>Type "dir c:" and enter>Type "chkdsk" and enter. Your computer might promote you to chkdsk later Press "Y" and restart you computer
The Acer Aspire series usually have a eRecovery manager than ables you to burn 2 recovery disk which you should have done when you first got the laptop. Since you haven't done that you'll have to buy new recovery CD/DVD
http://www.user-guides.co.uk/asp/product.asp?product=1241&ph=search&keywords=Acer,Aspire,Recovery,CD&recor=1&SearchFor=any&PT_ID=100
OR you can try the following.
Start>All Programs>Accessories>System Tools>System Restore. Choose a restore point that goes back to before your NTLDR problem started.
Please Rate, Thanks.
Jan 08, 2009 | Acer Aspire 3000 Notebook
Acer Aspire One  PC Notebook Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
