Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Contunuous draining turned into a flood when unit powered off
I have a bosch SHU5305 dishwasher. It seems to run continuously on drain and never starts a cycle (it does not get by the drain it seems to start a cycle with). I tried a few things -- resetting it and such but eventually decided to turn the breaker off for a while. When I reset it, it seemed to work -- it was filling but it seemed to continue to fill AND drain. Never did much else, just kept filling at the same time it was draining. I turned the breaker off again and left it. After a while, there was a flood in my kitchen. Shut the water off to the unit, powered up the breaker and forced a drain. Now I am wondering... when I powered it off while filling, did that leave the fill valve open causing the flood? If so, then that's not a problem, just my being naive. To the continuous drain issue, what could that be?
  • 3 more comments
  • stephen_gord May 09, 2009
    Can I get to the switch through the kick or do I have to pull the whole dishwaher? I can see water underneath and droplets around but can't see or "feel" a styrofoam float or the switch it activates???
    I think I found it, i removed the two screws holding the fill valve and moved it and feel a float in a pool of standing water...trying to get that out.
    Question...how did the water get there?
    Removed the water with shop vac. Float and switch seemed okay. Turned breaker on...machine drained and started to fill. noticed small droplets dripping from fill valve...after 30 seconds or so it started to "whine" and there was a fine mist coming out of the solenoid itself. That would explain where the water came from .... off to see if i can get a fill valve.
    Make sense?
    Success! I got a new fill valve (styled slightly differently than the original), hooked it up and am back in business!
    Looks like root cause was a leak from the fill valve (solenoid) that sprayed water in the underside of the unit causing the float to engage and a continuous drain.
    All good now... part $40 CAD
  • stephen_gord May 10, 2009
    Thanks for the help -- definitely pointed me in the right area to investigate / watch.
    I think my chiropractor will be more expensive than the service all -- a lot of time on the floor in weird contortions! Seriously, thanks :-)!
  • 423 Answers
The fill valve is governed by the float switch. I doubt that your fill valve (solenoid) has failed.
Focus on replacing the float switch and you should be all set.
Good Luck!
Posted on May 09, 2009
  • Jeff Meyer May 10, 2009
    Well Done!!! Finding the root cause is very satisfying, isn't it? And being back in business without an expensive service call is even better!
    I hate being wrong, but so be it. :-)
    I would have put money on the solinoid valve being good, only because the high percentage of float assembly failures, compared to inlet valves. But there you go!
Bosch Dishwasher model #SHU3002UC-06 continues to run on any cycle, does not stop at the timer shut off spot
Anti flood device in a lot of german machines and pump keeps running only way to knock it off is too un plug what has happened water has leaked possibly over a period of time ,and set the anti flood device off if ya disconnect macine plug and drain hose and lie on its side water will drain off anti flood put some towels to catch water and macihne should work after ya reconnect
Nov 01, 2015 | Bosch Dishwashers
Bosch dishwasher shx46a06uc-30
the unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
Apr 17, 2012 | Bosch 24 in. SHX46A05UC Built-In...
Questions about snaking the drain line for a Bosch SHU5305. Should I be able to snake all the way from the sink connection into the dishwasher or is there some type of backflow prevention or something...
I would NOT recommend you snake into your dishwasher because you could damage the drain pump.
If you think you have blockage, then take the unit out and disconnect the drain line and take it outside and use a hose on it.
Just remember to disconnect the power first.
Jul 16, 2011 | Dishwashers
Dishwasher turns on but nothng happens.
drain pump blocked and has overfilled flooding base pan and activating anti flood device tip machine to the left to remove water and consult handbook on how to clean pump outlet.
May 08, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Drain pump won't turn off
The reason the drain pump continously runs is because it is trying to remove any water too avoid any further flood as there is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Hope this helps.
Jan 24, 2010 | Bosch Dishwashers
Dishwasher cycles through all programs but will not drain or turn off at the end of cycle. I do not know if it drains inbetween. It just continues to run on 0 minutes and when I turn it off and open there...
underneath the machine there is a donute shaped styrofoam item called a flood safty switch .makke sure there is no debri underneath..mice will drag animal food or chew on this and will lodge it leaving debri under it causing it to trigger a false flood condition causing the machine to go in to a continual drain-is there a digital readout on your machine reading 88 continuasly
Aug 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHX33A runs continuously. Never finishes cycle.
I have a guide here to walk you through the process of clearing the drain system. You most likely have a clog somewhere and the dishwasher can't proceed because it would cause it to flood.
Jul 27, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch SHU43C Dishwasher
Is there no water coming in( hear no water at all) or no water NOT staying in ( drain motor running) ... the float switch is a safety to keep the dishwasher from flooding ...turns on the drain motor as soon as the door is closed..
I could check the control and see if you have power to the water valve.. maybe a control problem if no power..
Sep 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHX46A02UC-21
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
367 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
