Question about Huhtamaki Foodservice Chinet 14x18 Molded Fiber Food Tray, 250 Trays HUHFARM HUH FARM
136,000 miles this will be third time replacing thermostat for code p128.freeze frame said 69 m.p.h. coolant temp159 intake air temp 39??
Her fan is noisey always has been i mean for first few minutes or mile or so
  • mcsweeney6 Nov 30, 2013
    oh i didnt mention 139,000 on 2003 ford explorer.4.0v6..runs a tad too cool
I have 2008 PT Cruiser; getting P0128 code; I've changed thermostat & temperature sensor; I have to fill the anti-freeze container every 2 weeks; temperature hand will not always be at half way point. ...
This means that the engine's PCM detected that the engine has not reached the required temperature level within a specified amount of time after starting the engine. The intent of the P0128 code is to indicate a faulty thermostat. In determining the engine did not reach a "normal" temperature, it takes into account the length of time the vehicle has been running, the intake air temperature (IAT) sensor reading, the engine coolant temperature (ECT) sensor reading, and the speed of the vehicle.
A code P0128 may mean that one or more of the following has happened:
  • Low engine coolant level
  • Leaking or stuck open thermostat
  • Faulty cooling fan (running too much)
  • Faulty coolant temperature (ECT) sensor
  • Faulty intake air temperature (IAT) sensor
Past experience indicates that the most likely solution is to replace the thermostat. However here are some suggestions on troubleshooting and repairing a P0128 OBD-II code:
  • Verify coolant strength & level
  • Verify proper cooling fan operation (check if it's running more than it should). Replace if necessary.
  • Verify proper engine coolant temperature (ECT) sensor operation, replace if necessary.
  • Verify proper intake air temperature (IAT) sensor operation, replace if necessary.
  • If the above items check out good, replace the thermostat
you have all ready replaced the thermostat with the proper temperature opening thermostat(hopefully) and coolant sensor, you say you have to refill the coolant every 2 weeks this indicates that you either have a coolant leak that needs to be checked out and repaired or you are burning coolant which indicates a possible head gasket problem which will have to be checked. a low coolant level will set this code as there is not enough coolant in the engine to get the engine to operating temperature and stay there. these last suggestions is where I would start to look.
Sep 24, 2014 | 2008 Chrysler Pt Cruiser
99 sc1 overheats and lacks power
sounds like the catalytic converter is pluggged, not allowing exhaust to escape, therefore causing the engine to be hotter on topside, and loss of power
Sep 07, 2012 | 1999 Saturn SC
P0128 (and P0116) on 2006 GMC Sierra v-8, 5.3L, 4x4. Originally getting low temp readings on guage. After replacing the thermostat, the problem seemed to be fixed. A few days later, I was getting my...
P0116 - Engine Coolant Temperature (ECT) Circuit Range/Performance Problem
The ECT (Engine coolant temperature) sensor is a thermistor which changes resistance based on temperature of the coolant in contact with it. The ECT sensor will be located in the block or coolant passage. Usually it is a two wire sensor. One wire is a 5 Volt supply from the PCM (Powertrain Control Module) to the ECT. The other is a ground to the ECT.
As the temperature of the coolant changes the resistance on the signal wire changes accordingly. The PCM monitors the reading and determines coolant temperature in order to perform essential engine fuel management. When engine coolant is low, sensor resistance is high. The PCM will see a high signal voltage (low temperature). When coolant is warm, the sensor's resistance is low and the PCM will see a high temperature. The PCM expects to see slow resistance changes on the ECT signal circuit. If it sees a quick change in voltage that isn't consistent with an engine warming up, this P0116 code will set. Or if it sees a lack of change in ECT signal, this code may set.
Symptoms: There may be no noticeable symptoms if the problem is very intermittent, however the following may occur:
MIL (Malfunction Indicator Lamp) illumination
Poor drivability
Black smoke at tailpipe
Poor fuel economy
May not idle
May exhibit stalling or misfires
Causes: Potential causes of the P0116 code include:
Missing or stuck-open thermostat
Bad ECT sensor
Short or open on signal wire
Short or open on ground wire
Poor connections in wiring
Possible Solutions: If there are any other ECT sensor codes, diagnose them first.
Using a scan tool, check the ECT reading. On a cold engine, it should match the IAT reading or should be equal to ambient (outside) temperature reading. If it does match the IAT or ambient temp, check the freeze frame data on your scan tool (if equipped). The saved data should tell you what the ECT reading was when the fault occurred.
a) If the saved info indicates that the engine coolant reading was at the coldest exreme (around -30 deg. F) then that's a good indication the ECT resistance was intermittently high (unless you live in Anchorage!) Check for an open in the ECT sensor ground and signal circuits and repair as necessary. If they appear okay, warm the engine up while monitoring the ECT for any intermittent jumps high or low. If there are replace the ECT.
b) If the saved info indicates that the engine coolant reading was at the warmest exreme (around 250+ deg.F) then that's a good indication the ECT resistance was intermittently low. Check for a short to ground on the signal circuit and repair as necessary. If it appears okay, warm the engine up while monitoring the ECT for any intermittent jumps high or low. If there are replace the ECT.
Other ECT sensor and circuit related DTCs: P0115, P0117, P0118, P0119, P0125, P0128
P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
This means that the engine's PCM detected that the engine has not reached the required temperature level within a specified amount of time after starting the engine. The intent of the P0128 code is to indicate a faulty thermostat. Similar codes: P0125
Symptoms: You will likely not notice any drivability problems other than the MIL illumination.
Causes: A code P0128 may mean that one or more of the following has happened:
Possible Solutions: Past experience indicates that the most likely solution is to replace the thermostat. However here are some suggestions on troubleshooting and repairing a P0128 OBD-II code:
If Nissan vehicle, check for Technical Service Bulletins (TSBs), as the ECM may need to be reprogrammed to correct the P0128 code
These codes are telling you that the engine temperature is not sufficient. This can be caused by a faulty coolant sensor,air in the cooling system,or a faulty computer.
The engine should run at 190 F & higher when warmed up. Scan the computer system to view engine temperature.
Keep us updated.
Oct 01, 2011 | 2006 GMC Sierra
Po128 is the code. What's the problem
Well, I can't give you any specific information regarding your vehicle because you forgot to mention what kind of vehicle you have. (This is kinda important if you really want some help figuring out what is wrong with your car)
The "Generic OBD" of code P0128 is "Coolant Temperature Below Thermostat Regulating Temperature"
The most likely cause is a stuck-open thermostat, however, I have also seen defective Engine Coolant Temperature (ECT) sensors also cause this code.
Jun 13, 2011 | Chevrolet TrailBlazer Cars & Trucks
Eror code: PO128 Code
Symptoms You will likely not notice any drivability problems other than the MIL illumination.
Causes A code P0128 may mean that one or more of the following has happened:
Possible Solutions Past experience indicates that the most likely solution is to replace the thermostat. However here are some suggestions on troubleshooting and repairing a P0128 OBD-II code:
  • If Nissan vehicle, check for Technical Service Bulletins (TSBs), as the ECM may need to be reprogrammed to correct the P0128 code
Other ECT sensor and circuit related DTCs: P0115, P0116, P0117, P0118, P0119, P0125
Feb 08, 2011 | Buick Rendezvous Cars & Trucks
My 2003 kia spectra comes up with P116 and P128 error messages. What do I need
p0116 is-- engine coolant tempurature ckt/range performance----- p0 128 is--coolant temp below thermostat regulating temperature. to fix these 2 codes are similar, change coolant tempurature sensor and thermotat all should be ok. make sure coolant in radiater is full. hope this helps you.
Feb 07, 2011 | 2003 Kia Spectra
I have a 2004 Chevy Impala. As I was driving home yesterday I had the heater on full blast - temp outside appx. 60. The check engine light came on and I had a P0128 code. Could this be due to keeping...
REFERENCE: http://www.obd-codes.com/p0128
I hope this helps a bit!
Jan 11, 2011 | 2002 Chevrolet Venture Passanger
P0128 coolant temp below thermostat/regulating temp
P0128 - Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
* Low engine coolant level
* Leaking or stuck open thermostat
* Faulty cooling fan (running too much)
* Faulty coolant temperature (ECT) sensor
* Faulty intake air temperature (IAT) sensor
* Verify coolant strength & level
* Verify proper cooling fan operation (check if it's running more than it should). Replace if necessary.
* Verify proper engine coolant temperature (ECT) sensor operation, replace if necessary.
* Verify proper intake air temperature (IAT) sensor operation, replace if necessary.
* If the above items check out good, replace the thermostat
* If Nissan vehicle, check for Technical Service Bulletins (TSBs), as the ECM may need to be reprogrammed to correct the P0128 code
Hope helps (remember to rate and comment this).
Sep 27, 2010 | 2006 Dodge Caravan
2007 Chevy Cobalt with p0128 and "---" temp reading
The P0218 Code is primarily intended to indicate a faulty thermostat.
Have the thermostat replaced
Other possible causes that could trigger this code would be:
faulty cooling fan
faulty coolant temperature sensor
faulty intake air temperature sensor
Sep 08, 2009 | 2006 Chevrolet Malibu
BMW 325ci - Car cuts off on very hot days - Error code P00128
Check the following :
BMW Code PO128
solutions
Past experience indicates that the most likely solution is to replace the thermostat. Verify coolant strength & level
Aug 18, 2009 | BMW 5 Series Cars & Trucks
Huhtamaki Foodservice Chinet 14x18 Molded Fiber Food Tray, 250 Trays HUHFARM HUH FARM Logo
497 people viewed this question
Top Huhtamaki Foodservice Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Huhtamaki Foodservice Retail Supply Expert? Answer questions, earn points and help others
