Wireless internet is showing available, but it wont connect. I have an Aspire One, model number kav10, .... what do I need to do.
If your other laptop is working fine, then have a look at the configuration of the wireless card and use the same configuration on the one that is not working.
Depending upon your wireless card make there is a program that enable you to setup the wireless card. Go to Start - Programs to locate this program. If your wireless card is built-in refer to your Acer manual.
Encryption is setup on the wireless router and these settings are also used to configure the wireless card. If the encryption is already setup, changing the encryption will affect your other wireless card, therefore all the wireless cards will need to be reconfigured with the new encryption to work with the wireless router.
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire.
Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver.
Restarting the computer corrects this issue.
hope this helps
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
How do configure the wireless LAN card??? yes we have an ISP. I have another laptop that is working fine. Ande where do I go to enable the encryption?
Have you got an Internet Service Provider?
Have you enabled encryption on your wireless router?
Have you configured your wireless LAN card with the same encryption that you created on the wireless router?
