Screching noise when i turn on AC
2002 dodge grand caravan when i turn on the air conditioning it makes a screching noise. but thats the only time i getthe noise. belt is good and not lose all pullys are not loose there is a washer in the center of the AC clutch/pully that appears loose behind the nut but cant tighten nut to sinch up washer appears to be a counter wieght maybe bad clutch i assume how hard is this to replace or woudl it be best to replace the whole compressor?
  • rvigil88 May 09, 2009
    is the bearing something that can be changed easily?
    Sergeant:
  • 201 Answers
Sounds like front bearing on compressor. clutch works on magnetic pull in principle so screech is probably bearing and not clutch assembly.
Posted on May 09, 2009
Fisher Paykel washer makes a screching noise
Turn the washer over and see if this model uses a belt to drive the transmission for the washer, if so replace it, I will bet it does, if not the transmission is defective.
Oct 07, 2016 | Fisher Washing Machines
Rear ac blows warm after replacing expansion valve and evap core,also cold at expansion valve and temp actuator is working
2006 Dodge Caravan Rear AC evaporator Blockoff Easy air ...
? 15:00
www.youtube.com/watch?v=Fz2obM-laOA
Jul 2, 2012 - Uploaded by banshee8989 Most of the time if your AC stops working on a 2002 to 2008Dodge Caravan it is ... 2005 Dodge Grand Caravan 3.8L. No luck so far finding that ...
Jul 28, 2015 | 2008 Dodge Grand Caravan
2004 grand caravan air conditioning not working
clicking noise is a/c compressor kicking on and off from freon being low, need to recharge a/c system, these vans our bad about rear a/c evaporators leaking if you have the rear a/c option.
Sep 03, 2012 | 2004 Dodge Grand Caravan
When i turn on the heater it makes a screching noise
your blower motor is dying, replace it with a new one before your run out of heat/air conditioning
Jan 13, 2011 | 1998 Chrysler Concorde
Screching noise is it waterpump
that is very likely on this model.
Oct 21, 2010 | Dodge Neon Cars & Trucks
1997 Olds 88 Low Screeching Sound When Turning Wheel
Hi, be sure you have the power stering fluid to the max level, check the condition of the belt if is in good condition adjust it properly ,when the car turns ,it adds more presure to the pump and if the belt is not tight it will slips and make that screching noise ....good luck...
Nov 19, 2008 | 1997 Oldsmobile 88
Nissan problems
id say you need to replace your serpentine belt and or put belt dressing on it to stop the screching
also tell me more about the car cutting out
Nov 09, 2008 | Apple iPod MP3 Player
Air condition
I have a 2004 Dodge Grand Caravan SXT. I had the same problem and had a auto shop replace the thermostat and my AC works just fine now.
Sep 07, 2008 | 2004 Dodge Grand Caravan
AC AND ROUGH IDOL
Check the dodge website for recalls and see if the pcm needs to be updated. The pcm controls everything in that van.
Jun 02, 2008 | 2002 Dodge Grand Caravan
Heating & Cooling Logo
191 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
