Question about Life Fitness 95Ti Treadmill 95 Ti
User not detected
Only kicks in at low speed
    Top Expert:
  • Life Fitness Master
  • 12,223 Answers
Please RUN the software calibration for easy diagnostic and fix it. Go under the HOOD and read the instruction and proceed.
God bless you
Posted on Nov 28, 2013
My 1998 lexus e300 is running hot and I noticed the cooling fans are both running but at low speed. what controls the fan speed
The PCM(computer) controls the fan speed. Low speed comes on around 200 degrees, high speed kicks on at around 225 degrees. If they come on when you first start the engine, the coolant sensor is bad. PCM is in default mode and runs the fans all the time. Since it doesn't read the 225 mark, it won't kick on the high speed. Turning on the A/C will also kick on the high speed fans. That's if your A/C works.
Jun 21, 2015 | Lexus Cars & Trucks
Fan speed button on window air conditioner
This is mot my field of expertise, in any case here is the user manual. Hope it can help
Feb 25, 2008 | Comfort-Aire EKTC12-150J Air Conditioner
Abs kicking in when it shouldn't at low speed when
Without knowing what your driving and not knowing the mileage don't know what to suggest???????
Mar 07, 2013 | Cars & Trucks
Air conditioner pump clutch keeps kicking on and off at low rpms, car dies.
This is caused by one of two things, the AC is low on charge (refrigerant) or the idle speed is to slow to a problem in the automatic idle speed control system.
Aug 30, 2011 | 2004 GMC Envoy
Is there a list for computer codes for 1980-1990's Chrysler Le Baron
Yes here is that list.
Chrysler products COMMON CODES OBD1 (vehicles made before 1995)
Part 1: Chrysler Domestic vehicles
CODES/Meaning
88 display used for start or test
11 camshaft signal or ignition signal, no reference signal during cranking
12 memory to controller has been cleared within 50-100 engine starts
13 map sensor not detecting any change during test
14 map voltage too high or too low
15 vehicle speed sensor, no signal detected
16 knock sensor circuit. open or short detected
17 low engine temperature, possible thermostat fault
21 oxygen sensor signal, neither rich or lean detected
22 coolant sensor voltage low
23 air charge voltage high/low detected
24 throttle positioner sensor voltage high/low
25 automatic idle speed motor driver circuit, short or open detected
26 injectors 1,2,3 peak current not reached
27 injector control circuit does not respond to control signal
31 purge solenoid circuit, open or short detected
32 egr solenoid circuit, open or short detected
33 a/c clutch relay circuit, open or short detected
34 speed control servo solenoid, open or short detected
35 radiator fan control relay circuit, open or short detected
36 wastegate solenoid, open or short detected
37 part throttle unlock(PTU) circuit, open or short detected
41 charging system circuit not responding to control signal
42 fuel pump or auto shutdown (ASD) relay voltage sensed at controller
43 ignition control circuit not responding
44 battery temperature voltage circuit problem
45 turbo boost limit exceeded-map sensor detects overboost
46 battery voltage too high
47 battery voltage too low
51 air/fuel at limit
52 logic module fault
53 internal controller failure
54 camshaft reference circuit not detected
55 end of message
61 baro read solenoid, open or short detected
62 emr mileage not stored
63 eeprom write denied
64 flex fuel sensor signal out of range
65 manifold tuning valve, open or short detected
66 no ccd messages
76 ballast bypass relay, open or short detected
77 speed control relay, open or short detected
May 31, 2011 | Chrysler LeBaron Cars & Trucks
Have a 2 stage 70000btu 2 stage furnace by goodman. I have hooked up a honeywell steam humidifier. and when it calls for humidity the high fan speed does not kick in. The only fan speed that kicks in is...
Sorry to read about your problem, I hope this helps you out.
well its best to let the low fan do the humidity work, and not the high.. you did not provide the model of the goodman, but you ether went direct to the heater control card, to the humidity connection . or wired to the low side call contacts. you can hook the humidifier to the high fan speed contacts
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Goodman Heating & Cooling
When check engine light up, the truck start to kick at low speed
Hi! THe transmission may have gone in limp mode thats why it kicks on low speed at times. As a first course of action please replace the automatic transmission fluid for the fluid may be burnt causing it to perform poorly. Hope this helps and have a good one!
Aug 17, 2010 | 1999 GMC Sonoma
My 2000 eclipse 2.4L runs hot at idle only
Your car should have a High and low speed connector there. That would cause the problem you described, if the PCM sees the temp at about 195 the low speed fan should kick on, if that fan doesn't provide enough airflow it kicks on to high speed to cool quicker. in your case the low speed is non existent and the computer is simply waiting for the temp to raise to the point where it triggers the high speed relay.
Feb 25, 2009 | 2000 Mitsubishi Eclipse
2002 Chevy Avalanche ABS kicks in at low speed braking.
maybe a wheel bearing gone bad so sensor reads different speed causing the computer to think wheel is slipping then abs kicks in I have seen this problem with a 2002 gmc 2500 duramax diesel
Jan 07, 2009 | 2002 Chevrolet Avalanche
Abs kicks in at low speed and pedal pressure
You have a weak or bad ABS sensor on one of the hubs. They are built into the hub and are not individually replaceable. Also rust buildup around the sensor will cause this same problem. To stop the ABS from kicking in untill repair just pull the fuse.
Jul 02, 2008 | 2001 Ford F150 Styleside SuperCrew
Life Fitness 95Ti Treadmill 95 Ti Logo
56 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
