Question about Hardware & Accessories
Lennox gas furnace G12Q3-110-6 fan timer and relay
Don't know where the wires go on the relay from the timer
hotuna
  • 288 Answers
SOURCE: gas furnace wont stay lite
I'm a little confused by your terminology. You are saying you have a pilot lite and electric heat strips? Are you possibly meaning burners? Is the heater running for 2 hours straight without shutting off? how cold is it there? Lastly what temperature do you have the thermostat set at and how close does it get to the temp. before it shuts off?
Posted on Dec 20, 2007
SOURCE: lennox 80 ugh furnace turns on, ignites gas and shuts off in 2-3
I can appreciate in the fact that you do not want to offer a solution to my problem without paying money however you would like me to tell you how I fixed my problem for free, if you would like to know how I fixed it, how about you subscribe to my premium plan and I will tell you.
signed,
Not impressed
Posted on Nov 24, 2008
  • 85 Answers
SOURCE: NEED WIRING DIAGRAM FOR WISPER
http://hvacpartsshop.net/G20_Series.pdf This should be what your looking for.
Posted on Dec 09, 2008
  • 85 Answers
SOURCE: Heater no longer works on auto fan, only manual fan
When you call for fan in auto ensure your getting 24 volts at pin on control board, if it is not energizing then there is a problem with the relay.. Before you change out the expensive control board, try the therm..
  • 221 Answers
SOURCE: Lennox Fan will not come on when set to ''auto'' position.
Expensive is relative, service calls are never free. But if you have an idea what the problem is, you are armed against an unethical service company. Now to what you describe, could be a couple things, first let me explain the difference in fan speeds. Furnaces that both heat and cool have multi-speed blower motors. High speed is for cooling and lower speeds are for heating. The fan switch at the T-Stat turns on the high speed fan relay. The lower speed fan is turned on by either a temperature activated switch (silver box mounted on front on furnace above burners) or a time delay relay which is solid state. That being said, your problem could be a defective fan switch or one of your blower motor windings has gone bad. Most motors have 3 or 4 speeds and a technician could just change speeds and all would be good. A fan/limit switch is not so expensive that you would replace the unit. Bottom line, unless your really handy, a heating company is in your future. Good luck and please rate my answer if it was helpful to you.
Posted on Jan 02, 2010
Testimonial: "Thanks. I am not handy when it comes to furnace repairs, however this info will help me when I speak to the tech 1/4. I'll let you know the outcome."
Lennox 80 MGF furnace heat only. Both diagnostic lights are indicating everything is ok with the ignition control but the furnace main fan runs continuously. The fan is on automatic at the stat
So no heating just blower? If you have a g wire on the tstat remove it first. Then possibly a stuck relay. Obviously if the blower stops when g removed the tstat is bad.
Aug 14, 2017 | Heating & Cooling
Furnace computer won't let furnace light
What is the model number? I have an SLP98 (installed on 11/29/2011).... and if I take the cover off the front of the furnace the panel that has the fancy "Lennox" badge on it) you will see two clear round windows about the size of a half dollar (one high on the furnace box and one lower on the blower box.) If you look downward into the window on the blower box you can see a red LED display that will sometimes flash error codes like E228 (one character at a time). If your model has something like this, let me know. I've done some DIY fixes recently out of necessity....and their easy.....and several technicians confessed they didn't know much, if anything, about the newer high effieciency Lennox gas furnaces.
Mar 01, 2013 | Lennox Heating & Cooling
Lennox furnace model G11Q3-110 v.2 burners light but go out before fan comes on
Troubleshoot an ignition problem on a Lennox gas furnace ...
? 2:44
https://www.youtube.com/watch?v=yXIxgzwMkPs
Nov 17, 2012 - Uploaded by grayfurnaceman
This furnace should light its pilot with a spark then the pilot proves its on ... Troubleshoot an ignition problem on a Lennox gasfurnace .... Pilot and no inducer but is the same model as that great video! ... You probably have dirty burners. ... How do you know spark module is not sending 24 volts to mv and pv ...
Lennox Furnace Model G11Q3-82-2 - RepairClinic.com
Nov 19, 2012 | Heating & Cooling
I have a lennox 2 stage gas furnace and a lennox XP15 heat pump controlled through the Lennox 7000 touchscreen thermostat. I want to disable the heat pump due to excessive noise due to lower temperature...
At tstat press options. Press installer setup. Yes, you are qualified. System settings, non heat pump. Gas/ oil heat. Save changes. That should do it with no wiring changes.
Jun 18, 2017 | Heating & Cooling
Dec 31, 2009 | Superior Lennox Blower Thermal Sensor -...
My Lennox gas furnace runs for approximately two minutes and shuts off. Normally the blower runs for a few minutes but no longer is this the case. My furnace repair man cleaned the flame sensor and it...
if the unit has a flame (gas valve opening)the problem may be the fan going bad or fan relay -- sounds like unit going off on high limit control
Nov 01, 2009 | Heating & Cooling
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Dec 09, 2008 | Heating & Cooling
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
