Question about Brooktrout Technology Brooktrout TR114 P2L Modem
NO DIAL TONE
LINE FAULT: Possible phone line failure on channel three consecutive no-dial-tone errors within 45 minutes.
Check tel line error msg
Have you checked for dial tone on the line? It sounds like you have a problem with the inside wiring to the phone jack. To test your dial tone out call you number and use a screwdriver and stick it inside the phone jack on the wall, if you have dial tone to the jack you will hear the "short" that you are putting on the line.
Oct 16, 2012 | Uniden DECT 6.0 Cordless Phone ID
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
My phone show in use. Therefore I have no dial tone. I unpluged all phones and still no service.
Maybe your line is out of service, you can test it by connecting a standard wired phone to the line cord instead of your wireless phone base, if you have dial tone, the problem is at your wireless phone system, if there's no dial tone it could be a cable failure or in the central office, in this case you have to report it to the corresponding phone company.
Feb 26, 2011 | Uniden Lands Phones
Phone won't transfer to next free line when a second call comes
If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
Modem problem
Disconnect the phone line from the modem and connect a normal phone to this phone line. Lift the handset and check it you have a dial tone and see if you can dial out.
If you don't get a dial tone then there is a fault with the phone line and it needs to be repaired before you can use your modem.
Apr 14, 2009 | Dell Latitude C640 Notebook
No dial tone on xp
U need to double confirm the phone line whether got dial tone or not. What u can do is to plug the phone line to a single line phone. If dial tone is available, u can able to make call.
Feb 13, 2009 | Dell Inspiron 530 Desktop Computer
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
HP Officejet v 45
Do you actually have a dial tone on the phone line?
It will still dial without a dial tone.
Plug a phone into the line ans check for the presence of a dial tone. I suspect that to be your problem.
Mar 31, 2008 | Computers & Internet
Brooktrout Technology Brooktrout TR114 P2L Modem Logo
Top Brooktrout Technology Computers & Internet Experts
David Payne
David Payne
Are you a Brooktrout Technology Computer and Internet Expert? Answer questions, earn points and help others
